Old 12-23-2012, 08:32 PM   #1626
RM3851
Member#: 232522
'14 STi
02C Croatianized
05 STi, KW V3, Enkei NT03 18x8.5et38. Currently the tires are 235/40 and while turned about 45* up front (for an illustration to the right), the left very front of the tire comes soooo close to the wheel well that I simply cant comprehend how do ppl run ANY other size larger than 235/40.
No camber plates. Currently, the alignment specs suggest cca. 4.4* of caster, -1* of camber.
I would like to go to 245/40 but I am 99.9% positive it will rub while turning.
Any experience, photos, suggestions?
Thanks.
RM3851 is offline   Reply With Quote
Old 12-23-2012, 09:21 PM   #1627
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
He says his alignment is stock. Don't know if thats stock spec or since the factory. Either way, I'd say check the alignment.
BSP671 is offline   Reply With Quote
Old 12-24-2012, 10:30 AM   #1628
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
year: 2013
model: Wrx 5dr
wheel model: Rota gravel
wheel size/offset: 18x8 e-48
tire brand/model: goodyear f1
tire size: 235/40/18
suspension: tanabe tdf-140
alignment: stock
fender mods: none
spacers: no
wirthless is offline   Reply With Quote
Old 12-25-2012, 10:58 PM   #1629
B1Ad3
Member#: 311829
Originally Posted by sc00by4life View Post
Yea. With that setup you are going to be rubbing a lot regardless.
So maybe a 18 x 8.5 245/35/18 what offset? i think they come in a +35 or +30.
Dont want to have any scrubbing issues but want to have the same sort of look as the above picture
B1Ad3 is offline   Reply With Quote
Old 12-26-2012, 03:01 AM   #1630
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
If you want that look you need WIDE tires like a 255/35 on that 8.5 at a minimum with some camber and roll/pulled fenders. Try finding a wheel with an offset in the high 40's or use spacers on an OEM wheel with a wider lower profile tire.
Digital Dillon is offline   Reply With Quote
Old 12-26-2012, 10:24 AM   #1631
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Is there a big difference between 225/40 and 235/40 on a 18x9.5?
Old 12-26-2012, 01:51 PM   #1632
BuggedWrx
Member#: 227893
2012 STI
Year: 2003
Model: WRX
Wheel size/offset: 17x9 +35
Tire Brand: Hankook V12 or HTRZ III
tire size: 245/40/17 or 255/40/17
suspension: ST coilovers and Group-N topmounts
fender mods: none yet
For any of you that have 17x9s on your car. Planning on running 255/40/17 or 245/40/17
What modifications did you need for this to work? I have about a finger and a 1 inch gap all around.
I'm guessing roll flat and pull all around and probably some camber plates?
BuggedWrx is offline   Reply With Quote
Old 12-28-2012, 05:08 PM   #1633
Danny WRX Pikeness
Member#: 196621
2012 WRX hatch
Hey all, quick fitment question. im horrible when it comes to wheel/tire sizes blah blah blah. I have a 2012 wrx hatch lowered 1.5i nches and im planning on running an 18x8 +35 wheel with a 235 40 tire. Would i need to roll my fenders with 0 camber or will that fit with no modification. Thanks guys!
Danny WRX Pikeness is offline   Reply With Quote
Old 12-28-2012, 05:51 PM   #1634
sc00by4life
Member#: 97135
0 camber would be dangerous. i would not recommend that.
Old 12-28-2012, 06:08 PM   #1635
Danny WRX Pikeness
Member#: 196621
2012 WRX hatch
How so? What does stock usually run? Like i said, sorry for my lack of knowledge. First time actually messing with the whole big wheel fitment deal.
Old 12-28-2012, 06:22 PM   #1636
Danny WRX Pikeness
Member#: 196621
2012 WRX hatch
I actually should have said 0 camber adjustment. Sorry
Old 12-29-2012, 02:06 PM   #1637
jaysh
Member#: 133200
2013 STi Limited
For some reason the search is only showing the first few pages of this thread...
My debate is this:
2006 STi
Want to get Rota G Forces on my Eibach lowering springs
Debating between 18x8.5 or 18x9
Tires would be Hankook V12's if I go w/ the 8.5 (225/40/18) and 9 (235/40/18)
Not looking to roll. Would I fit the 9's with that tire? I think 225/40/18 on a 9 might be stretching too much?
jaysh is offline   Reply With Quote
Old 12-29-2012, 02:46 PM   #1638
sc00by4life
Member#: 97135
you'll need to roll with the 18x9 gforce. pretty much regardless of tire.
and that much stretch looks STUPID unless you are fender on rim low.
Old 12-30-2012, 07:15 AM   #1639
huscroft
Member#: 234777
97 Subaru impreza
black
year: 2005
model: Wrx wagon
wheel model: Rota g-force
tire size: 235/40/18 or whatever fits
suspension: stock
alignment: stock
fender mods: none
spacers: no
will this fit?
huscroft is offline   Reply With Quote
Old 12-30-2012, 07:24 PM   #1640
WillyW
Member#: 342087
Hey everyone I have a silver 04 wrx and am looking to put new 17 in rims this spring. I was looking into BR09's either in hyper silver or black. Im on the stock suspension currently and was wondering which would look better. Open to other suggestions as well. New to the forums btw so apologies if not posted in the right area. Thank you ahead of time
WillyW is offline   Reply With Quote
Old 12-31-2012, 01:38 PM   #1641
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
Originally Posted by wirthless View Post
year: 2013
model: Wrx 5dr
suspension: tanabe tdf-140 1.1"
alignment: stock
fender mods: none
spacers: no
Any ideas ?
Old 12-31-2012, 01:46 PM   #1642
byun
Member#: 258046
2011 Impreza WRX
Any ideas ?
This should fit with no problem. I had the g-forces in the same size and offset on mine and am lowered with the bilstein and rce yellows.
byun is offline   Reply With Quote
Old 12-31-2012, 01:50 PM   #1643
dfw
Member#: 161460
Do you think 245's on the same set up work?
dfw is offline   Reply With Quote
Old 12-31-2012, 02:50 PM   #1644
byun
Member#: 258046
2011 Impreza WRX
I would think so, I had quite a bit of room, but couldn't say for sure.
Old 01-01-2013, 09:04 AM   #1645
boostedxsti
Member#: 332060
05 STi
year: 2005
model: Sti
wheel model: Enkei RPF1
wheel size/offset: 18x9 +40
tire size: wondering this myself.. 245?
suspension: BC BR w/ swift springs
alignment: camber plates up front
fender mods: none
spacers: no
thinking about 18X8.5 or 18X9
boostedxsti is offline   Reply With Quote
Old 01-01-2013, 12:14 PM   #1646
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
year:2006
model:WRX
wheel model: Rota DPT
wheel size/offset: 18x8.5 +44
tire brand/model: ???
tire size: 255/35
suspension: STOCK
alignment: I have camber bolts If I need to adjust anything.
fender mods: will roll if needed.
spacers: none
*trying to get the biggest setup on stock 06 WRX(with fenders rolled)
JokerGT is offline   Reply With Quote
Old 01-01-2013, 04:44 PM   #1647
MooKz
Member#: 255479
2005 Legacy GT
Satin White Pearl
Summer Mode:
Year: 2005
Model: Legacy GT
Wheel Model: Varrstoen ES111 (BBS LM Replicas)
Wheel Size/Offset: 18x9.5 +34
Tire Brand/Model: Nankang NSII (Temporary)
Tire Size: 215/40
Suspension: BC Coilovers, Whiteline Endlinks, Whiteline Camber and CA Bushings.
Alignment: Camber (around 3.5* in front 4.5* in back.)
Fender Mods: Rolled and Pulled
Spacers: None.
Winter Mode:
Year: 2005
Model: Legacy GT
Wheel Model: XXR 527
Wheel Size/Offset: 17x8.25 +35
Tire Brand/Model: Kumho Ecsta All Season
Tire Size: 205/45
Alignment: Awaiting alignment.
Spacers: None.
MooKz is offline   Reply With Quote
Old 01-02-2013, 12:22 PM   #1648
igotboostpower
Member#: 280693
15' Launch Edition
WRB on Gold BBS
Year: 2013
Model: STI 5dr
Tire Brand/Model: lm-60 blizzaks
Tire Size: 245/45
Suspension: stock
Alignment: stock.
Fender Mods: none
Spacers: None.
will these clear the brembos without spacers?
igotboostpower is offline   Reply With Quote
Old 01-02-2013, 08:16 PM   #1649
Apedz215
Member#: 328682
year: 2013
model: Wrx 5dr
wheel model: Miro 111
wheel size/offset: 18x8.5 +35
tire brand/model: not sure
tire size: not sure
suspension: stock
alignment: stock
fender mods: none
spacers: 10mm?
Will this fit? Not really looking to roll fenders or anything. Im a noob to wheel fitment coming from the jeep world
Apedz215 is offline   Reply With Quote
Old 01-03-2013, 10:53 AM   #1650
stockley1234
Member#: 332441
Would someone please be able to help me out with my setup?
Year: 2007
Model: Impreza 2.5 N/A WAGON
Suspension: Coilovers; whatever I order. KW V1's more than likely.
What I want to run:
18x8.5 +45.
I am wondering if someone would be able to confirm that I would be able to clear with just a roll and pull on the rear fender. Would I need to run much pass natural camber?
stockley1234 is offline   Reply With Quote
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
