Old 10-22-2012, 01:56 PM   #1451
Gsxricky
Member#: 324861
2011 WRX "Limited"
Originally Posted by XERO287
You don't have to take anyone's opinion on here, but due note that the single reason one posts pictures on here is to feel proud of their purchase and subconsciously receive opinions. Not all of them have to be in your favor.
Agreed, but I was communicating with someone else (not about my car) and he decided to chime in. Either way, you are right in your point. Opinions are what you get on the thread and is the point of it. This Back and forth is just flaming up a good thread.
Gsxricky is offline   Reply With Quote
Old 10-22-2012, 02:01 PM   #1452
XERO287
Member#: 253541
2011 WRX 5DR Premium
Exactly. Post moar specs people!
XERO287 is offline   Reply With Quote
Old 10-22-2012, 02:03 PM   #1453
sc00by4life
Member#: 97135
Originally Posted by Gsxricky View Post
Advice maybe, but bashing people based on his opinions calling wheels pennies is not advice.
i didnt bash anyone.
you got offended that i said he could have a similar look for little investment.
Old 10-22-2012, 02:06 PM   #1454
Gsxricky
Member#: 324861
2011 WRX "Limited"
Really, I'm not offended, but I am over us ruining this thread. Opinions are opinions like the guy above this said.
Old 10-22-2012, 07:35 PM   #1455
240benzo
Member#: 292412
1997 Legacy Wagon
Green
Your A Troll.
YOU'RE*
troll level UP!
MOAR SCOOBY FITMENT from my buddies in wichita ks!
mexipoke but awesome wheel choice =]
240benzo is offline   Reply With Quote
Old 10-22-2012, 09:59 PM   #1456
d0ugch0i
Member#: 198861
2004 WRX
thinking about getting 245/40/18 on my 8" wheel. would i still be able to lower my car without any rubbing issues? my fenders are rolled. the stance im going for is for the fender to sit right above the tire so theres hardly any wheel gap or no wheel gap at all.
d0ugch0i is offline   Reply With Quote
Old 10-22-2012, 10:38 PM   #1457
02 Scoob-TN
Member#: 176010
2005 WRX sdn ver8'ed
Phat-Tuned RIP Bugeye
2002 USDM Bugeye JDM Ver 8 Longblock swapped
VF37
Full 3 inch turboback
Lots more..+Phatbotti Tuned
18x9 et38 Styluz M575
255/35/ZR18XL...
Fortune 500's+Roller Bearing upgrade Front 9k 14.0" Rear 7k 13.75"
Rear Fenders folded flat from 9 to 3 o'clock
Front fenders untouched
Brembo's re-drilled 5x100
Full Energy Bushings
No Spacers
Did it my way. Just did a little research...
02 Scoob-TN is offline   Reply With Quote
Old 10-23-2012, 07:05 AM   #1458
Fatty_Patty
Member#: 331275
2006 Impreza WRX
AWP
edit: nvm, taking foot out of mouth slowly.
Fatty_Patty is offline   Reply With Quote
Old 10-23-2012, 12:44 PM   #1459
Bulletshield
Member#: 312901
Over winter I'm thinking about putting bc racing coilovers on my 02 Wrx. I'm wondering if anyone has experience fitting 17x8.25 (+25) on this model year or am I better of with an offset of (+35)? I'm a poor student so I'm looking at xxr 530s.
Bulletshield is offline   Reply With Quote
Old 10-23-2012, 03:21 PM   #1460
sc00by4life
Member#: 97135
Neither is ideal.
Old 10-24-2012, 10:43 PM   #1461
BrandonWoRX
Member#: 256780
Originally Posted by DeleriousZ View Post
Finally got better pictures.
18x9.5 et25 225/40
Does anyone know the fender room on these? I've been considering trying to fit similar sized wheels with the same tires on an 09 WRX.
BrandonWoRX is offline   Reply With Quote
Old 10-25-2012, 01:35 AM   #1462
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Coilovers, camber control all around, roll/pull in rear and roll/light pull in the front. Also, you could get away with a 235/40.
Digital Dillon is offline   Reply With Quote
Old 10-25-2012, 01:47 AM   #1463
sc00by4life
Member#: 97135
this, however i doubt you could get away with a 235 on the narrow body. Also, unfortunately for the narrowbody, you'll need adjustable LCA's in the rear in addition to the coilovers.
225, along with the modifications Digital mentioned.
Old 10-29-2012, 06:06 PM   #1464
daniel5on
Member#: 257256
2008 Impreza WRX
Great info, was just on here looking for some advice in the right direction.
I am on H&R coilovers and have almost a 2 inch drop
Wheel Style - Rota DPT
Diameter - 18"
Width - 8.5"
Offset - +44mm
Tire : 215/35
I want to do some 5mm spacers and camber plates, but I want to go back up to a 225/35 (Also planning to get some 18x9.5 later) because I just dont like the harsh ride of these small tires...
Would this work out?
daniel5on is offline   Reply With Quote
Old 10-29-2012, 06:13 PM   #1465
sc00by4life
Member#: 97135
Diameter - 18"
Width - 8.5"
Offset - +44mm
Tire : 215/35
Camber plates aren't possible in the rear.
The narrowbody really doesn't have much room.
Old 10-29-2012, 07:43 PM   #1466
Digital Dillon
Member#: 288727
2008 WRX premium
With the +44 offset a 235/40 will work or a 225/40, giving you little more sidewall for a better ride. I ran 235/40 on an 18x8 +35 without a problem. The higher offset and .5" width shouldn't make that fitment much different.
Old 10-29-2012, 11:34 PM   #1467
xeiros
Member#: 205411
2006 WRX STI
Obsidian Black
Browsed through the thread and did some searching, but haven't seen anything thats conclusive.
I've got an 06 STI with stock struts and springs currently. I'm wanting to pick up a set of Motegi MR119 Rims (45mm offset) with some 245/40/18 BFG KDW2's on them. This isn't going to cause any fitment problems is it?
I've heard my car can be a bit finicky with what you can fit because the rear fenders are a real PITA to properly roll.
xeiros is offline   Reply With Quote
Old 10-29-2012, 11:38 PM   #1468
Wirtz
Member#: 286408
WFC #952
Function:error!
Revised my setup
Car: 2005 STi
Fender mods: Shaved and hammered rear fenders
Camber: -3 all around
17x9 +11/+13 with 215/45/17 on -3 degrees of camber. My setup is equivalent with width and stretch profile to an 18x10 +24 with a 245/35/18
Has just a little poke all around. Love it
Wirtz is offline   Reply With Quote
Old 10-31-2012, 02:15 PM   #1469
V4NCITYRIDER
Member#: 307939
2012 WRX Base Sedan
Hi. trying to get a set of wheels+tires for winter and hoping to minus size to 215/55/16
my car is a 2012 WRX sedan
and I'm wondering if a 16x6.5 +42 offset would work alright?
V4NCITYRIDER is offline   Reply With Quote
Old 10-31-2012, 03:38 PM   #1470
sc00by4life
Member#: 97135
A little tall.
215/50.
Old 10-31-2012, 03:54 PM   #1471
Digital Dillon
Member#: 288727
2008 WRX premium
Or a 205/55 will fit well.
Old 10-31-2012, 03:59 PM   #1472
V4NCITYRIDER
Member#: 307939
2012 WRX Base Sedan
A little tall.
215/50.
okay i see, now is that due to the offset of +42mm?
I sort of did some calcs for fun and the stock height of wheel and tire is 25.3" and 215/55 matches that exactly.
Old 10-31-2012, 04:20 PM   #1473
V4NCITYRIDER
Member#: 307939
2012 WRX Base Sedan
thanks. should I be concerned about the offset? the stock offset is 52mm i believe?
Old 10-31-2012, 04:39 PM   #1474
Digital Dillon
Member#: 288727
2008 WRX premium
Nope, the +42 on the 6.5" wheel is just fine!
Old 10-31-2012, 05:41 PM   #1475
V4NCITYRIDER
Member#: 307939
2012 WRX Base Sedan
Ahh. thanks for that... been troubling me for a bit lol.
So last question - is there a good way to know if the wheel will clear the calipers without physically fitting them on the car?? basically I'm wondering if these wheels will clear..
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
