![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
#Belieber
Moderator Member#: 140163
Vehicle:03 STi hellaflunctional |
this fitment thread encompasses ALL styles: hellaflush, aggressive, stretch & poke, meaty tires, wrong fitment, correct fitment, etc.
this is not the thread for opinions. there is no right and wrong. points will given accordingly. if any "correct fitment" crew members post here, you will receive points for each and every post. please search and research before posting. i'd like to see educated questions, not "can i run a 17x9 +20 without modifying my fenders and stock suspension?" please follow this format: year: model: wheel model: wheel size/offset: tire brand/model: tire size: suspension: alignment: DON'T BOTHER ASKING ABOUT AN "AGGRESSIVE" SETUP IF YOU'RE GOING TO SAY YOU DON'T WANT TO ADD NEGATIVE CAMBER fender mods: spacers: yes/no? size? please let me know if there's anything else i can do to improve this thread. thanks in advance for everybody's help assisting other members. if you don't know what's required to fit a certain fitment, please refrain from posting so we don't clutter the thread up. if you think an offset is too low, too bad...don't post because this is the style thread where people do things because they think it looks good.
#2 |
Member#: 66815
SCIC
Vehicle:2005 WRX Wag -SOLD:( CGM STX #125 |
year: 2005
model: WRX WAGON wheel size: 18x8.5 wheel offset: +35 tire size: 225/40-18 suspension: KW V3, GC front camber plates fender mods: Aggressive roll w/ no pull rear, none in front Wheels are flush, no poke, stretch tires allow for pretty decent tuck. I get to post in both motorsport and form > function fitment threads =D |
#3 |
Member#: 8303
Vehicle:2011 SWP WRX 02WRX & 05STi (both sold) |
year: 2011
model: WRX Sedan (base) wheel model: Rota Grid (Hyper-black) wheel size/offset: 18x9.5/+38 tire brand/model: Falken Ziex ZE-912 tire size: 265/35-18 suspension: BC Racing BR Series alignment: -2.0f, -1.9r fender mods: rolled rears spacers: no Wanted to go for a nice, subtle look since this is my DD. My goal was to get rid of the huge wheel gap, but not a complete drop. Before: ![]() After: ![]() ![]() ![]() Yes, it may not look like much of a difference, but behind the wheel, it's night and day ![]() Last edited by WR_eXe; 07-09-2011 at 04:24 PM. |
#4 |
Member#: 101315
Vehicle:2011 WRX Hatch Torqued_Performance Stg 2 |
year:2011
model:WRX hatch wheel size: 18x9.5 wheel offset: +38 tire size: 265/35/18 suspension: DGR coilovers, Cusco rear lower control arms fender mods: rolled rears camber: -1.7F, -2.0R ![]() |
#5 |
Member#: 193959
Vehicle:2002 Wrx Wrb wagon 05 Wrx AW 18x10 WFC#295 |
i like this thread already. only addition would be maybe wheel and tire brand and model.
year:2005 model:wrx Wheel model: Miro Stp1 wheel size:18x10 wheel offset:+25 Wheel brand/model: falken ziex 912 tire size:225/40/18 suspension:megan street coilovers upgraded 135mm 10k fronts to go lower, 6k rear fender mods:rolled and pulled front and rear, no fender liners, tucked harnesses, blow torch and hammer front fender tubs to not rub Camber: -3.5f -4.5r Spacers: no, but for brembos you need a 5mm spacers to clear. ![]() ![]() ![]() ![]() ![]() ![]() Last edited by under0athh51189; 07-09-2011 at 04:27 PM. |
#6 | |
#Belieber
#7 |
Member#: 193959
^cool my post is fixed. hoping we get alot more posts in here.
#8 |
Member#: 8303
Fixed mine as well. Should become a pretty informative thread once we get more posts.
#9 |
Member#: 157348
South East
Vehicle:It's rowdy outside I ain't signin' s*** |
![]() year: 1997 model: Outback Sport motorsport: I can't afford track time wheel model: Team Dynamics Monza wheel size: 17x7 wheel offset: +45 tire brand/model: Toyo Extensa HP tire size: 225/45/R17 suspension: KYB AGX / Whiteline FlatOut springs / Saggy Butt Spacers alignment: I forget fender mods: rear roll and cut, wicked JDM saggy bumper (complete with missing tabs )spacers: n/a ![]() ![]() Last edited by XanRules; 07-09-2011 at 11:15 PM. |
#10 | |
Member#: 268115
NWIC
Vehicle:2005 WRX Wagon 48W- CGM |
#11 |
Member#: 50902
RMIC
Vehicle:05 STi White |
Perfect thread, i wonder where the inspiration came from??
year: 2005 model: USDM STi wheel model: Rays/Prodrive GC07J wheel size: 18x8.5 +44 tire size: 225/40/18 suspension: Tein Flex w/front camber plates. Bolts in rear. alignment: -1.4 front, -2 rear. fender mods: Aggressive cut, lip and plastic trim + slight pull rear. Nothing front. spacers: 9mm front and rear. +35 total offset notes: I have 245/40/18's for track days that also fit. Wheels are flush no poke, 225's sit nice and tucked. pic before spacers, camber set at -1.1 front -1.6 rear. ![]() pics with spacers coming... Last edited by umscooby; 07-12-2011 at 04:28 PM. Reason: posts need pics! |
#12 |
Member#: 193959
i think that people should only post a setup if they have pics, just my $.02
#13 |
Member#: 100002
SCIC
Vehicle:2005 WRX STi AW Real.Man.Krew. |
year: 2005
model: STi wheel model: Work XD-9 wheel size/offset: 18x10 +18 tire brand/model: Hankook V12 EVO tire size: 235/40/18 suspension: BC Racing BR Coilovers alignment: -2.7*F/-3.4*R fender mods: Rolled/Pulled Front Fenders. Rolled/Pulled/Shaved Rear Fenders spacers: No Spacers ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#14 |
Member#: 233651
Vehicle:2008 WRX DGM |
I want to know if i put
20mm ichiba v2 spacers on my stock wrx 2008 wheels (Eibach Springs are on) will i have to roll fenders? thanks ben |
#15 | |
#Belieber
if you have more than 20mm between the inner edge of the fender lip and the outer edge of your tires, you won't need to roll your fenders. |
#16 |
Member#: 243697
Vehicle:02 Stg2+ WRX Top Scoob 031 |
A very simple question, but I'll post up all the specs regardless.
Question: Would adding 4mm or 5mm spacers make any difference at all visually? year: 2002 model: WRX wheel model: Rota Grid wheel size/offset: 17 X 7.5/+48 tire size: 225/45/17 suspension: KYG Struts/Tein springs (1.5" drop) alignment: Stockish fender mods: None spacers: None ![]() |
#17 |
#Belieber
no...you'd be better off buying new wheels with your desired offset.
#18 |
Member#: 271998
South East
Vehicle:2002 WRX Phatbotti tuned 16GXT E85 |
Year: 2002
Model: Wrx Wheel Model: O.Z. Alleggerita HLT Wheel size/offset: 17x8/+48 Tire size: 225/45/17? Recommendations? I want to have good grip around turns etc. Suspension: KYB Agx struts with epic engineering springs and F&R swaybars Alignment: Stock for now Fender Mods: Don't really want to do any... Spacers: Do I need some? Thanks! |
#19 | |
Member#: 50902
RMIC
you would have no trouble fitting a 245/40/17 with your setup. in general shorter sidewalls give you more stability through turns as well as better turn in response and feel. taller sidewalls are more cushy feeling. for summer tires the wider they are the more grip you're going to get as long as your camber isn't way out. Last edited by nhat; 07-17-2011 at 11:58 PM. |
#20 |
Member#: 127232
W. Canada
Vehicle:Do You Even Subaru |
delete
#21 |
Member#: 248479
RMIC
Vehicle:2000 sti'ish outback and something german |
so im thinking about doing something stupidly aggressive on a 02 sedan.
18x13 +20 not sure on tire size but will need to be stretched for days. im thinking i could get 265s under the fenders with lots of fender work, and between -3 to -4 degrees of camber and its going to poke a bit i dont want to run flares. stock fenders with lots of pull, and rolling. i might consider welding extra metal on to give me a little more flare. any thoughts or adivce? yes i know this is stupid and going to cost $$$ thanks, kyle |
#22 | |
#Belieber
#23 |
Member#: 248479
RMIC
i think they offer +33 offset as well. but id have to double check.
#24 | |
Member#: 97135
NWIC
I take that back. You MIGHT be able to fit the +33's, but thats only if you stretch a 225/45 or 235/35 on those wheels and 3.5*+ of camber. This also means roll + pull all around. The widest people seem to fit within stock fenders is 11", 12" is already pushing it depending on offset and tire. Last edited by sc00by4life; 07-18-2011 at 05:55 AM. |
#25 |
Member#: 287879
Vehicle:2011 Wrx Sti SWP |
Ok so i just got the car. I seen this thread http://forums.nasioc.com/forums/show....php?t=2138259 and i love that setup but id like a lil more tire for these damn potholes out here.
I wanna run the Miro stp-1's. 18x10 +25 I ordered BC BR coilovers already, im just trying to figure out what tire size i need and do i need spacers to clear the brembos? i would like to avoid pulling and rolling the fenders but if i have to i can get it rolled. I dont mind camber also as i will only have this setup just for the summer. Help is much appreciated. |
| Thread Tools | |
| Display Modes | |
| the motorsport fitment thread: because race car! | nhat | Tire & Wheel | 45 | 11-20-2011 03:21 PM |
| the official wheel/tire fitment thread: all fitment questions go here! | nhat | Tire & Wheel | 1086 | 06-15-2011 01:02 AM |
| where did the wheel fitment chart go? | PoopRSkupe | Brakes, Steering & Suspension | 0 | 01-26-2004 01:36 PM |
| A thread in the STi forum to keep it alive (because STi forum is closing) | Eric SS | Off-Topic | 6 | 09-10-2003 03:54 PM |
