Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 07-08-2011, 10:08 AM   #1
ryoga28
Member#: 62946
2012 Audi S4
Default Low gas mileage - 16 mpg (2011 wrx)
I used to get 18 mpg using the aem cai on stage 2, but after switching to the Cobb tuning Sri air box I started to get 16 mpg instead. Same driving habbits. Anyone else with the same problem?
ryoga28 is offline   Reply With Quote
Old 07-08-2011, 11:21 AM   #2
Cobb Tuning
Member#: 4803
For the 2011 WRX, we support the stock, Cobb SF, and AEM intake. Each of these intakes has a different set of maps. I would make sure that when you switched to the Cobb SF intake, that the correct Cobb SF map was reflashed. Other than that, there should be no difference in fuel economy between these intakes and I would just give it some additional time (since the reflash).
Bill
Old 07-08-2011, 01:01 PM   #3
funderpants
Member#: 281694
2011 WRX
Gray
^I have a 2011 WRX running the 93 octane Stage II AEM map. 45-65mph hour long drive through bluffs and hills and I averaged 24.6mpg. Same trip back but using a ethanol free 93 from mobile I averaged 33mpg!
funderpants is offline   Reply With Quote
Old 07-10-2011, 09:05 AM   #4
ms6ftw
Member#: 286274
how long has it been since you reflashed it? let it settle, try it after 50 miles running the map.
ms6ftw is offline   Reply With Quote
Old 07-10-2011, 04:44 PM   #5
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
im getting 24 mpg with my 08. i have the same vf52 turbo as you swapped. also stage 2 tuned. yours seems very low.
424wrx is offline   Reply With Quote
Old 07-11-2011, 12:55 AM   #6
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
I'm running a 2011 WRX, getting about 18mp from Cobb Stage1 map. Got about 21 on the highway. Disappointed But I didn't buy it for the mpg
pet3r is offline   Reply With Quote
Old 07-11-2011, 10:53 AM   #7
lickitysplitwrx
Member#: 276859
I have the Cobb SF intake and the correct tune for it and I am averaging 25.5 mpg this tank.
lickitysplitwrx is offline   Reply With Quote
Old 07-15-2011, 04:29 PM   #8
funderpants
Member#: 281694
2011 WRX
Gray
People getting <20mpg either have something wrong with the car, crappy gas, or a combination. If the right map is run with the right fuel, it should be getting at least 22+mpg highway. ..............unless of course you're driving like there's a free taco giveaway somewhere.
Old 07-17-2011, 09:36 AM   #9
ryoga28
Member#: 62946
2012 Audi S4
I'm getting an average of 16.8 now with a combo highway/city driving. It's already on the second tank of gas. I guess i'll get my dealership to check it out for me later
Old 07-17-2011, 10:32 PM   #10
JordanM9
Member#: 273214
2013 WRX Limited
CBP
I am running stage 1 +sf 93 map and at 70 mph I almost always get 27.x so I think 16 is some sort of issue.
JordanM9 is offline   Reply With Quote
Old 07-19-2011, 03:11 AM   #11
tehra33it
Member#: 259917
2011 wrx limited
black
i have a wrx 2011 and i drive thru a canyon on curvey roads and some highway and avg 21-24mpg
tehra33it is offline   Reply With Quote
Old 07-24-2011, 05:00 PM   #12
MESSENGERMAN
Member#: 171381
2005 Impreza WRX STi
I've been averaging 20-21mpg in the city and 24-25mpg on the highway with my 2008 wrx with a vf-52 swap protuned at 298whp and 314wtq.
MESSENGERMAN is offline   Reply With Quote
Old 07-24-2011, 11:56 PM   #13
horrorbiz
Member#: 77290
13 SSM BRZ
06 Impreza 2.5i
Hmm.. I'm running Stage 1 93 and I get around 21-22MPG and I drive semi-aggressively. I also tend to drive a little too fast on the highway. I work from home so my car rides always vary.
My friend's wife also has a 2011 and she gives me a hard time because she gets an average of 24-26MPG. She definitely drives a lot more conservatively than I do.
horrorbiz is offline   Reply With Quote
Old 07-27-2011, 08:11 PM   #14
Cobb Tuning
Member#: 4803
Mileage can be very dependent on driving style. Also, if you are getting worse mileage and you just changed intakes, you might take a look at your install, there could be an intake/boost leak. However, how often you are in boost, how hard you drive etc can really take a toll on mileage.
Low gas Mileage question. umscooby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 34 05-11-2012 02:43 PM
Low gas mileage and pulsating after front brake change bawalker Brakes, Steering & Suspension 4 01-05-2008 08:58 PM
Low gas mileage blue-flame General Community 13 01-16-2005 09:56 PM
any experiences with low gas mileage? the spacecowboy Normally Aspirated Powertrain 11 02-15-2001 07:54 AM
poor gas mileage - any ideas? rubbersidedown General Forum Archive 12 11-13-2000 01:16 AM
