Old 08-17-2011, 09:32 PM   #126
Psychoreo
Member#: 79643
04 EJ207 Swapped
Mikey tuned 271whp/287wtq
Yea me neither but they're winters and that's what's on them. Come summer time there'd be somewhere around a 245 series tire.
Psychoreo is online now   Reply With Quote
Old 08-17-2011, 09:34 PM   #127
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Kind of a weird combo...
After looking up the Pirelli Winter 240 Sottozero... How are you getting 205/55/17? Unless you are talking about the Serie II...
Either way... that's a 8" snow tire... What are you trying to accomplish?
JourdanWithaU is offline   Reply With Quote
Old 08-17-2011, 09:42 PM   #128
Psychoreo
Member#: 79643
04 EJ207 Swapped
The tires are less important in this situation but they're HERE
My main question is how they would look in regards to the sedan fenders/wagon control arms.
For instance, (really crappy picture)
Those are 17x7 (supposedly) +35 exel radius (can anyone confirm the offset? I don't trust amazon.com...)
Not looking for hellaflush here, just trying to bring the wheel out a bit more and be able to have 17x8's.
Old 08-22-2011, 05:34 PM   #129
jmousso
Member#: 250285
05 WRX
Default Fitment questions
So, I finally have the job to pay for wheels!
Now I'm a big stance guy, I enjoy looking at it, but not so much driving with it.
So, I've been trying to figure out what a good stance/fitment is, without being too ridiculous and causing myself too many problems.
I definitely would like to go 18's, but I'm not so sure on how wide. I was pondering at 18x8, or 18x9 with anywhere from +25 to a +38 offset.
Now I understand fender work, and the coils, but what would I have to do for camber? How do I obtain said camber? Will it be damaging to my wheel bearings? Also, as far as tires go, I'm not too big on the whole stretched thing. So what size do you think would be appropriate?
EDIT: Or perhaps that wouldn't be wide enough to even need camber? Could I tuck and roll and be safe with that much width? So many questions o.O
EDIT2: Sorry, thread got moved. Thats why the post looks so out of place.
Thank you for your time, and responses!
jmousso is offline   Reply With Quote
Old 08-23-2011, 07:07 PM   #130
sc00by4life
Member#: 97135
If you don't like driving it, why do you want to do it?
Camber is achieved through ride height, camber bolts, or camber plates. Your wheel bearings will be fine. As far as tires, it seriously depends on the offset. With either of the two offsets you mention (+25 and +38) you WILL need to stretch tires, and you WILL need fender work. Stick to et42+ and you'll be much happier.
You can run a 17x9 +42 and up to a 245 tire on your car without really needing to worry about rolling (maybe a touch in the rear). You don't have to be "hellaflush" for your wheels to look good.....
Old 08-24-2011, 11:15 PM   #131
jmousso
Member#: 250285
05 WRX
Well, I should say I don't MIND driving it, but hence why I'm trying to keep it to some sort of happy medium you know?
I'm not really sweating it too hard with the whole fender rolling or any sort of body modification to get a wheel to fit. I suppose I just more get lost around the camber issue and what route to take with that.
If you wouldn't mind could you PM me and we could chat about it? I don't want to take up the thread with my noobish-ness
Old 08-25-2011, 10:04 AM   #132
Slow_2.5
Member#: 292104
2006 Jawny jawn
Burple
All of you would benefit from running wide wheels, streched tires and lowering it!
Slow_2.5 is offline   Reply With Quote
Old 08-25-2011, 01:19 PM   #133
240benzo
Member#: 292412
1997 Legacy Wagon
Green
is a first gen wrx about the same width of a car as a second gen legacy?
i cant decide wheels i wana get for my wagon
was thinking around a 17x8+40 or 17x9+35
also considered a 16x8+15 or 18x9+35
im thinking 17s would be a good inbetween
240benzo is offline   Reply With Quote
Old 08-26-2011, 12:23 PM   #134
kylea1
Member#: 255452
2002 wrx TD04ed =P
how is everyones tire wear with camber settings like 2.0 etc? im gonig for my alignment soon and have a semi aggressive stance and at the same time i do not want to kill my tires to fast. how long do you guys get out of your tires?
kylea1 is offline   Reply With Quote
Old 08-26-2011, 01:05 PM   #135
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
-2 is fine. Once you start getting a little higher you will get camber wear.
I'll recommend -2 front and -1 to -1.5 rear.
Byzantium is offline   Reply With Quote
Old 08-26-2011, 01:51 PM   #136
kylea1
Member#: 255452
2002 wrx TD04ed =P
Ok is their anything wrong with 2.0 in the back and front?
Old 08-26-2011, 05:30 PM   #137
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
no. if this is just a daily driver, there's nothing wrong with it.
Old 08-30-2011, 09:04 PM   #138
fmars62
Member#: 290517
2008 Impreza 2.5i
Dark Grey Metallic
what are the widest wheels i can go on my 2008 2.5i hatch without them rubbing? and i just got lowering springs and my fenders rolled for prep. i was thinking 17x9 or can i go wider?
fmars62 is offline   Reply With Quote
Old 08-31-2011, 03:30 PM   #139
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
you also have to consider offset, tire size, and alignment.
Old 08-31-2011, 05:30 PM   #140
240benzo
Member#: 292412
1997 Legacy Wagon
Green
do you think a 18x8.5+35 will sit pretty flush on a 96 legacy??
dont want tons of poke-just something clean and low
Old 08-31-2011, 05:56 PM   #141
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
i think that'd be good. not sure what tire size you'd run but i'm sure you can figure that out on your own
older legacies have such tight fenders.
Old 08-31-2011, 08:15 PM   #142
fmars62
Member#: 290517
2008 Impreza 2.5i
Dark Grey Metallic
yeah idk what tires I'm gonna run, i really don't want lo pros, and idk way offset to run, I'm a noob to scoobies cause i just got mine, and I've tried seating and idk what offset is good for a stances car
Old 08-31-2011, 10:27 PM   #143
240benzo
Member#: 292412
1997 Legacy Wagon
Green
if i could get a 205/40 or something similar thatd be nice
im def not opposed to doing fender work or new to it coming from the 240 world
i just dont want to run alot of camber but according to wikipedia
the 2nd gen legacy is a half inch wider than the first gen wrx's which look pretty good with 8.5s and 9s so i cant decide on which width would look best/most aggressive without looking like too much
Old 09-03-2011, 12:41 AM   #144
A2WREX
Member#: 292143
2008 WRX 4D
Dark Gray Matallic
year:2008
model:WRX
wheel model:Motegi MR125
wheel size/offset:18''x8" +35
tire brand/modelroxes 4
tire size: 225/40/18
suspension:epic engineering lowering springs
alignment:idk
fender mods:soon....
i ordered these motegi's for my wrex and im pretty sure im gonna have to roll the fenders or not, tell me what u guys think, would they hurt my wheel bearings for a DD and if you think ill be running into any other problems such as camber issues... thanks in advance
A2WREX is offline   Reply With Quote
Old 09-05-2011, 11:31 PM   #145
sc00by4life
Member#: 97135
Originally Posted by A2WREX
year:2008
model:WRX
alignment:idk
Yes you'll need some form of camber control. You might need to roll the rears but I doubt it.
Old 09-05-2011, 11:34 PM   #146
sc00by4life
Member#: 97135
"low pro's" are the only tires you'll be able to get stance with. Most 17-18 tires for our cars are "low pro" anyways....
If you don't have coilovers, sways, some form of camber control, and fender mods, you will never get "stance".
Old 09-06-2011, 01:15 AM   #147
designfate
Member#: 114502
04 STi
Bugeye forever
sorry if im beating a dead horse here, ive been searching threads but havent been able to find a definite answer. Im planning on getting 18x9.5 +20's and I want to avoid the rim poking out. With that size wheel I see people posting that 265/35's work. Im planning on rolling my fenders and im planning on running these with coilovers.
will 265's give me a little more flushness as far as sidewalls go? Think ill have to pull my rear fenders? Sorry for posting in here but i figured it would get the best answer.
designfate is offline   Reply With Quote
Old 09-06-2011, 08:26 AM   #148
CaseD
Member#: 206771
04 G35 coupe
I would imagine you would need to pull your fenders esp the rears with a 265.
Im currently considering buying a set of 18x9.5 +30 wheels. I would imagine that I would definitely need to roll the front and rear fenders. I am already lowered on bc coils. As far as needing more camber would a set of rear camber plates do the trick?
I am also looking at a 245/35/18 tire (not sure which brand yet though). how much camber would people recommend running?
CaseD is offline   Reply With Quote
Old 09-06-2011, 09:43 AM   #149
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
to fit 255/35/18s or 265/35/18s, you'll need a front fender roll, rear fender roll and pull, and i'd say at least -2.5* camber all around as a starting point but most likely more.
you'll want rear camber plates for sure. front fenders you won't have to touch if you run more than -2.7* camber, rears will need a roll and pull with at least -2* camber if you run the 245/35/18s but i'd go with a 255/35/18.
Old 09-06-2011, 11:00 AM   #150
CaseD
Member#: 206771
04 G35 coupe
Can I achieve that much camber on bc coils w/ rear plates? Where exactly is the limit? I am trying to learn a lot about this before I pull the trigger on a set of wheels, that way I know what I am getting myself into. Are you recommending 255/35s just because of the extra meat on the tire?
at first I was looking at these:
http://www.wheeldude.com/catalog/pro...oducts_id=6461
now I am considering these because of the slightly higher offset:
http://www.ngpracing.com/store/index...roduct_id=4096
I dont mind messing with the fenders, but running that the amount of camber you mentioned for the 18x9.5 just seems like a lot.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
Message Board Statistics All times are GMT -4. The time now is 05:31 PM.
