Old 11-28-2012, 04:50 PM   #1551
BenT
Member#: 195836
year: 04
model: WRX Sedan
wheel model: Rota DPT
wheel size/offset: 17x9 ET35 or ET42 ???
tire brand/model: Bridgestone RE760 Sport
tire size: 245/40/R17
suspension: 05 OEM STi w/ RCE Yellow springs (05+ STi hubs)
alignment: no camber
fender mods: rear fender inner ledges are cut down to about 1/4 inch
spacers: No
I basically don't know which offset to choose between 35 and 42 but want the widest stance possible without rubbing... please help!
thanks!
BenT is offline   Reply With Quote
Old 11-28-2012, 05:20 PM   #1552
sc00by4life
Member#: 97135
Originally Posted by BenT
year: 04
model: WRX Sedan
spacers: No
thanks!
+42 is better, but you still probably need to roll all around.
Old 11-29-2012, 09:09 AM   #1553
BenT
Member#: 195836
How much camber or tire stretch (if I go with a 235 or god forbid 225) are we talking about if I go with the 35 offset?
Old 11-29-2012, 10:14 AM   #1554
sc00by4life
Member#: 97135
Depends on what brand. Honestly, where the face of the wheel sits visually, it won't look a whole lot different.
Old 12-01-2012, 10:11 AM   #1555
Bobert540
Member#: 82281
2013 WRX Ltd. Hatch
Im possibly picking up a 13 wrx hatch. I have a set of RS 6 spokes with winter tires on them. Will they fit? I know bolt pattern is the same. They fit on my 06 wrx but just wanted to make sure offset. Was ok
Bobert540 is offline   Reply With Quote
Old 12-01-2012, 11:34 AM   #1556
sc00by4life
Member#: 97135
They fit the GC. They fit the GD. Nothing major has changed in that regard. They will fit.
Old 12-01-2012, 02:00 PM   #1557
jaysh
Member#: 133200
2013 STi Limited
Model: 2006 STi
Wheel: Rota G-Force
Wheel size/offset: 18x8.5 +48
Tires: Hankook Ventus V12
tire size: 235/35/18
Suspension: Stock Struts with Eibach Pro Springs
Alignment: No Camber
Fenders: Would like to try and avoid Rolling.
spacers: No
Thanks.
jaysh is offline   Reply With Quote
Old 12-01-2012, 02:09 PM   #1558
sc00by4life
Member#: 97135
Originally Posted by jaysh View Post
Model: 2006 STi
Wheel: Rota G-Force
spacers: No
Thanks.
You should be ok. You'll want a 235/40 though.
And it's dangerous to run "no camber" or "0" camber. You NEED negative camber for ANY wheel setup. Not to mention just about all cars come with some negative camber from the factory.
Old 12-01-2012, 02:41 PM   #1559
Bobert540
Member#: 82281
2013 WRX Ltd. Hatch
Perfect! thanks for the quick reply.
Old 12-03-2012, 10:51 AM   #1560
NRTmotorsports
Member#: 16517
'13 BRZ
I'm ready to buy a wheel/tire combo just need some quick advice. I have an '09 WRX and want a nice flush look with the fenders. Was looking to get 17x8 with either a +40 or +44, still unsure of tire size, was thinking 235/45 or possibly wider? As of right now I'm running stock ride height and will at most see an 1.5 inch drop on springs. Could someone help with with a size that wont require fender pull or any rubbing issues with a slight drop? Thanks everyone
NRTmotorsports is offline   Reply With Quote
Old 12-03-2012, 01:59 PM   #1561
sc00by4life
Member#: 97135
there is no such thing as flush without some form of fender modification.
that said, neither of those will be really "flush" in the way 99% of us use the term, but the +40 will probably be "flush enough" for you.
235/45 is a bit tall, try a 235/40.
Old 12-03-2012, 02:21 PM   #1562
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
The +40 offset is probably the best choice for a mild drop. I have enkei pf01's with 17x8+35offset with 245/45/17 but i wish i would have gone with 245/40/17 instead. I have koni's w/ Rce yellows (~1" drop) and it sits fairly flush and I have not rolled or pulled. Only time I have rubbed is with a full car and hard cornering occurred. Also what scooby4lyfe said lol. Hope this helps somewhat.
KartRacer3 is offline   Reply With Quote
Old 12-03-2012, 05:08 PM   #1563
jorge0886
Member#: 269257
2011 STI Limited
2011 STI
I have the stock 245/45/18
and I'm going to a 225/50/17
How much is this going to affect my speedometer?
jorge0886 is offline   Reply With Quote
Old 12-03-2012, 05:31 PM   #1564
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Originally Posted by jorge0886 View Post
2011 STI
Google search tire size calculator. Goto the miata website. Enter in your current tire specs and it will tell you exactly. Your welcome
Old 12-03-2012, 08:07 PM   #1565
sc00by4life
Member#: 97135
2011 STI
your stock size is actually a 245/40/18.
Running the calculations, a 225/50/17 will be about 1/8th of an inch taller, which would be fine for me.
Old 12-05-2012, 11:58 AM   #1566
bicho_ojo
Member#: 268847
2005 35r'd STI
I will be ordering a set of Work Emotion CR Kai's in 18x8.5 et 38 will these clear my brembos?
bicho_ojo is offline   Reply With Quote
Old 12-07-2012, 01:40 PM   #1567
johnmkv
Member#: 300848
2012 WRX
LR
So outside of work emotions xd9 is there any other wheels with a similar amount of sopokes and a sweet lip like that? Problem with xd9 is that they are 10 inches wide i would like something in the 9.5 or 9 inch range with a lip similar to xd9 an ideas? Rota makes p1 but only in 8 in wide
johnmkv is offline   Reply With Quote
Old 12-07-2012, 02:00 PM   #1568
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
The Rota DPT is a 10 spoke, but I don't know the sizes.
flat4LGT is offline   Reply With Quote
Old 12-07-2012, 02:25 PM   #1569
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
18x9.5 with offsets ranging from low 20's to 44. And a 18x8.5 too.
Digital Dillon is offline   Reply With Quote
Old 12-07-2012, 03:01 PM   #1570
tee-tea
Member#: 328853
has anyone done 255/35/18 on a gc8? If so I wanna know what et, spacers, etc
tee-tea is offline   Reply With Quote
Old 12-07-2012, 03:26 PM   #1571
johnmkv
Member#: 300848
2012 WRX
LR
No lip though im looking for something deep dish i guess would be the term but in 9.5
Old 12-07-2012, 03:38 PM   #1572
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
So do you want the design or the lip?
The DPT is the closest in design, but you aren't going to find many "knockoffs" that have that kind of lip. Regardless of size or offset.
Old 12-07-2012, 04:09 PM   #1573
Digital Dillon
Member#: 288727
2008 WRX premium
Check out Varrstoen, Miro, and XXR for budget wheels with a deep lip design.
Old 12-07-2012, 04:12 PM   #1574
sc00by4life
Member#: 97135
The 9" xd9's have pretty similar lip (2.5" vs 3.5").
Old 12-08-2012, 09:40 AM   #1575
xeiros
Member#: 205411
2006 WRX STI
Obsidian Black
year: 2006
model: STI
wheel model: Motegi MR119
wheel size/offset: 18x8 +45
tire brand/model: BFG KDW2
tire size: 245/40/18
suspension: Stock
alignment:
fender mods: Wanting to avoid.
spacers: none
Basically wondering if this wheel and tire setup will work on my car without having to roll the fenders, or if the tires are going to be too wide. If I have to run the stock 225/40 on these rims then so be it, but I'd like to squeeze out what I can without having to worry about rolling the fenders.
xeiros is offline   Reply With Quote
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
