Old 07-07-2011, 10:47 AM   #1
Bottom Feeder
Member#: 2808
Question Fuel injection coming to NASCAR in '12, but what type?
I'm not a fan of stock car racing, but the recent news (to me, at least) that NASCAR is finally going EFI next year is interesting.
Looks like McLaren is supplying the electronics, but does anyone know if it'll be old-school TBI, multi-port, or something else?
Bottom Feeder is offline   Reply With Quote
Old 07-07-2011, 01:43 PM   #2
Draken
Member#: 16
1964 Autodynamics
Formula Vee
Sounds like multi-port, since they had mentioned Holley being spec supplier of the TB, McLaren the electronics, but a "unnamed supplier of fuel injectors."
They are testing the cars today at Kentucky with the FI setup.
Draken is offline   Reply With Quote
Old 07-07-2011, 01:50 PM   #3
04trailsti
Member#: 179170
This could bring the tuning aspect to a whole new level.
04trailsti is offline   Reply With Quote
Old 07-07-2011, 02:14 PM   #4
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
... Never thought that I'd see the day. I'm actually quite shocked to be honest.
axelthrasher is offline   Reply With Quote
Old 07-07-2011, 06:25 PM   #5
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
^ yeah, me too. they're still on bias ply tires though, right?
lil'redwagon is offline   Reply With Quote
Old 07-07-2011, 07:23 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I wish they'd catch up with where motorsports were 10 years ago and run direct injection
at least they're in the early 80's now with EFI
Old 07-07-2011, 08:22 PM   #7
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
They should keep with their old tech ways and start out with Unichips and then move up to UTECs.
rjrutzky is offline   Reply With Quote
Old 07-08-2011, 08:28 AM   #8
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Put your Apexi SAFC on eBay - it might be on Dale Jr.'s dash next year!
LetItSnow is offline   Reply With Quote
Old 07-08-2011, 09:56 AM   #9
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
nascarforums.com Does anyone know or could come over and help me tap my ecu for my safc?
Really though, they are going to have to build some stout systems with all that heat they generate. It'll be hard to make something as reliable as a carb and 2 msd boxes.
Old 07-08-2011, 01:07 PM   #10
Scooby921
Thanks Sir Alex!
Member#: 88606
2011 GMC Sierra
1990 Miata
Do they really see any more heat or worse conditions than the systems in use in any other racing series? I understand that NASCAR is pushing close to redline for hours at a time, but at the speeds they are running the airflow is much better for cooling things. I would think anything designed to last an ALMS or LMS 12 or 24 hour event is more than capable of handling a NASCAR event.
Scooby921 is offline   Reply With Quote
Old 07-08-2011, 03:53 PM   #11
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
In the drafting races they do. The car in the back sees next to no air at all. Not nearly as much drafting in road racing.
Old 07-08-2011, 08:04 PM   #12
chkltcow
Member#: 10814
'08 135i
97 Miata M
They'll have to run "compromised setups" to get better cooling. They may have speeds to get the airflow, but they'll block off the radiator openings to allow the bare minimum air through so they can preserve aerodynamics.
chkltcow is offline   Reply With Quote
Old 07-15-2011, 11:25 AM   #13
Homemade WRX
Member#: 33782
96 bastard child
that's also why thermal efficiency is so crucial for motorsports. The more thermally efficient, the less heat you put into you radiator and engine bay...thus less airflow needed to cool your radiator and also the smaller the radiator you can get away with
Old 07-15-2011, 12:54 PM   #14
kfoote
Member#: 39180
2004 WRB STi
Slash Ten - FBHIC
nope, it's been a long time since they used bias ply tires. This is off the top of my head, but I'm pretty sure that NASCAR, at least at the Cup level, last used bias ply tires in the mid-1990's.
NASCAR has access to a spec ECU and a good idea of how they'll work. The Grand-Am Rolex cars use a spec Bosch ECU, though it is different among the different cars.
kfoote is offline   Reply With Quote
Old 07-19-2011, 06:49 PM   #15
BigRigger
Member#: 129969
2005 Sti
Silver/Black
WOW, hopefully this will start a trend in motorsports. Next they will start using new technologies like DOHC motors and 5 speed transmissions.... LOL
BigRigger is offline   Reply With Quote
Old 07-22-2011, 01:24 AM   #16
nevin95 LSi
Member#: 219571
'02 wrx wagon 259k+
'95 SVX ebony mica
i can see it coming... New for nascar 2030: 4 cylinder turbocharged engines.
nevin95 LSi is offline   Reply With Quote
Old 07-22-2011, 02:18 AM   #17
Ryguy32789
Member#: 214559
2005 WRX
Now they need to start using OEM Camaro, Mustang, and Challenger chassis. I feel that for NASCAR to regain some relevancy, they need a stronger connection to the fanbase- using "stock" chassis could provide that. It's also been a long time since "Win on Sunday, Sell on Monday" was true, and I'm sure they manufacturers would throw more support behind the teams if that started happening again.
Ryguy32789 is offline   Reply With Quote
Old 07-22-2011, 11:22 AM   #18
Homemade WRX
Member#: 33782
96 bastard child
^^^seeing the torture test and flogging on the eco-boost engine for instance, I know has helped sales for Ford. If they were actually displacing their engine getting the crap kicked out of it in their vehicle, I'm sure it would influence sales to some extent.
Old 07-22-2011, 12:41 PM   #19
Bottom Feeder
Member#: 2808
NASCAR doesn't need relevancy when they are as popular as they are and with such a big fanbase. They aren't going to change anything because it's doesn't need to be changed.
Sure, there's nothing 'stock' about a stock car, but they can't go backwards now and keep it the same sport.
Old 07-22-2011, 12:57 PM   #20
borisbsp
Member#: 162978
02 WWRX Wagon
http://iagperformance.com
Totally agree.
borisbsp is offline   Reply With Quote
Old 07-22-2011, 02:40 PM   #21
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
to me as a disconnected NASCAR watcher... I can say if they DID go back to mainstream chassis, with a reasonably and DIRECTLY derived powerplant I would watch. I would love to see my beloved Ford prove itself with the 5.0L Modular DOHC against the mighty LS-series of GM or the HEMI 5.7 (not SRT-8 6.0). And make Toyota use a street-based version of the tundra V-8 NOT an F-1/Indy derived power plant... If Honda wants to join... then the Ridgeline engine is the choice...etc.
All of NASCAR has gotten soooo far away from "stock cars" that its a joke.
Rob
TXwrxWagon is offline   Reply With Quote
Old 07-22-2011, 03:24 PM   #22
Ryguy32789
Member#: 214559
2005 WRX
NASCAR's popularity is in a free fall right now. Have you watched a race this season? I would be surprised if 1/5 of the races were sold out- and a lot of them had probably at least 1/4 of the tickets still available at race time.
I started to lose interest when the Car of Tomorrow came out and everybody had to use the same cookie cutter chassis, as well as when NASCAR took a tough stance on aggressive driving.
Old 07-22-2011, 04:02 PM   #23
chkltcow
Member#: 10814
'08 135i
97 Miata M
It's not just that.... the word "stock" is wholly meaningless in racing in general. Go look at AutoX "stock" class cars with $10,000+ in suspension work and Hoosier slicks.
And yes, attendance is down. They're offering buy one get one free for the Charlotte fall race, I think... and the All-Star race tickets we got were steeply discounted. NASCAR hasn't taken a strong stance on aggressive driving, though... anything but. It's still "have at it, boys" unless something has changed in the past few weeks.
Old 07-22-2011, 04:51 PM   #24
Ryguy32789
Member#: 214559
2005 WRX
I know about the "Have at it boys" mantra, but the thing that I was thinking about was Kevin Harvick and that punk ass Kyle Bush being on "probation."
Old 07-22-2011, 05:30 PM   #25
chkltcow
Member#: 10814
'08 135i
97 Miata M
That wasn't "aggressive driving".... that was flat out ****ing stupidity. Hockey allows fighting on the ice... but I guarantee if two players meet up in the parking lot to battle it out, both the NHL and local police might have something to say about it.
So the time has come to get new brakes, but not sure what to get - HELP! DJS_02_WRX Newbies & FAQs 31 12-30-2009 12:53 PM
Ford Mustang, Dodge Challenger Coming to NASCAR? Camaro to Follow? AVANTI R5 Non-Subaru News & Rumors 11 06-16-2009 01:47 PM
NASCAR coming to Anderson in southwest MO drewwrxrogers Mid West Subaru Owners Club Forum -- MWSOC 3 03-04-2007 10:51 PM
NASCAR coming to Anderson in southwest MO drewwrxrogers Mid Atlantic Impreza Club -- MAIC 5 03-03-2007 07:01 PM
Honda Civic Type R Coming To States In 2010? NYCshopper Non-Subaru News & Rumors 25 03-02-2007 04:52 PM
Message Board Statistics All times are GMT -4. The time now is 02:23 AM.
