Old 02-05-2013, 02:52 PM   #1801
WiechWRX
Member#: 249659
2012 WRX Limited
^ Thanks that's what I figured! If I wait and get the +38 will I just be looking at some rolling?
WiechWRX is offline   Reply With Quote
Old 02-05-2013, 03:19 PM   #1802
itsachalkboard
Member#: 343197
year: 2012
model:STi
wheel model: Advan RZ (bronze)
wheel size/offset: 18x9.0 + 45 (or 35)
tire brand/model: Stock
tire size: 245/40/R18
suspension: stock
alignment: None
fender mods: None (hopefully)
spacers: no
Looking for a pure performance setup. Not as worried about stance/more concerned about feedback.
Let me know before I pull the trigger. I've done some searching and think it will work, but would like some second opinions before I go for it.
itsachalkboard is offline   Reply With Quote
Old 02-05-2013, 03:46 PM   #1803
boricuamepr
Member#: 246244
2003 v7 Limited
STi Clone
Originally Posted by boricuamepr View Post
03 WRX
Tokico D-Spec and RCW Yellow Springs
17x9.5 +38 Enkie RPF1
245/40r17
Alignment -2* rear -1.5ish* front
I was told I could run these with a fender roll, just trying to confirm.
Still need some help, I can't find a straight answer.
boricuamepr is offline   Reply With Quote
Old 02-05-2013, 06:46 PM   #1804
illanasbugeye
Member#: 346063
2003 wrx
Default spacers?
What will i need to do to widen my wheel base and how much can i expect to spend?
illanasbugeye is offline   Reply With Quote
Old 02-05-2013, 07:37 PM   #1805
ProjectMonkey
Member#: 340145
Ok its that time of the year were we all get our income tax back and want to make a purchase. Need some advice. I have only seen these on 2010 and above and 03 on 18's. But what do you think on a 2002 WRX wagon, no fender flares. I doent understand offset set to well, i would not know what to go with. Think 17x8 on a 245 tire. Input....
ProjectMonkey is offline   Reply With Quote
Old 02-05-2013, 08:06 PM   #1806
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
What is the offset?
A 245 tire might be a little wide to fit under a wagon, but it depends on your suspension set up.
flat4LGT is offline   Reply With Quote
Old 02-05-2013, 08:12 PM   #1807
ProjectMonkey
Member#: 340145
I honestly doent want to run anything crazy this time around, I had a lowered 04 civic on D2 coilover. I was thinking about just going with Tien lowering springs. A 235 should work, dont want crazy strech??
Trying to go with a flush look, doent want cazy camber.
Old 02-05-2013, 09:44 PM   #1808
wagon_war
Member#: 320092
02 WRX WAGON
I am trying to do a 17x9 et38. On a 02 wagon what fender mods am I looking at with a 215/40
wagon_war is offline   Reply With Quote
Old 02-05-2013, 09:48 PM   #1809
wagon_war
Member#: 320092
02 WRX WAGON
Originally Posted by needasubie10 View Post
02 wrx wagon
kyb replacement struts with prodrive blues
Im looking at getting a set of drag dr31 in 17" not sure if 7 or 8 wide would be best and am taking reccomendations on tire sizing also. Dont want to do any fender mods. It looks like the offset is +40
I looked through the drag thread but didnt see alot on the wagons
Thanks
Any suggestions on this setup?????
Old 02-05-2013, 10:05 PM   #1810
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
I'm running 18x8.5 +48 with a 235/35 and less than -2* of camber all the way around and everything fits under my wagon. I'm about 2-2.5" lower than stock. The only problem is that there are only like 2 tires available in a 235/35/18 and a 225/40 will have a decent stretch on a 9" wheel. But since you're planning on going with a 17, you can probably do a 235/40 under wagon fenders.
ps- my wheels for sale too
/shameless plug
Old 02-05-2013, 10:22 PM   #1811
ProjectMonkey
Member#: 340145
so a 17x8 +45 with a 235/40 should fit just fine without any mods??
Old 02-05-2013, 10:31 PM   #1812
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
Maybe a roll in the rear, but I don't see it being a major issue.
Old 02-06-2013, 06:37 PM   #1813
ejsands92
Member#: 346200
2002 wrx wagon
Default 02 wrx wagon
Year/Model: 2002 wrx wagon
Wheel:Rota G-force
Wheel size: 17x8 e48
Tire Size:??
Suspension:All stock
Alignment:Stock
Just curious what size tires would be good? I don't want to have fender work done, I think I could do a 235/40/17 easy enough??
PS they would be summer tires
ejsands92 is offline   Reply With Quote
Old 02-06-2013, 09:41 PM   #1814
FreeDiRo
Member#: 324928
2006 Sti
SGM
Year/Model: 06 WRX TR
Wheels: ASA Mesh 17x7.5 with +45 0ffset
Tires: 225/45/17
Suspension: stock for now
Alignment: stock but want negative camber.
Will I run into fitment issues or what can I do to make this set up work?
FreeDiRo is offline   Reply With Quote
Old 02-06-2013, 09:52 PM   #1815
bboylocob
Member#: 151809
2007 WRX
Tires: 225/45/17
No issues there
bboylocob is offline   Reply With Quote
Old 02-06-2013, 10:06 PM   #1816
FreeDiRo
Member#: 324928
2006 Sti
SGM
Originally Posted by bboylocob View Post
No issues there
Awesome! Thanks for the reassurance.
Old 02-06-2013, 10:26 PM   #1817
FreeDiRo
Member#: 324928
2006 Sti
SGM
No issues there
Another quick question, what if tires are 235?
Old 02-06-2013, 10:27 PM   #1818
bboylocob
Member#: 151809
2007 WRX
Still fine. I had same size wheels same offset ran a 235/40 no issues
Old 02-06-2013, 10:35 PM   #1819
FreeDiRo
Member#: 324928
2006 Sti
SGM
Sweet, thanks man.
Old 02-07-2013, 11:44 AM   #1820
onsharry
Member#: 268229
2004 WRX
Default Fitment
Year: 2004
Model: WRX
Wheel Model: Work XD9
Wheel size/offset: 18x9 +38
Tire brand/model: Hankook Ventus v12
Tire size: 235/40/18
Suspension: CKS (Corner Konnection Systems) coilovers
Alignment: Let me know
Fendor mods: Let me Know
spacers: yes/no? size? No
I've been reading and searching, but i just want to get a straight answer before I drop about 2 grand. Thanks in Advanced.
My car currently sits with no wheel gap. I dont plan on going any lower.
My questions are:
Would I need a Roll? (Yes?)
Would I need to pull? (hope not)
How much Negative camber? (dont mind)
Would rim be past the fendor or flush?
Please Let me know thanks!!!
onsharry is offline   Reply With Quote
Old 02-07-2013, 12:01 PM   #1821
littlewhitewagon
Member#: 103068
11 STI sedan
Originally Posted by itsachalkboard View Post
year: 2012
model:STi
suspension: stock
alignment: None
spacers: no
Your stock 245s are not going to be a "pure performance" setup. Think more 265-285 for that. Fender mods are necessary for that kind of action. 10" wide is where you should be looking as far as wheel width.
littlewhitewagon is offline   Reply With Quote
Old 02-07-2013, 12:04 PM   #1822
littlewhitewagon
Member#: 103068
11 STI sedan
Wheel:Rota G-force
Tire Size:??
Alignment:Stock
Depends on the actual tire. 225/45R17 will likely fit without issues, 235/40R17 will more likely need a roll in the back. If you want NO work, then 7.5 wide with 225s is your ticket.
Old 02-07-2013, 12:17 PM   #1823
littlewhitewagon
Member#: 103068
11 STI sedan
245/40R17 on a 17x8 will not be optimal, don't go past a 235 on that wheel width. It gets sloppy unless you run a short walled tire like 245/35R17 which is really for track or autox use. I've run it before.
Originally Posted by flat4LGT View Post
What is the offset?
A wagon will fit 245s, I put 255 R comps under mine. Offset is going to be very important along with alignment specs. The +45 range around -2 deg camber is where it fits well for most people with a fender roll.
If you are trying to do this with only springs, it may be slightly painful because of camber adjustments that will be necessary. You might want to consider something more conservative like 8"+45 with 235/40R17 with rolled rear fenders.
Nasty, but whatever you want. 9" with 215 is not within recommended ranges. 215 is a 7-8" wheel width tire. 9" should have 235 to 255s on it. 245/40R17 actually works really well for the wagon. The offset of that wheel is a little low and you should see if you can find something with a slightly higher offset if possible (around +45, yes 7mm matters if you want to get technical). Fender mods depend on your alignment settings. Rolled flat rears is a requirement. Rolling the fronts is not a bad idea.
Old 02-07-2013, 01:23 PM   #1824
rymaggi
Member#: 253442
Originally Posted by rymaggi View Post
Anyone?
rymaggi is offline   Reply With Quote
Old 02-07-2013, 01:59 PM   #1825
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
2006
WRX Wagon
Wheel Brand: Rota Grid
Wheel Size: 17x9 +42
Tire Brand: Toyo Proxe 4 ??
Tire Size: 245/40/17 ??
Suspension: Coilovers F Camber plates, Rear Camber bolts, 22mm Sways, ALK Kit, RCA Kit
Alignment: Not Sure ?? Some Help ??
Fender Mods: Rolling Pulling: Im guessing Rolled flat all around ?? Pull ??
Kinda looking for Answers/Opinions on the "??" spots. Will i need camber plates in the back also
Yes, the 17x9 +42 will fit. Depending on how low you are, the 245/40s will not fit in the rear without a roll and pull. Depending on the amount of camber you run in the rear, you may have some inboard clearance issues especially with that wide and tall of a tire.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
