Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 07-23-2013, 05:15 PM   #2801
sc00by4life
Member#: 97135
Originally Posted by ZenkiS14 View Post
Good enough for me, I'll be ordering the 245/40 tires then!
17x9 +42 245/40 RE01R. Rolled rears, that's it.
Old 07-23-2013, 10:08 PM   #2802
BigTaco425
Member#: 347237
2013 WRX Limited E85
Satin Black Vinyl
Not sure if I posted mine here
18x8 235/40
BigTaco425 is offline   Reply With Quote
Old 07-23-2013, 11:52 PM   #2803
DARTH MAGNUS
Member#: 285248
2014 PBP GR WRX
2006 STi - SOLD :(
^specs, please.
DARTH MAGNUS is offline   Reply With Quote
Old 07-24-2013, 01:36 PM   #2804
Chuckls
Member#: 280696
2005 WRX
Ok wheel gurus, assist me in my quest for wagon greatness:
year:03
model:Impreza TS wagon
wheel model: Undecided
wheel size/offset: Undecided. I need help.
tire brand/model:N/A
tire size: Undecided. I need help.
suspension: ST coilovers
fender mods:Not opposed to rolling
What I'll be using my car for:
DD with AutoX mixed in.
What would be the best way to make use of my wagon's narrow rear end? 17's are what I'm looking at.
Chuckls is offline   Reply With Quote
Old 07-24-2013, 01:52 PM   #2805
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
year:03
Maybe some 17x8 or 9 and you want to keep the offset as close to 45 as possible. I've actually never set up a wagon, but have read a lot on the wagons. I think your best bet will be around 17x8 et45. Or a 17x9 et 45 with a 245/40
dburgoon is offline   Reply With Quote
Old 07-24-2013, 02:21 PM   #2806
Ikbrown92x
Member#: 329706
Damn! Good looking wagon! Any more pics?
Ikbrown92x is offline   Reply With Quote
Old 07-24-2013, 02:35 PM   #2807
sc00by4life
Member#: 97135
not my car. but there are more on wheeldude's website.
Old 07-24-2013, 03:31 PM   #2808
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
A lot is going to depend on ride height and suspension travel. You should be able to run a 17x8 or 8.5 in the +45 range with a 245 tire without much trouble. If you are willing to run some negative camber (maybe -1.5*, which would actually be beneficial in auto-x anyway) and roll the rear fenders, you can probably up to a 17x9 +42-45 with a 245 or 255. Oakos has RPF1s in 17x8 and 9 +45 available in a couple color options.
flat4LGT is offline   Reply With Quote
Old 07-24-2013, 04:53 PM   #2809
Chuckls
Member#: 280696
2005 WRX
I have no problem doing rear camber. I'll just grab some rear camber plates.
Old 07-24-2013, 06:23 PM   #2810
Aarron_M
Member#: 68210
2013 STI
year: 2013
model:5dr STI
wheel model: Volk TE37
wheel size/offset:18x10/+40
tire brand/model:
tire size:265/35/18
suspension: RCE Yellows
fender mods:none
spacers: no
Will I have issues with inner rubbing? I'm not against rolling or pulling, just wondering if I'm gonna need spacers before I pull the trigger. Thanks.
Aarron_M is offline   Reply With Quote
Old 07-26-2013, 02:55 PM   #2811
snowboarder2587
Member#: 322407
2012 WRX Limited
Plasma Blue Pearl
year: 2012
model:WRX sedan
wheel model: TSW Doninton
wheel size/offset:19x8/+32
tire brand/model:
tire size:235/35/19
suspension: RCE Blacks
fender mods:none
spacers: no
Hey guys, I already have these wheels and did a test fit. They basically were scrubing the second I sat in the car. My questions is if fender rolling will give me enough clearance? Most people I know that rolled their fenders only scrubbed on bumps so I'm not sure if fender rolling will help. The tires are (2) toyo proxes 4 and (2) Goodyear eagle gt. The OD's are within 1% off each other but I believe the eagle gt is wider (even though both have the same tire size). Thanks for you help!!
snowboarder2587 is online now   Reply With Quote
Old 07-26-2013, 03:34 PM   #2812
kozak
Member#: 262871
2003 WRX
Primer
year: 2003
model:WRX sedan
wheel model: Kosei K1 TS
wheel size/offset: 17x8/+45
tire size:235/40/17
suspension: DMS 50mm Tarmac valving
fender mods: pulled fronts.
spacers: UNKNOWN
The mystery here is: will I require spacers to make this fit/work?
kozak is offline   Reply With Quote
Old 07-27-2013, 12:23 AM   #2813
JJ527
Member#: 312462
2004 WRX
Deleted.
JJ527 is offline   Reply With Quote
Old 07-30-2013, 12:11 AM   #2814
CanadianSTiEh
Member#: 363584
13 STi
year: 2013
model: STi
wheel model: Advan RSII
wheel size/offset: 18X9.5/et45
tire brand/model: stock dunlops
tire size: 245/40/18
suspension: stock struts with swift springs
alignment: pending
fender mods: rolled rears
spacers: none
CanadianSTiEh is offline   Reply With Quote
Old 07-31-2013, 04:43 PM   #2815
matigas_TT
Member#: 322775
2012 WRX-4Dr
Need some help guys.
I have a 18x8.5 +48 that I'll be putting in my 2012 wrx
I'm trying to get some opinions. What tire looks better with just the OEM Suspension ?
245/40 or 255/35 ? Will any of this reduce my wheel gap ?
Pictures will really help or any comments
matigas_TT is online now   Reply With Quote
Old 07-31-2013, 09:36 PM   #2816
wukelich
Member#: 363961
Default new guy help
Hey guys I have a 04 wrx with 18 xxr +20 on the offset with 225 40 18 nittos my @ is I'm rubbing in the rear even after a fender pull do I need camber bolts ?? I am lowered with springs
wukelich is offline   Reply With Quote
Old 07-31-2013, 11:42 PM   #2817
rocklizzard91
Member#: 226287
year: 2002
model: WRX sedan
wheel model: RPF1
wheel size/offset:17x9 +45
tire brand/model: undecided
tire size: 255/40/17
suspension: fortune auto 500 w/ swift springs
fender mods: none yet, open to rolling
spacers: open to spacers
Im curious as to whether or not this will rub? Im not sure if ill have clearance between the tire and the suspension, can anyone verify if I will? Or will I need a spacer? Will I need more than a roll to fit these? Im not looking to slam the car, more of a DD/occasional auto-x car.
Will going to these wheels make it feel like a dog? Im rolling on stock wheels and oem size tires right now
rocklizzard91 is offline   Reply With Quote
Old 08-05-2013, 06:31 PM   #2818
ZenkiS14
Member#: 274029
1997 Nissan S14
Pics for reference of later people who ask.
year: 2006
model: WRX TR Sedan
wheel model: Rota RT-5R
wheel size/offset:17x9 +42
tire brand/model: Falken Ziex 612
tire size: 245/40/17
suspension: bone stock...for now
fender mods: rears rolled, but not needed at this height
spacers: none
Specs:
Pics installed:
Front fender flush:
Turned out pretty good! Thanks for the help on fitment questions guys, could actually have run a much more aggressive offset in the rear. Going to lower it 1.5" or so in the spring probably.
ZenkiS14 is offline   Reply With Quote
Old 08-05-2013, 11:06 PM   #2819
Ampliified
Member#: 328243
2012 Impreza WRX
year: 2012
model: WRX
wheel model: XXR 531
wheel size/offset: 18x8.5 +35
tire size: 255/40/18
suspension: Eibach Pro-kit
alignment: Stock for now
fender mods: Will roll if necessary
Spacers: Will I need them?
I read through a dozen pages of this thread and many others looking for someone else with a similar set up to find none so will this fit my car or will I have to go for a thinner tire or wider wheel because the next size up is 18x9.5 +35 trying to figure out what all the offset numbers mean because I am a wheel noob preciate any help I can get really need new wheels ASAP!
Ampliified is offline   Reply With Quote
Old 08-05-2013, 11:50 PM   #2820
TWlSFM
Member#: 286220
2011 WRX SWP
1991 Ford Ranger v6
year: 2011
model: WRX
wheel model: Work XD9's
wheel size/offset: 18x10 +18
tire brand/model: Yokohama S Drives
tire size: 225/35/18
suspension: BC BR Coilovers - Slammed
alignment: -1.5 in the front and - 2.5 in the rear
fender mods: rolled fenders all around
spacers: none
TWlSFM is offline   Reply With Quote
Old 08-06-2013, 09:13 AM   #2821
scoobydo2.0
Member#: 261290
2004 WRX
year: 2004
model: WRX
wheel model: Rota Grid
wheel size/offset: 17x9 +42
tire brand/model: Undecided
tire size: 245/40/17 or 235/40/17
suspension: KYB AGX w/ Prodrive Blues & Cusco lateral links
alignment: Unsure
fender mods: Willing to roll, maybe pull
spacers: none (have 3MM if necessary)
Please let me know alignment specs and if my tire choice is gonna work, thanks
scoobydo2.0 is offline   Reply With Quote
Old 08-06-2013, 09:44 AM   #2822
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
^^ yes it will work. Shouldn't need too much camber but you will need a decent roll
Old 08-06-2013, 10:08 AM   #2823
joncrook
Member#: 340905
2013 WRX Limited
year: 2013 wagon
model: WRX
wheel model: Cosmis xt-005r
wheel size/offset: 18x9 +25
suspension: purchasing BC coilovers
alignment: Unsure
spacers: none
Needing some guidance on tires size that will fit. Trying to do an 1 1/2 drop but not sure yet. I feel like I will need 225/30 or 235/30 tire. Any guidance would be greatly appreciated. Thanks in advance!
joncrook is offline   Reply With Quote
Old 08-06-2013, 07:40 PM   #2824
ZenkiS14
Member#: 274029
1997 Nissan S14
Originally Posted by scoobydo2.0 View Post
year: 2004
model: WRX
alignment: Unsure
See my post above. I just installed that exact size and offset. Wont need any camber really, stock spec will be fine, and might need to roll fenders depending on height.
Old 08-06-2013, 07:52 PM   #2825
snowboarder2587
Member#: 322407
2012 WRX Limited
Plasma Blue Pearl
Originally Posted by snowboarder2587 View Post
year: 2012
model:WRX sedan
tire brand/model:
tire size:235/35/19
fender mods:none
spacers: no
Little help guys? Thanks
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
