Old 04-25-2014, 12:41 PM   #3901
ATchrispeck
Member#: 377823
2014 wrx 4 door
DGM.
18x7.5
48mms offset
6.06 backpacking
Enkei nt03-m
Open to tire size 235/40/18
Stock height would I be good to go?
Wider tire fit?
Thank you
ATchrispeck is offline   Reply With Quote
Old 04-25-2014, 01:44 PM   #3902
sc00by4life
Member#: 97135
Originally Posted by ATchrispeck View Post
18x7.5 48mms offset 6.06 backpacking Enkei nt03-m Open to tire size 235/40/18 Stock height would I be good to go? Wider tire fit? Thank you
I wouldn't buy a 7.5" wheel.
I wouldn't run any wider than a 225 on that wheel.
Old 04-25-2014, 03:42 PM   #3903
ATchrispeck
Member#: 377823
2014 wrx 4 door
DGM.
Hmm ok thanks for the inputs sc00b
Old 04-25-2014, 04:47 PM   #3904
Cobbzzor
Member#: 274244
2004 STi
Car: 2004 WRX STI Stock Suspension & Alignment
Wheels: XXR 522 18x8.5 +48
Tires: That's the question, 225/40 or 235/40
I have been checking around and get different answers from different vendors as to what is "recommended" for this setup. Half say the 225 while the other half say 235. I believe and have read that the 235 would be the better route, but will they fit correctly without any rubbing/modifications?
Cobbzzor is offline   Reply With Quote
Old 04-26-2014, 03:48 PM   #3905
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
year: 05
model: Sti
wheel model: Nt03+m
wheel size/offset:17x9.5 et38
tire brand/model: Re-11
tire size: 255/40r17
suspension: Feals 441 7k/5k 14" front/13.75" rear
alignment: Current -1.5 front -1.9 rear. Prob will be moved nearer to -2.0 f when I get nt03s
fender mods: None
spacers: none
Just curious what I am looking forward to in the fender rolling/puling department? I might be wong but perhaps just rear roll? Is it best to just cut them and go from there? Thanks.
Blingstrom is offline   Reply With Quote
Old 04-26-2014, 09:58 PM   #3906
subbielov3r32
Member#: 341281
model: widebody gc
suspension: bc coilovers
tire: 255/40r18
wheel: 18x9.75 5x100. XXR 527
will this work properly?
subbielov3r32 is offline   Reply With Quote
Old 04-26-2014, 10:11 PM   #3907
sc00by4life
Member#: 97135
Originally Posted by subbielov3r32 View Post
widebody gc bc coilovers 255/40/18 18x9.75 5x100. will this work properly? any pulls or rolls?
No one will be able to tell you. We don't know what kit you have, let alone wha fitments will work.
But you can do better than BC's and XXR's.
And you typically can't roll or pull a wide body.....
Old 04-26-2014, 11:09 PM   #3908
subbielov3r32
Member#: 341281
22b widebody kit. i need to know if the wheel and tire will fit properly and would there be any rubbing on the coilovers. for now im going with bc's and xxr's. im new to the wheel fitment thread. still learning
Old 04-27-2014, 11:11 AM   #3909
sc00by4life
Member#: 97135
You'll probably have better luck in rs25 or browsing through members car gallery. There are a few wide body Gc's in there.
You don't have to buy sub par parts because you're "new". Spend the money once.
Old 04-28-2014, 06:53 PM   #3910
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
Car: 2010 WRX Sedan
Suspension: Stock
Wheels: 17x9 RPF1
Tires: 255/40/17
Offset: That's the question, I want a flush look.
I've seen 11+ sedans and hatches run this setup with no problems at stock ride height. I would like to do the same. I can't decide between +45 or +42 offset. If someone has pictures on a 08-10 sedan it would be AWESOME!
I'm about to pull the trigger on a new set of wheels and tires any day now.
The1SloR/T is offline   Reply With Quote
Old 04-28-2014, 09:45 PM   #3911
WrxHATCH8
Member#: 383003
2009 WRX HATCHBACK
Originally Posted by Coltonwrx View Post
year: 2010
model: WRX
wheel model: Miro stp1
wheel size/offset:18x10 +30
tire brand/model: kumho ecsta somethins
tire size: 225/40
suspension: bc br coilovers
alignment: -4 front. -3-3.5 rear
fender mods: rolled/pulled a little
spacers: yes/no? size? No
Love this look!! I have a white 09 Wrx hatch and wasn't sure if I'd like how these wheels would look but I love it! I also have bc br coils how low are you in these pics? I would be looking to go lower if possible.
WrxHATCH8 is offline   Reply With Quote
Old 04-28-2014, 10:17 PM   #3912
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Originally Posted by The1SloR/T View Post
Car: 2010 WRX Sedan
Suspension: Stock
Wheels: 17x9 RPF1
Tires: 255/40/17
3mm isn't going to really make any difference.
You are prepared to roll your fenders, yes?
And I'm not certain by any means, but you may be getting pretty close to strut or the inner rear fender liner with that setup.
P.S. Car will be a bit 'off' looking with that wheel/tire setup on stock suspension, IMO.
Breezio is offline   Reply With Quote
Old 04-28-2014, 11:04 PM   #3913
BSHUNTER
Member#: 290877
2013 WRX STI SEDAN
Year: 2013
Model: sti 4door
Wheels: enkei Rpf1's
Wheel size/offset: 18x9.5 + ?? (Need help on the offset)
Tires: the stock 245/40 r18's currently on the car
Suspension: stock for now
Alignment:n/a
Fenders: willing to roll
Spacer: do not want
My question is, what's a good offset to clear the sti brembo's without sacrificing performance/maintaining the best performance, steering feel ect. My main concern is performance over looks. That being said, do I need to go with a more narrow wheel than 18 x 9.5? Thanks for the advice!
Edit. Looking at a set of 18x9+35. This seems like a happy medium if I understand this offset business. Anyone have any input for me?
BSHUNTER is offline   Reply With Quote
Old 04-30-2014, 11:49 AM   #3914
dirtcollector
Member#: 357347
2005 wrx sti
aspen white
2005 sti
17x9 +22
sumitomo htr p01 215-50-17 91w
Stock suspension as of now will be switching to koni struts with rce yellows
I want to know if I can make this work using the stock camber by just rolling and pulling or would I need camber bolts ect...
Also I know these tires are a bit big don't plan on keeping this size what would be an ideal size for my setup.
My wheels poke a Tad and want to make it flush without going to crazy with the camber.
dirtcollector is offline   Reply With Quote
Old 04-30-2014, 03:51 PM   #3915
44rex
Member#: 238820
13 wrx hatchyyy
ISM
44rex is offline   Reply With Quote
Old 04-30-2014, 04:11 PM   #3916
bassler
Member#: 167544
'12 DGM STi sedan
'14 Audi S6, '16 XC90
Originally Posted by 44rex View Post
2013 wrx hatch
im trying to see if i can fit this settup.
wheels: work cr ultimate
size: 18x10.5 et 15
tire: 225/40/18
suspension:bc br extreme lows, gt spec rear camber arms, and cusco rear trailing arms
fenders: rolled
Curious on how negative my camber will need to be, to fit this setup
something tells me if you're contemplating this set up you already know what the answer will be. it's a complete guess but i'd think something like -5 would be the starting point plus you'll likely need adjustable rear upper control arm bushings. the tire model choice and corresponding stretch will be a variable. trial and error unless you can find someone with a similar set up but i dont think you'll find much like that on here. good luck
bassler is online now   Reply With Quote
Old 04-30-2014, 04:25 PM   #3917
sc00by4life
Member#: 97135
2013 wrx hatch im trying to see if i can fit this settup. wheels: work cr ultimate size: 18x10.5 et 15 tire: 225/40/18 suspension:bc br extreme lows, gt spec rear camber arms, and cusco rear trailing arms fenders: rolled Curious on how negative my camber will need to be, to fit this setup
This is not for newbies to fitment.
Old 05-03-2014, 02:34 PM   #3918
Matt515
Member#: 241492
2006 Forester, RBP
Tuned by M@ at WI!
Anyone have work xt7's forsale?
Matt515 is offline   Reply With Quote
Old 05-03-2014, 02:50 PM   #3919
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Maybe in the classifieds, you know, where people buy and sell stuff
Counterfit is offline   Reply With Quote
Old 05-03-2014, 03:11 PM   #3920
Matt515
Member#: 241492
2006 Forester, RBP
Tuned by M@ at WI!
Oh really? I never thought of that.
Old 05-03-2014, 07:29 PM   #3921
sc00by4life
Member#: 97135
Well this wouldn't be the place to find them.
Old 05-03-2014, 09:10 PM   #3922
Counterfit
Member#: 124254
"The Scoobinator"
Clearly
Old 05-04-2014, 03:41 PM   #3923
Ambition07sti
Member#: 367605
Test fit my wheels and bought 235/40 18 tires. Wheels are 18x9.5 +38
http://flic.kr/p/nd7bhm
http://flic.kr/p/nuCFeN
http://flic.kr/p/nsy54Q
Ambition07sti is offline   Reply With Quote
Old 05-04-2014, 09:33 PM   #3924
bmac67
Member#: 189337
2006 WRX
SGM
year: 2006
model: WRX
wheel model: Rota G-Force
wheel size/offset: 18x9 +35
tire brand/model: Mich Pilot Super Sports
tire size: 235/40/18
suspension: Eibach Lowering Springs
alignment: -1.5 Front -2.6 rear
fender mods: Rolled
spacers: yes/no? size? None
These are rubbing in back over hard bumps, not looking to pull rears. If I went with a 18x8.5 +48 same tire would I be any better off? If not what size can I run with this tire?
Thanks guys!
bmac67 is offline   Reply With Quote
Old 05-04-2014, 09:37 PM   #3925
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
I'm surprised that's rubbing. But and 18x8.5 +48 shouldn't be a problem.
flat4LGT is offline   Reply With Quote
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
