Old 02-07-2013, 04:08 PM   #1826
sc00by4life
Member#: 97135
Originally Posted by rymaggi View Post
Searching. It helps. That's one of the most common 9" wheel/tire combos.
Old 02-07-2013, 04:10 PM   #1827
sc00by4life
Member#: 97135
Originally Posted by wagon_war View Post
I am trying to do a 17x9 et38. On a 02 wagon what fender mods am I looking at with a 215/40
With that width/offset, that little tire will look gay as ****. Especially if you aren't fender on rim low.
Old 02-07-2013, 07:06 PM   #1828
wagon_war
Member#: 320092
02 WRX WAGON
So 225/40 atleast for that width rim ? And expect rolling and/or a slight pull on my fenders? I'm going for a flush/stretched look???? But not trying to run a lot of negative camber
wagon_war is offline   Reply With Quote
Old 02-07-2013, 07:40 PM   #1829
littlewhitewagon
Member#: 103068
11 STI sedan
I will first start by telling you that unless you know exactly what you are doing, you are going to go down a road you can't afford. Most tire shops won't even be able to mount a 215 on a 9" wheel.
littlewhitewagon is offline   Reply With Quote
Old 02-07-2013, 09:27 PM   #1830
rymaggi
Member#: 253442
Originally Posted by flat4LGT View Post
Yes, the 17x9 +42 will fit. Depending on how low you are, the 245/40s will not fit in the rear without a roll and pull. Depending on the amount of camber you run in the rear, you may have some inboard clearance issues especially with that wide and tall of a tire.
Thank you for the reply. Guy just sold his wheels. So now I'm looking at 18x8.75 +35 with 225/40/18.
Would like to be somewhat flush but not ass on ground flush. Fit with a roll. Or will I need that dreaded pull?
rymaggi is offline   Reply With Quote
Old 02-07-2013, 10:19 PM   #1831
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
+35 you'll need a pretty substantial pull. For reference, my offset is +48 on an 8.5 and I only needed a roll. So you're almost a half inch further out on the offset with a slightly wider wheel. Pull will be necessary at least in the rear.
For reference here's how mine sits.
flat4LGT is offline   Reply With Quote
Old 02-08-2013, 02:23 AM   #1832
ProjectMonkey
Member#: 340145
Default Side View
By any chance you post a side view of you car!!! This can kinda help with the fitment you are explaining!! Thanks.
ProjectMonkey is offline   Reply With Quote
Old 02-08-2013, 11:06 AM   #1833
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
I'm not sure what you mean by "side" since that is the side view.
Here's a few rear views to give an idea of how the wheel fills out the arch.
Old 02-08-2013, 11:06 AM   #1834
wagon_war
Member#: 320092
02 WRX WAGON
I am researching and basing the setup I Think I want off fellow members cars. By asking on Diffrent setups I will know what to expect on pricing and fitment
Old 02-08-2013, 11:09 AM   #1835
wagon_war
Member#: 320092
02 WRX WAGON
If I wanted more tire/wheel stretched out of the fender I would need to drop in offset????
Old 02-08-2013, 11:17 AM   #1836
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
Yeah. You would need to go with a lower offset. Something into the +35-40 range would give a bit more poke. I'm also running -2* of camber in the rear otherwise it would be a little more flush.
Old 02-08-2013, 11:31 AM   #1837
wagon_war
Member#: 320092
02 WRX WAGON
I expect to roll My fenders and a slight pull But Nothing far enough to distort My fenders I was thinking 17x9 et38 depending on allignment and ride height......how well do your 4pot brakes work over your stockers????? Just curious
Old 02-08-2013, 01:46 PM   #1838
ode
Member#: 312864
Hello!
Do you think this will work.
2004
WRX Wagon
Wheel Brand: BBS
Wheel Size: 19x8.5 +30
Tire Brand: ?
Tire Size: 235/35/19
Suspension: Bilstein Coilovers, Front+Rear Camber bolts
Fender Mods: Sedan front fenders
ode is offline   Reply With Quote
Old 02-08-2013, 02:38 PM   #1839
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
Not even close
Old 02-08-2013, 06:21 PM   #1840
barrywrx
Member#: 146992
2011 wrx
swp
year: 2011
model:wrx
wheel model: Varrstoen es2
wheel size/offset: 18x8.5 + 38
tire brand/model: not sure yet
tire size: not sure
suspension: stock
alignment: None
fender mods: none
spacers: no
Will they fit?
barrywrx is offline   Reply With Quote
Old 02-08-2013, 07:31 PM   #1841
rymaggi
Member#: 253442
Originally Posted by ode View Post
Hello!
2004
WRX Wagon
Wheel Brand: BBS
Tire Brand: ?
Google rumble wagon. She did it. Looks great. I see wagons all the time with that wide of wheels. They look to fit nice. I'm sure a roll and pull in rear. With some good camber.
Only thing I don't get is, getting which tire size, with different variables ( different wheel widths with different offsets )
Old 02-08-2013, 08:28 PM   #1842
sc00by4life
Member#: 97135
rumble's fitment isn't what was posted.
19's might be a problem depending on height, but otherwise a roll all around should suffice.
Old 02-09-2013, 01:38 AM   #1843
ode
Member#: 312864
Its pretty close to rumble setup. The reson to go with this setup is because I have those wheels at home. And its good lightweight and also expensive set of wheels.
Old 02-09-2013, 11:21 AM   #1844
chocolate
Member#: 296165
please follow this format:
year: 2002 - 2003 or 2006 - 2007
model: wrx
wheel model: bbs rc
wheel size/offset: et38
tire size: 225/40/18
suspension: stock
fender mods: no
spacers: no
I plan on buying a wrx in the near future and was wondering if these wheels would fit. They are from a Jetta Gli. I don't know if I will need cone lugs, whether the hub will match the rim or whether I will have clearance issues in the rear or front while turning. Anyone know what I will need? And/or which wrx year it would fit best 2002 or 2006? I also don't mind changing tire size if needed as long as it doesn't mess up mileage or suspension
chocolate is offline   Reply With Quote
Old 02-09-2013, 02:09 PM   #1845
Romp_
Member#: 343207
year: 2013
model: wrx 5-door
wheel model: Rota G-Force
wheel size/offset: 18x9 / 5x100 / E35 / 73
tire size: 255/35/18 Hankook V12
suspension: stock
fender mods: no
spacers: no
Romp_ is offline   Reply With Quote
Old 02-09-2013, 02:12 PM   #1846
sc00by4life
Member#: 97135
model: wrx
wheel model: bbs rc
suspension: stock
fender mods: no
spacers: no
Jetta's use a different seat for the lugs (well they use studs actually). and you didn't post the actual sizes of the wheels.
just knowing they are coming off a VW, I'm going to venture to say they wont fit.
Old 02-09-2013, 02:28 PM   #1847
chocolate
Member#: 296165
Thanks for the reply the wheels bolts are 5x100 and the size is 18x7.5. Looks like the hub core is 1mm bigger. Does anyone know where I can get a hub centric ring from 56.1 to 57.1? I cannot seem to find it online.
Old 02-09-2013, 05:32 PM   #1848
sc00by4life
Member#: 97135
Yes....spacing is the same....but the lug seat is completely wrong.....
You still haven't told us sizes to know if they'll clear your brakes.
Slow down, before you buy the wrong parts.
And 1mm hub rings do not exist. Do you know how small that is?
Old 02-09-2013, 10:08 PM   #1849
fedex23
Member#: 133204
2006 WRX TR CGM
356hp/403tq... FTW tuned
Deleted
fedex23 is offline   Reply With Quote
Old 02-10-2013, 03:26 PM   #1850
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
year: 2006
model:WRX Wagon
wheel model: Rota MXR
wheel size/offset: 18x9.5 + 38
tire brand/model: Kumho Ecsta XS
tire size: 245/35/18
suspension: BC BR Coils with only front camber plates
alignment: currently -1.75* front and -2* (natural) rear
fender mods: aggressive roll in the rear, no pull yet (but I know I'll have to)
spacers: no
My biggest question is the "how" of modifying the front fenders. How do I roll the fronts and what do I do about the fender liners. I've done a bit of searching around and all I can find is "I trimmed the fender liners" or "I removed them" but no one has set forth a "how to" so I was hoping someone here could put an end to that search for me.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
