Old 07-08-2011, 02:11 AM   #1
saabaru11
Member#: 280963
2005 92xaero
desert silver
Default Total noob on washing engine bay
Need some input on how to correctly clean your engine . Do I spray the engine down 1st? If so what can I not wet? I hear simple green and a tooth brush work the best. Thanks for the help!
saabaru11 is offline   Reply With Quote
Old 07-08-2011, 02:44 AM   #2
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
cover your air filter if it's open.
Spray the rest of that **** down.
Simple Green and a brush.
Dress plastic if desired.
Done.
XanRules is offline   Reply With Quote
Old 07-08-2011, 09:36 AM   #3
buki_JB
Member#: 274345
2011 STI 5dr
^^ This. Just did it last night...you will be surprised how awesome it works.
Also, sometimes if the bay is super dirty, it's best to let the simple green soak in for a bit to really penetrate through the muck that's on there.
buki_JB is offline   Reply With Quote
Old 07-08-2011, 11:41 AM   #4
AspenScoob255
Member#: 217405
2006 WRX
Add do not blast the alternator with H2O to Xan's list.
AspenScoob255 is offline   Reply With Quote
Old 07-08-2011, 12:50 PM   #5
buki_JB
Member#: 274345
2011 STI 5dr
Why? I feel like it gets plenty of water on it while driving in the rain, what's the difference?
Old 07-08-2011, 01:07 PM   #6
AspenScoob255
Member#: 217405
2006 WRX
Driving in the rain and shooting pressurized water into it are 2 different things. Besides it is covered so most rain water is deflected or rerouted anway.
Old 07-08-2011, 01:26 PM   #7
96max2fast
Member#: 252910
I would put a plastic bag over it and an exposed aftermarket air filter just to be certain and hose the rest of that sucker down!
96max2fast is offline   Reply With Quote
Old 07-08-2011, 01:29 PM   #8
STiwestMA
Member#: 191070
05 WRX STi
Done.
+1 works excellent.
STiwestMA is offline   Reply With Quote
Old 07-08-2011, 01:57 PM   #9
SubieDugie
Member#: 119219
2005 STi
WR Blue
If you run the engine while spraying water on it you will find out pretty quick what can't get water on it. If you do though, don't run the engine long enough to get hot, which isn't long. You should never spray any cleaner on anything hot especially your engine. Basic engine rule is stay away from all electrical components to include wiring/connectors. Be careful using any APC/cleaner undiluted on your engine especially rubber/plastic, and never on bare aluminum. Follow the manufacturer's recommended dilution mix for the job at hand. Only spray a direct stream of water where it really needs like oil/grease build up areas. A little APC and some mild scrubbing/agitation works better than straight blasting with water. If in doubt keep the water away; take the time to cover things using al foil, plastic bags, and tape. Avoid getting any undiluted APC on the paint and headlights, and any cleaner you get on the paint/hdlts make sure you rinse off immediately or wipe with a clean, wet microfiber clothe. To dry your engine without starting it and possibly getting steam build up into electrical connection or loose seals on things like headlights, use the blow side on a shop-vac and wipe things down with a towel to avoid water spotting especially on the rubber, plastic, bare al/metal, and non-clear coated paint under the hood. If you dress the engine use a true protectant for the surfaces your are dressing. 303 Aerospace Protectant is great because it's non silicone based so it won't attract dirt and build up like armor-all type sprays. Dressing the motor, or any other area for that matter isn't just for looks. It keeps the material from deteriorating from heat/dirt buildup. Recommend using a spray detailer/spray wax on the painted surfaces to brighten them up and give a little protection as well. Spray detailers/waxes/sealants can be sprayed on during the drying step to save you time and help reduce marring the paint/glossy surfaces and make drying easier/faster usually. To clean the fire retardant material attached to the underside of the hood, spray a mild cleaner onto a damp cotton terry clothe and dab the fire retardant material taking care not to rub hard. Whatever you do don't soak the stuff then scrub it and pull at it. There are cleaner designed for cleaning electrical components like connectors and electric motors; you can find them on autogeek.net that I know of.
Have fun and be safe.
SubieDugie is offline   Reply With Quote
Old 07-08-2011, 03:28 PM   #10
saabaru11
Member#: 280963
2005 92xaero
desert silver
Thank you all for the input. Sounds like I got a fun project this weekend.
Old 07-08-2011, 03:36 PM   #11
renob123
Member#: 41986
'06 STI/'85 Brat
The Simple Green in the blue bottle (Simple Green in a blue bottle...that makes no sense) is apparently safe for aluminum. I used it once with no disastrous results.
Jacob
renob123 is offline   Reply With Quote
Old 07-08-2011, 03:38 PM   #12
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
I cover the filter and purple power the **** out of everything and hose it off. Make sure to have the car aiming toward the sun when you start. Once you are done leave the hood up for an hr or so and let the sun dry up the remaining water
Cbgrandtheftauto is offline   Reply With Quote
Old 07-08-2011, 04:21 PM   #13
SubieDugie
Member#: 119219
2005 STi
WR Blue
Great point. Just make sure that you take it out of the sun and let the eng bay cool before applying any dressings/protectants, as to prevent streaking.
Old 07-11-2011, 06:41 PM   #14
veener79
Member#: 204304
2008 WRX 4D Stage 2
veener79 is offline   Reply With Quote
Old 07-11-2011, 10:40 PM   #15
The Duke
Member#: 264877
Disclaimer - POTENTIALLY it MAY harm your engine. I am not responsible, etc.
Now, seriously, some say that washing a motor is bad and that it could cause damage to the electronics. I have washed my share of motors and never had a problem with electronics, wiring, failing parts, slipping belts, etc. If you're stupid about this I'm sure there's a way to kill the motor, but otherwise you're golden. You drive a car with a big whole in it anyways...
Thing you need:
Degreaser (Non-acidic cleaner preferrably. Won't harm metals)
Brush (for Agitating)
Towels (Cloth or paper)
Process;
Start:
1)With the engine cold/slightly warm at best (we don't want warping) lightly spray the motor. Some prefer to cover the alternator, battery, or other sensitive areas. If you want (I never do and I never have a problem) cover it with plastic wrap.
2) Apply cleaner, being agitating with brush.
3) Rinse off with hose. Use low pressure and avoid sensitive areas (if uncovered, don't drown the alternator for example. Getting it wet is fine, but don't spray it for 5 minutes on full blast).
4) Wipe excess. Use a towell or brush to wipe off the motor and any standing water. Good for removing water from plug holes, belts, etc.
5) Optional - Engine Dresssing.
Some prefer to spray the engine with a dressing that will keep it shiney and protect it. I've used CD2 engine cleaner and I liek it (follow direction) but it was nice just to clean the motor honestly. I like the bare OEM look, and it's nice to not have to wipe my hands when touching my motor. If you choose, usually it's spray it on a cold engine and turn the motor on to bake it it (it's a resin). Then wipe excess away.
6) Clean-up.
Spray/clean the dirt spot on the drive that you will have.
The Duke is offline   Reply With Quote
Old 07-13-2011, 04:47 AM   #16
kateviliams
Member#: 285333
simply use green or aluminium cleaner or polish.
kateviliams is offline   Reply With Quote
Old 07-13-2011, 10:00 AM   #17
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Jus beware of high pressure water, use the low pressure setting at the CW or stand back a ways... the engine is pretty well sealed, besides the obvious... but it's not sealed for typhoon pressures.. lol..
washed engine bay, now car won't start CEL on pinoy_boy204 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 06-08-2010 10:12 AM
changed oil, washed engine bay... EGT not working now?! Rallye-fan Electrical & Lighting 0 12-31-2006 03:08 PM
noisy pulley after washing engine bay kiwee Transmission (AT/MT) & Driveline 4 08-07-2006 10:02 PM
washing engine bay 949 Interior & Exterior Modification 1 08-29-2005 01:35 PM
Washing Engine Bay? Inprogress Texas Impreza Club Forum -- TXIC 14 08-08-2005 12:17 AM
