Old 07-22-2011, 04:59 PM   #51
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
Originally Posted by sc00by4life View Post
i'm pretty sure miro's in that size require at least a 10mm spacer to clear brembos......
i know im hellaslow is only running 5mm up front on his with brembos
under0athh51189 is offline   Reply With Quote
Old 07-23-2011, 10:39 PM   #52
xXTheBossXx
Member#: 287907
Default 18x9.5 e20 with 235.40r18 on wrx?
Hi i am trying to find out what is the best choice. i love concave i love some poke and i love some camber. what do you guys think of this set up?
18x9.5 et20 235/40r18 tire?
Rota grids from wheel dude..
any other places to get a better deals?
any other sugestions?
modifications? o slam it i have to roll fenders im guessing but if i ut them on stock suspension while waiting for my coil overs will they work? is there anyting i shold know before diving into this wheel
xXTheBossXx is offline   Reply With Quote
Old 07-23-2011, 11:06 PM   #53
under0athh51189
Member#: 193959
2001 Lexus IS300
it should look pretty decent. i would go with a 225/40/18 tire but if you want some more meat than just get the 235's. and yes wheel dude is the best deal unless you want to buy them used.
as far as mods go i would get coilovers first or youll regret them not fitting and rubbing like crazy. get some bc coils and then get the wheels. as far as fender mods if you want to go slammed you will need all 4 fenders rolled and rears slightly pulled. also youll probably have to pull you front fender liners and tuck your wiring harness. i had to do all this plus use a torch and hammer to smash in my front fender wells to make my 18x10 +25 fit on my wrx and im running 225/40 tires with -3.5 front camber and -4.5 rear. but im also maxed out on how low i am.
Old 07-23-2011, 11:25 PM   #54
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Would u post a pic please?
07wrx84 is offline   Reply With Quote
Old 07-23-2011, 11:27 PM   #55
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Ya I would get 225's fit better lol
Old 07-24-2011, 01:28 AM   #56
sc00by4life
Member#: 97135
225 would fit better (like those guys said).
you shouldn't need obscene amounts of camber.
Old 07-24-2011, 01:29 AM   #57
sc00by4life
Member#: 97135
i thought dfunk needed 10mm's....not sure.
my varrstoens required 10mm to clear up front and have a similarly concaved face (almost flat lol).
Old 07-24-2011, 02:52 AM   #58
What v8
Member#: 254718
ok so i want to slam my car on some rims that are 18x9 +35, right now im stock suspension and fenders, what kinds of mods would i need to run this, what kind of camber, and i dont want to pull my fenders but i am willing to roll em. also what size tire should i run? any help will be appreciated as i am a noob to hellaflushnessssssssss lol.
What v8 is offline   Reply With Quote
Old 07-24-2011, 07:45 AM   #59
xXTheBossXx
Member#: 287907
post a dam pic i wanna see this beauty thanks for the advice ill look into 225s
Old 07-24-2011, 06:26 PM   #60
nhat
Member#: 140163
03 STi
hellaflunctional
any other modifications? o slam it i have to roll fenders im guessing but if i ut them on stock suspension while waiting for my coil overs will they work? is there anyting i shold know before diving into this wheel
best place to get them is wheeldude.
and it'll look like **** on stock suspension no matter what you do.
go to member's car gallery lazy asses
Old 07-24-2011, 06:28 PM   #61
nhat
Member#: 140163
03 STi
hellaflunctional
pretty sure dfunk is on 18x10 linea corse lemans.
Old 07-24-2011, 07:54 PM   #62
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Thanks Sherlock ^^^^^
Old 07-24-2011, 08:01 PM   #63
under0athh51189
Member#: 193959
2001 Lexus IS300
first page in here post #5
Old 07-24-2011, 08:01 PM   #64
under0athh51189
Member#: 193959
2001 Lexus IS300
they are
Old 07-24-2011, 09:08 PM   #65
Grieby54
Member#: 244643
2005 WRX Stage 2
CGM
Default Would it fit?
Would 18x8 ET37 wheels with 235/45's fit on my stock '05 WRX without fender rolling?
Grieby54 is offline   Reply With Quote
Old 07-24-2011, 09:49 PM   #66
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Just came across this thread...
If any "correct fitment" crew members post here, you will receive points for each and every post.
Originally Posted by Byzantium View Post
Points for what, asking a simple question? Get over it nhat.
i stated in the very first post you aren't welcome here. you haven't posted anything constructive and your questions only serve one purpose. you have all the other threads to post your righteous opinion and hatred in, stay out of here. the others are doing a damn fine job of staying out, for some reason you can't.
your points are still coming.
It's about time that he got something.
My stuff...
year: 2009
model: Impreza 2.5i Hatch
wheel model: Rota Silpstream
wheel size/offset: 16x7+48
tire brand/model: Bridgestone Potenza RE92
tire size: 205/55/16
wheel model: Rota G-Force
wheel size/offset: 17x7.5+48
tire brand/model: Kumho Ecsta ASX
tire size: 225/45/17
suspension: BC BR Coilovers (rears at max low, front can still go a tiny bit lower), Cusco Rear Lower Control Arms
alignment: Haven't gotten aligned since the last 1" drop but before I was at -1.2 front, -0.9 rear. Nothing crazy.
fender mods: none
spacers: none
Although the BC's are at max low, I know this isn't a crazy set-up but I am not rubbing and the fenders are untouched. I think that 225 +48 is probably the closest you can get to the (unrolled) fender without hitting it. 235 could probably be done, but a nigher offset would be needed. (good info for people who don't want to roll)
Sadly no real pictures yet.
JourdanWithaU is offline   Reply With Quote
Old 07-25-2011, 08:55 AM   #67
xXTheBossXx
Member#: 287907
sorry nhat merged my thread with this one so when i say something it makes me look like a jackass...
Old 07-25-2011, 09:21 AM   #68
nhat
Member#: 140163
03 STi
hellaflunctional
no... not even close.
my bad
Old 07-25-2011, 12:48 PM   #69
spagez
Member#: 252748
2013 wrx
Year: 2005
Model: RS Sedan
Wheel Model: Motegi Racing Wheels
Wheel size/offset: 17x7/+42
Tire size: 215/45/17? Recommendations?
Alignment: Stock
Fender Mods: Don't want to, if can be avoided...can I add saggy butt to avoid fender rub?
Suspension: Stock strut & springs from an 06 WRX TR
Additionally, given the stock wheelbase of 05 impreza sedan (RS: F - 1485mm, R - 1475mm ; WRX: F - 1485mm R - 1480mm; STi: F - 1490mm, R - 1495mm), i was thinking a 17x7 +42 offset will not make the wheels stick out the fender as much as it would on the WRX and STi. Or my thinking is incorrect.
Thanks
spagez is offline   Reply With Quote
Old 07-25-2011, 01:14 PM   #70
under0athh51189
Member#: 193959
2001 Lexus IS300
you shouldnt rub at all on stock suspension. . youll be fine. i used to run 17x8 +48 rota ge forces with 225/45/17 on tein s techs no problem. then i added 25mm spacers to make it a +23 offset and all i had to do was roll my fenders.
Old 07-25-2011, 03:53 PM   #71
06AZREX
Member#: 132244
2006 OBP WRX
2006 BMW 325i
Here is mine, nothing fancy yet.
2006
WRX TR
XXR 522
17x9 +42
Nankang NS1 235/40
Tein S-techs
Stock alignment
No fender mods
No spacers
[/url]
Will be selling these soon and stepping up to 18x10, coilovers and some fender work. John
06AZREX is offline   Reply With Quote
Old 07-26-2011, 06:21 AM   #72
T WRX rawr
Member#: 215168
2006 WRX stage 2 OS
Do you rub in the rear at all? I am wanting the same spec wheels but most likely on KW coilovers.
2006 WRX
17x9 +42
235/40 or 255/40
Alignment?
Fender work: I wouldn't mind rolling the rears too much, but if I don't have to that would be great.
Any thoughts?
T WRX rawr is offline   Reply With Quote
Old 07-26-2011, 09:56 AM   #73
06AZREX
Member#: 132244
2006 OBP WRX
2006 BMW 325i
No rubbing at all. You should be fine tuning 255 with coilovers as well.
Old 07-26-2011, 10:40 AM   #74
nhat
Member#: 140163
03 STi
hellaflunctional
rolling your rear fenders, 255/40/17s, and you'll only need -1.5* camber in the rear too clear.
Old 07-27-2011, 12:47 AM   #75
h1gh
Member#: 283363
07 STi
Default are 225/45/17 too small for a 17x9 rim +28?
im thinking about swapping my existing tires off my 17x7.5 rims over to a new 17x9 +28 wheel. just wondering if my tires will look too small or too aggressivewith that setup. more importantly will it be safe to drive hard on?
h1gh is offline   Reply With Quote
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
