Old 12-12-2011, 07:24 AM   #301
cmiller219
Member#: 187179
5 Golden
Rings
lol yeah i read that. i was just wondering more about the size of the tire i chose.
cmiller219 is offline   Reply With Quote
Old 12-12-2011, 10:58 PM   #302
Neff 11 2.5i
Member#: 277410
11' 2.5i Wagon
Yo Jourdan, what's the drop on your hoopty? I'm rocking the same ride and looking for what you have as far as wheel gap.
Hit me back!
Neff 11 2.5i is offline   Reply With Quote
Old 12-12-2011, 11:43 PM   #303
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Me?
IDK, 2-3 inches. Ground to top of the fender is something like 24" in the front and 25" in the rear.
JourdanWithaU is offline   Reply With Quote
Old 12-19-2011, 11:37 PM   #304
BraveSTi
Member#: 262030
I got a question.. I'm currently running PF01's 18 x 8.5 et48 on an 11 STi with no issues. I'm interested in the RCT4's..
Will the 18 x 9 et43 RCT4's clear the stock Brembos and will it be necessary to roll/modify the fenders at all(if I install coils, springs etc)?
BraveSTi is offline   Reply With Quote
Old 12-20-2011, 12:14 AM   #305
sc00by4life
Member#: 97135
not sure if they clear brembos (pretty sure they will though). And no, you probably won't need to roll.
Old 12-20-2011, 10:27 AM   #306
JerseyKid
Member#: 135901
2011 WRX
Satin White Pearl
year: 2011
model: WRX Sedan Base
wheel model: Rota D-Force
wheel size/offset: 18x9.5 +40
tire brand/model: ContiProContact
tire size: 245/40/18
suspension: BC Coils
alignment: -1.5 front -2.2 rear
fender mods: rolled in rear
spacers: yes/no? size? none.
JerseyKid is offline   Reply With Quote
Old 01-01-2012, 11:10 PM   #307
mrchyes
Member#: 294069
04 Impreza RS
year: 2004
model: 2.5 RS Impreza
wheel model: Rota Grid
wheel size/offset: 17X9 +35mm
tire brand/model: Suggestions?
tire size: 245/40/17
suspension: KYB GR-2 struts with eibach lowering springs
alignment: suggestions
fender mods: would like to not have to
spacers: yes/no? size? N/A
mrchyes is online now   Reply With Quote
Old 01-01-2012, 11:43 PM   #308
sc00by4life
Member#: 97135
Originally Posted by mrchyes
year: 2004
Roll, pull depending on ride height. Even more so if it's a wagon.
Old 01-02-2012, 12:48 AM   #309
BlackSTi05x
Member#: 233560
2005 STI
fitment help please
year: 2005
model: STi
wheel model: XXR 527
wheel size/offset: 17X8.25 +35mm
tire size: best fit/widest?
suspension: BC racing coilovers, lowered amount approx 2" lower then stock
fender mods: ideally, would like to not have to
thanks
BlackSTi05x is offline   Reply With Quote
Old 01-02-2012, 12:54 AM   #310
sc00by4life
Member#: 97135
you'll need fender mods with a 17x8 +35 unless you are running <225's.
Old 01-02-2012, 12:59 AM   #311
BlackSTi05x
Member#: 233560
2005 STI
so transferring my tires from stock rims over wont work without some fender adjusting?
Old 01-02-2012, 01:09 AM   #312
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Strictly speaking, those wheels are massive downgrades from your stock ones.
Byzantium is offline   Reply With Quote
Old 01-03-2012, 10:00 AM   #313
mrchyes
Member#: 294069
04 Impreza RS
I am still wondering how much roll and pull and where i will need it with a 17X9 +35 offset rota grid with 235/40/r17 dunlops on there...they are extreme performance summer tires so they arent very beefy at all.
also, honestly...i have no idea how to roll or pull fenders...
Old 01-03-2012, 10:01 AM   #314
mrchyes
Member#: 294069
04 Impreza RS
Old 01-03-2012, 01:31 PM   #315
h1gh
Member#: 283363
07 STi
need some help
how will a 17x9 +38 drag dr-31 do on my car? thinking of 245/45/17
car: 07 wrx
mods: bc racing coilovers dropped, rear sway bar
will i need a camber kit in the back?
will i need to roll all around?
h1gh is offline   Reply With Quote
Old 01-04-2012, 04:26 AM   #316
sc00by4life
Member#: 97135
Originally Posted by h1gh
need some help
car: 07 wrx
Yes to both. You might need a slight pull in the rear depending on height.
You should do a 245/40 though. Your gearing will thank you.
Old 01-04-2012, 11:19 PM   #317
icantdotreflips
Member#: 288896
2007 STI
I am trying to set this up, but I just want to make sure this will flow together. Before I write out the items I just want to say... I want this setup to benefit the handling of the car(obviously), I do not want to roll the fenders but i guess I am open to it, and I am unsure if I will need a camber kit after it is all said and done.
year: 2007
model: STI
wheel model:Enkei RPF1s
wheel size/offset: 17x9, offset would be some where around +35 I guess.
tire brand/model: Open to suggestions, but I would like hankook..
tire size: I want a small stretch but nothing drastic.
suspension: ISC coilover kit. Not on yet, but I am planning to drop at least 1.5 in front and 1 in the back.
alignment: I need help....
fender mods: Hope to have none if possible....
spacers: yes/no? size? No spacers
Hopefully this is an educated question. I just don't know where else to turn.
Thanks guys!
icantdotreflips is offline   Reply With Quote
Old 01-05-2012, 12:16 PM   #318
krisdeezy
Member#: 250246
18x9.5 +15 Enkei Nt03 +m 215/35/18
krisdeezy is offline   Reply With Quote
Old 01-07-2012, 12:30 PM   #319
Wirtz
Member#: 286408
2005 P&L Tuned STi
WFC #952
year: 2005
model: STi
wheel model:Varrstoen 2.2.0
wheel size/offset: 17x9.5, offset choices either +12 or +30 OR 17x9 +12
tire brand/model: I have 215/45/17s at home. Forget what they are lol.
tire size: I want a stretch I know they'll fit the 9j better but I know with 45 series 215 on 9.5j is easy amongst most
suspension: BC Racing BR 8k/6k
alignment: I figure max out the front coil alignment roughly and add my camber bolts in rear?
fender mods: I assume I can get away with just a close roll on every fender?
spacers: I assume no for the +12's. If I need for the +30 I'll just rock the 9j +12
Just wondering if I'm in the right ballpark on fender work. I'm up for some camber and I like riding fairly low so no fear there.
Wirtz is offline   Reply With Quote
Old 01-07-2012, 02:03 PM   #320
sc00by4life
Member#: 97135
hahahahahaha.
close roll? nah dude even with super stretch you'll need to at least pull the rear.
Old 01-07-2012, 02:45 PM   #321
Wirtz
Member#: 286408
2005 P&L Tuned STi
WFC #952
Originally Posted by sc00by4life View Post
hahahahahaha.
Alright thanks. I guess I'll need a pulls but I can live with that
Old 01-07-2012, 03:11 PM   #322
sc00by4life
Member#: 97135
you can do it :P.
Old 01-09-2012, 02:15 AM   #323
Wanna Be Sti
Member#: 267981
02 Wrx
year: 2002
model: WRX
wheel model:Rota Torque
wheel size/offset: 18x9.5+35
tire brand/model: 235/40/r18 Falken fk452
suspension: Would it work on stock until i can afford Bc?
Please let me know if this fitment would work without too many supporting mods! or input thanks
Wanna Be Sti is offline   Reply With Quote
Old 01-09-2012, 04:09 PM   #324
gometang
Member#: 32142
'05 STi
Blk
Will 265/35/18 fit on 18x9 +50 for an '05 sti? I currently have 245/35/18s and there are times where the bottom of my rim's lip gets scratched on trackdays on certain turns. I am looking for some more sidewall so it will be less prone to do that. I am pretty sure 255/35/18 will be fine, but hoping for some more tire.
gometang is offline   Reply With Quote
Old 01-10-2012, 06:00 PM   #325
ABeastinWRX
Member#: 239469
2004 WRX
PSM for now ;)
year: 2004
model: wrx sedan
wheel model: Enkei RP02
wheel size/offset: 17x7.5 +48
tire brand/model: Falken Ziex
tire size: 215/45/17
suspension:Eibach Pro Lowering Springs
alignment:stock
fender mods: stock
spacers: no (but will they help?)
Is there a way I could get these wheels to be more flush with the fenders by just using spacers?
This is my winter setup and I am looking into new wheels and tires for the summer and want to learn the game of flushness but do not want to sacrafice too much function for my car is a stage 3.
ABeastinWRX is offline   Reply With Quote
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
Message Board Statistics All times are GMT -4. The time now is 08:21 AM.
