Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 07-27-2011, 01:18 AM   #76
subi400
Member#: 216984
1996 Impreza outback
Green
Well, it depends on the tires that you have. Some of the tires are wider compared to other tires in the same width. With that width of rim, I would go with at least a 235/40R17 tire. But I would do some more research before saying for sure.
subi400 is offline   Reply With Quote
Old 07-27-2011, 04:02 AM   #77
h1gh
Member#: 283363
07 STi
theyre falken 912s
h1gh is offline   Reply With Quote
Old 07-27-2011, 05:32 AM   #78
blu_sti
Member#: 122487
04 STI
Just purchased this not too long ago off a another member. (torque r 18x19.5 +35) I plan on running 225/40/18 or 235/40/18 on my tires. Currently i have my fenders rolled, sitting on s-tech springs and stock struts. This will be going on an 04 sti. I have purchased 5mm spacers to clear the brembos already. Can somebody tell me what else i need to do to make these wheels fit? Is it really necessary to run coilovers, camber plates/camber bolts?
blu_sti is offline   Reply With Quote
Old 07-27-2011, 05:55 AM   #79
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
oh
my
god
Old 07-27-2011, 07:59 AM   #80
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by h1gh
im thinking about swapping my existing tires off my 17x7.5 rims over to a new 17x9 +28 wheel. just wondering if my tires will look too small or too aggressivewith that setup. more importantly will it be safe to drive hard on?
per manufacturer recommended specs? yes.
in the real world? no.
hope you've got a place in mind to roll your fenders and the right suspension mods.
Old 07-27-2011, 02:03 PM   #81
h1gh
Member#: 283363
07 STi
well i have coilovers and yea i plan to roll fenders. what else do i need. and what do u mean by per real world specs? Its not idea to run a small tire like that? would 235s be better? 235/45/17 or 235/40/17
Old 07-27-2011, 05:30 PM   #82
Marshall6285
Member#: 256100
year: 2002
model: WRX
wheel model: TE37
wheel size/offset: 17X7.5 +48
tire brand/model: Nitto neogen (new) BFG G-force (old)
tire size: 225/45
suspension: Tein SS
fender mods: None
spacers: None
Marshall6285 is offline   Reply With Quote
Old 07-27-2011, 06:18 PM   #83
nhat
Member#: 140163
03 STi
hellaflunctional
go to tire rack, look at any 225/45/17 tire, and check the manufacturer specified wheel width for mounting.
Old 07-27-2011, 07:12 PM   #84
Gordo92
Member#: 270878
Default Question about Possible Setup
Is it possible to run 19x8.5 with a 42+ offset on a 2010 2.5i?
If so, what kind of mods to the fenders would I be looking at?
P.S. It is sitting on an Sti Suspension.
Gordo92 is offline   Reply With Quote
Old 07-27-2011, 07:23 PM   #85
S53089
Member#: 172942
1992 Mazda B2600i
Drift Slut
jesus christo. read back about what everyone else has asked!!!
S53089 is offline   Reply With Quote
Old 07-30-2011, 01:21 PM   #86
decaman
Member#: 73055
04 STi
Default Work Emotion CR Kai Fitment
Hey all, I am looking to pick up some Work Emotion CR Kai gunmetal wheels. Some that I have found are in 17x9 (+44) and I am very interested in picking these up but I am worried about fitment. The only definitive info I have found is I need 10mm spacers in the front but I'm not sure about the rears. Will I have to roll or pull my fenders? Also, can I expect any unusual wear on my wheel bearings or tires with this setup?
My car:
04 STi (5x100)
stock struts with Espelir GT springs (front bump stops cut)
hotchkis swaybars/endlinks
otherwise stock suspension and fenders
Also, if you know of someone selling work emotion CR Kai in gunmetal please let me know! (size doesn't matter to me much as long as fitment doesn't require major mods). Prefer to buy with tires already installed.
Thanks!
decaman is offline   Reply With Quote
Old 08-01-2011, 04:09 AM   #87
ryanx
Member#: 252646
2002 stage2 wrx
aspen white
hey, im looking into buying some new wheels for my 02 wagon and i want something more aggressive than stock but i cant afford to get into coil overs and camber plates and things of that nature
my car is currently on swift sport springs and the stock struts
my question is, is it completely ridiculous for me to think i can get an agressive look without fender work and coil overs?
the wheels im looking at are the rota g-forces or grids in either 17x8 or 17x9
would those fit my wagon without modification? or if modifications are necessary then how much?
i hope that made sense i just got off work and im pretty tired
ryanx is offline   Reply With Quote
Old 08-01-2011, 06:01 AM   #88
soulhassorrow
Member#: 150732
2011 WRXXXX
LRP
For 17x9 +42, I see that most people rock 225/40 or 235/40! Assuming the car these would go on is dropped on h-techs with stock sturts, are 235/45 too meaty as to cause rear/front rubbing??
soulhassorrow is offline   Reply With Quote
Old 08-01-2011, 03:34 PM   #89
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
as far as the 17x8s i used to run the same setup with 225/45/17 with no rubbing at all on tein s techs. you would be fine with the 17x8s but they do look kinda sunk they wont be flush at all. it took 25mm spacers to get flush. i would venture to say that the 17x9s would be fine with 225/45 on them with no rubbing.
under0athh51189 is offline   Reply With Quote
Old 08-01-2011, 10:56 PM   #90
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Finally got some pictures!
Originally Posted by JourdanWithaU View Post
wheel model: Rota Silpstream
wheel size/offset: 16x7+48
tire brand/model: Bridgestone Potenza RE92
tire size: 205/55/16
wheel model: Rota G-Force
wheel size/offset: 17x7.5+48
tire brand/model: Kumho Ecsta ASX
tire size: 225/45/17
JourdanWithaU is offline   Reply With Quote
Old 08-01-2011, 11:52 PM   #91
NA STI
Member#: 285083
2006 STi
Default 17x9.5 +32 tc-105n
I searched but couldnt find much about these wheels... but does anybody know if the 17x9.5 +32 weds sport tc-105n will clear the 05 sti brakes without spacers or anything? im planning on putting some 295/35/17 a6s on them if they do. I obv. know it would rub because its going to stick out to far, But im just going to raise it high enough so that it dosnt rub. You guys think I will be fine with the inboard clearance with that offset and tire size? Im running tic sst spec coils.
Thanks
NA STI is offline   Reply With Quote
Old 08-02-2011, 12:37 PM   #92
fuapiti
Member#: 96334
2005 WRX sedan
WRBlue
Havn't been able to snap pictures yet, just installed new tires but here it is:
year: 2005
model: WRX sedan
wheel model: SSR Type C-RS
wheel size/offset: 17x8 +48
tire brand/model: Dunlop Direzza Sport Z1 Star Spec
tire size: 245-40-17
suspension: Tein Type Flex Coilovers
alignment: 1.5F - 1.0R (this will be changed to 2.0F 1.5 R)
fender mods: None
spacers: None
No rubbing issues, looks meaty, mean and very functional.
fuapiti is offline   Reply With Quote
Old 08-02-2011, 12:47 PM   #93
nhat
Member#: 140163
03 STi
hellaflunctional
Thanks
i think you should be good. i doubt brembo clearance is an issue.
Old 08-02-2011, 10:09 PM   #94
DAlexsanderC
Member#: 287879
2011 Wrx Sti
Wanted to confirm these.
http://forums.nasioc.com/forums/show....php?t=2162388
Will this fit on a 11 Sti sedan?
Dude said it will fit fine. It clears his brembos
Specs are:
5x114.3 (2) 18x8 +45 and (2) 18.8.5 +50
DAlexsanderC is offline   Reply With Quote
Old 08-02-2011, 11:34 PM   #95
nhat
Member#: 140163
03 STi
hellaflunctional
Specs are:
waste of money in my opinion
Old 08-03-2011, 03:39 AM   #96
DAlexsanderC
Member#: 287879
2011 Wrx Sti
Guessing it will be fine but a waste of money? thanks
Old 08-03-2011, 11:40 AM   #97
dingobite
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
Update 6-18-2013 Red are new parts I changed the last picture to something current.
2008 Sti no spacer i wont be mounting for another month or two.
RFP1, 17x10 +38,
Dunlop Star Spec Direzza 265/40/17
Rear Fenders rolled
Suspension - BC racing Coilovers + Swift springs
Theres about 1 inch and half fender gap on all four corners.
Almost identical drop the rce springs give you.
F/R 22mm whiteline swaybars.
Plenty of room at the struts 3mm or more at
the closest spot the wheel can touch the brembos.
Theres finger gap over the sti.
The 265 star specs do rub in the rear if i lift the car in any way that it will drop down all the cars weight just on the tips of the sidewalls. Yet i can still get into a auto x type of situation where theres no rubbing making tight turns. Probably needs rear adjustable control arms to avoid fender pulling, im no expert so ask someone else.
dingobite is offline   Reply With Quote
Old 08-03-2011, 01:58 PM   #98
ImportDynamics.com
Member#: 266986
2008 EVO X
WHITE
Hello Guys
I just buy Advan RG11 18x9 et 45. My car is a 05 WRX STI Without any suspension mods.
What tires you guys can recommend me without having to make any fender rolling.
Thanks in advance
Juan C
ImportDynamics.com is offline   Reply With Quote
Old 08-07-2011, 01:11 AM   #99
blackstidriver123
Member#: 183188
2007 Sti
ASPEN
Default te37 17x9 +22
Hey i was wondering anyone here fitted te37 17x9 + 22 on their sti? i was wondering if it is possible? cause i want to get te37 and i know the perfect size for me is 18x9 +28 but volks don't make that size so i was asking if anyone know what is a good fitment that isn't too hella flush but look flush with a concave look
blackstidriver123 is offline   Reply With Quote
Old 08-07-2011, 02:19 AM   #100
grippy monkey
Member#: 131067
your "stance"
sucks
I can't think of a specific STI that has had 17x9 +22 TE37's, but plenty of people have had wheels in that same range of width/offset. I am currently running 17x9 +17f/24r on my car with a full sized tire. Just be prepared to do fender work. Aggressive camber will be a must also.
You might also want to check into gramlight wheels my Rays. They make some 17x9's that are offset in the 30's that make it much easier to fit a 245+ tire.
grippy monkey is offline   Reply With Quote
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
