Old 11-11-2011, 09:09 AM   #251
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Well it depends on what you want out of the car. There are better options available if you're more for performance and have a little bit of $ to spend. You will need to replace/rebuild your stock struts with the mileage you likely have on the car if you want to drop it.
Byzantium is offline   Reply With Quote
Old 11-11-2011, 09:11 AM   #252
niceaznwrxguy
Member#: 259193
007 Swagon
Red
Well I did see bc coilovers but they are kinda expensive and if I were to get a set of springs and shocks...wouldn't it come out to the same price?
niceaznwrxguy is offline   Reply With Quote
Old 11-11-2011, 09:14 AM   #253
Byzantium
Member#: 207826
85k 2002 WRX
BCs are junk. As are most cheap coilovers.
Old 11-11-2011, 09:25 AM   #254
niceaznwrxguy
Member#: 259193
007 Swagon
Red
Wow..it seems like most of the coilovers under a grand arent good. I was wondering if u can post your wheel and tire and suspension specs if you could thanks.
Old 11-11-2011, 10:45 AM   #255
Byzantium
Member#: 207826
85k 2002 WRX
I'm a function > form minion. You'd be disappointed.
Suspension is Tokico D-Specs w/ Swift Spec R springs. Wheels, I own 4 sets.
Old 11-11-2011, 01:40 PM   #256
niceaznwrxguy
Member#: 259193
007 Swagon
Red
Yeah I dont think they make d specs for my car lol
Old 11-11-2011, 01:49 PM   #257
Byzantium
Member#: 207826
85k 2002 WRX
There are still some pretty good options, like Feal re-valves.
http://www.dirtyimpreza.com/forums/s...ad.php?t=15223
Old 11-11-2011, 05:46 PM   #258
niceaznwrxguy
Member#: 259193
007 Swagon
Red
Would a 17 x 9 with a 35mm offset work and not look stupid?
Old 11-11-2011, 11:33 PM   #259
99LIGHTNING
Member#: 278039
2007 Subaru WRX STI
Rally Blue
Default Eibach Pro Kit Springs
I have a 07 STI. Sway bars upgraded. Running some 11 STI Limited Spec C wheels with a 55 offset. Can I put on a set of Eibach Pro Kit Springs and have no fitment issues. 235/40/18 is what I run for tires. I auto cross this and would like to lower it a little. Thanks for your time.
99LIGHTNING is offline   Reply With Quote
Old 11-12-2011, 11:28 AM   #260
littlewhitewagon
Member#: 103068
11 STI sedan
Suspension techniques coilovers are as close as you can get to a good coilover without spending more than about a grand.
17x9+35 with decent alignment with 245/40r17 tires is doable without being stupid. 235/40 if you want a little more margin for clearance.
littlewhitewagon is offline   Reply With Quote
Old 11-12-2011, 11:50 AM   #261
niceaznwrxguy
Member#: 259193
007 Swagon
Red
what do u think of 18 x 8.75
Old 11-12-2011, 12:46 PM   #262
Byzantium
Member#: 207826
85k 2002 WRX
I recommend NOT getting XXRs.
Old 11-12-2011, 09:49 PM   #263
SubbyPimp
Member#: 79952
1999 RS/ 2004 WRX
WRB/ JBP
year: 1999
model: 2.5rs
wheel model: Work Emotion 11R
wheel size/offset: 18X9.5 +30
tire brand/model: Direzza DZ101
tire size: 265/35/18
suspension: Ohlins Coilovers
alignment: 2.0 fr/ 1.5 rr
fender mods: mega pull
spacers: No
SubbyPimp is offline   Reply With Quote
Old 11-13-2011, 12:10 AM   #264
mrchyes
Member#: 294069
98 Forester
Green
amazing secks is above me.
you have been PM'd sir
mrchyes is offline   Reply With Quote
Old 11-13-2011, 12:56 AM   #265
99LIGHTNING
Member#: 278039
2007 Subaru WRX STI
Rally Blue
Default Anyone have a answer for my previous post?
2007 STI
Sways bars upgraded
2011 STI SPEC Wheels 18 by 8.5 with 40 series 235mm with tires. 55 offset.
Can I put some Eibach springs one with out any fitment problems?
Old 11-14-2011, 04:59 PM   #266
Munoka
Member#: 277982
2010 STI hatchback
Default rota grid 18x9.5 et30...
I have a 2010 STI and i just bought a set of Rota Grid 18x9.5 et30's... I test fit them on my car today to find out that they do not clear my brembros in the front... It touches them by just a hair... How do I make these wheels fit? 5mm spacer? Does anybody run 18x9.5 et30 on a 2008+ STI?
Munoka is offline   Reply With Quote
Old 11-14-2011, 07:55 PM   #267
littlewhitewagon
Member#: 103068
11 STI sedan
Width is not the problem. Your offset selection makes it just that much off. I agree on no XXR.
Old 11-15-2011, 01:15 AM   #268
niceaznwrxguy
Member#: 259193
007 Swagon
Red
What do y'all think of prodrive gt 1 in 18 x 8.5 5 x 114.3 with 53mm offset? Debating if I should save for these on my 05 sti and will I have to do anything to make it fit?
Old 11-16-2011, 02:56 AM   #269
littlewhitewagon
Member#: 103068
11 STI sedan
Fits like stock.
Old 11-20-2011, 11:39 PM   #270
craze191st
Member#: 297642
2011 STi
PBP
Originally Posted by sc00by4life View Post
its already posted...learn to read...
can't believe i kept missing that post, sorry about that
craze191st is offline   Reply With Quote
Old 11-21-2011, 10:18 PM   #271
bugeyemat
Member#: 299938
quick question; i found a set of 17" rims. tire size is 205/45/17r on all 4rims. two rims are 8.5" the other two are 9.5" i dont plan on doing over 65, or beating on it. my diffs should be fine right? Think about when you take a turn each tire is moving at a different speed because the inner tires turn faster then the outer.
bugeyemat is offline   Reply With Quote
Old 11-22-2011, 04:28 AM   #272
sc00by4life
Member#: 97135
No, you won't be fine. You'll fry your center diff very fast. And there is no benefit to staggered setups on our cars in the first place.
Old 11-22-2011, 10:40 AM   #273
littlewhitewagon
Member#: 103068
11 STI sedan
I would argue on a purpose built car, reverse stagger would have benefit simply because more width fits in front than the rear. Especially true since there are bolt on wide front fenders. But the normal people who need to ask need not apply.
Old 11-22-2011, 10:52 AM   #274
Byzantium
Member#: 207826
85k 2002 WRX
205/45/17s on 8.5" and 9.5", because race car!
Old 11-22-2011, 04:00 PM   #275
sc00by4life
Member#: 97135
Most awd time attack cars will stagger offsets, not wheel width. A lower offset in front dramatically helps turn-in, and reduces understeer.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 04:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 02:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 02:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 04:54 PM
