Old 02-15-2013, 11:04 PM   #1876
Sn00zr
Member#: 161860
2004 STI
JBP
Originally Posted by sc00by4life View Post
i think you mis-read.
Properly fitting FLARES. not stock body.
18x10.5 +18ish would be perfect. Plenty of guys have run 18x10 +0 wheels w/ 275-285's with s13 flares.
Ya. Specifically speaking Karlton Flares. I am looking at THESE but gotta sell my TE37 first.
Sn00zr is offline   Reply With Quote
Old 02-15-2013, 11:17 PM   #1877
d0ughb0ii
Member#: 347190
Originally Posted by TokyoHero View Post
year: 2002
model: WRX WAGON
Wheel style: Rota G force flat black WRBlue pin strip
wheel size: 18x9
wheel offset: +35
tire size: 235/40
suspension: raceland coilovers
fender mods: rolled and pulled front and rear rolled. Soon sedan swap fenders. Just bought a parts car.
Those wheels look sick. Lovin the car too
d0ughb0ii is offline   Reply With Quote
Old 02-16-2013, 02:00 AM   #1878
Streetslappah
Member#: 337127
05 STI
Wrb
Sup fellas I'm new here and looking into some wheels and wondering about the fitment... I want wheels to be aligned with the fenders sorta flush!
2005
STi
Rota grid or xxr522
17x9+42 or 18x8.5+48
tire size: 235/40?
suspension: apexi coilovers
fender mods: hopefully not maybe a roll?
spacers: no
Thanks appreciate it!
Streetslappah is offline   Reply With Quote
Old 02-16-2013, 10:39 AM   #1879
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
Either of those should fit pretty easily with maybe a roll and a tad bit of negative camber.
flat4LGT is offline   Reply With Quote
Old 02-16-2013, 12:33 PM   #1880
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by CarverSnell View Post
Wheel model: Drag DR-31
Wheel size/offset: 17x9 +38
Tire brand/model: Goodyear ???
Tire size: 235
Suspension: H&R Springs, KYB AGX struts
Alignment: ???
Fender mods: maybe slight fender roll in rear.
Spacers: None.
Figured most of this stuff out. How does it look to everybody?
You're going to need a full roll in the rear. Those springs are too soft for that low of an offset.
Originally Posted by QwaktastiK View Post
So my question is:
I'm considering switching to WORK XD9 18x10 +38...
How much more will these poke?
Half of an inch is 12.5mm. So that's my guess. But according to http://www.rimsntires.com/specs.jsp, there is no change (given i run the same size tires) Is that right?
http://www.1010tires.com/WheelOffsetCalculator.asp
Yup, you're looking at 13mm further out.
Originally Posted by Gillsby View Post
year: 2006
model: wrx
wheel model: xxr 518
wheel size/offset: 18x7 or 18x8x8 not sure on ofset
tire brand/model: not sure
tire size: need suggestions
suspension: KYB shocks & struts, H&R OE Sport Springs .75 front/.5 rear
alignment: needs one.
fender mods: none atm would roll possibably but dont want to
spacers: no
hey guys. i trashed a wheel the other day and figured it was time to get a new one. so i figured i would buy 4 new ones. i really like the looks of the xxr 518s but not sure if i can get them to fit easly. they come in 18x7 and 18.8.5. will they fit with normally sized tires and if so what size.
thanks
18x7 not even once. That would be the biggest waste of money ever. Stick with 18x8 or 18x8.5 +45 to +48 with a 225/40/18 or 235/40/18.
2005
STi
Rota grid or xxr522
tire size: 235/40?
spacers: no
17x9 +42 will require a rear roll, 18x8.5 +48 won't. You can figure out which one is more flush to the fender knowing that.
Old 02-16-2013, 01:57 PM   #1881
CarverSnell
Member#: 256218
2004 Impreza WRX
FP Black, 380whp
What do you mean "full roll".
CarverSnell is offline   Reply With Quote
Old 02-16-2013, 02:11 PM   #1882
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by Romp_ View Post
year: 2013
model: wrx 5-door
wheel model: Rota G-Force
wheel size/offset: 18x9 / 5x100 / E35 / 73
tire size: 255/35/18 Hankook V12
suspension: stock
fender mods: no
spacers: no
Is that what you want? Or is this your current setup?
And 1mm hub rings do not exist. Do you know how small that is?
I'd like to see a 0.5mm thick ring
Old 02-16-2013, 04:13 PM   #1883
Streetslappah
Member#: 337127
05 STI
Wrb
Thanks nhat and flat4 I'll be going with the grids most likely I'll post pics after installed too
Old 02-17-2013, 04:25 AM   #1884
spacecowboy13
Member#: 309066
2003 WRX
Midnight Black
Model: 2003 WRX sedan
Wheel model: Rota Grid
Wheel size/offset 17x8/5x100/ +38 / 56.1
Tire size: 225/45R17 N5000
Suspension: stock; but order coilovers
Fender mods: none
Spacers: no
Will they fit without any issues, +38 without fender mods? Or better off staying with +44
spacecowboy13 is offline   Reply With Quote
Old 02-17-2013, 10:43 AM   #1885
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
On an 8" wide wheel, you're probably better off sticking with the +44 if you want to avoid fender mods.
Old 02-17-2013, 11:36 AM   #1886
spacecowboy13
Member#: 309066
2003 WRX
Midnight Black
The wheels I have know are 17x8 +44 offset. I like how they look, but would like a little more flush look. So running +38 I would need to roll the rear fenders, which is not a big deal. Or could I get away with it on stock suspension?
Old 02-17-2013, 01:45 PM   #1887
nhat
Member#: 140163
03 STi
hellaflunctional
Here's an idea: grab a ruler, go outside to your car, measure from the outer edge of your tire to the inner edge of the fender lip, and you'll have your answer.
By thew way, flush and stock don't go together. What's with all these people wanting to be flush without rolling fenders and/or on stock suspension
Old 02-17-2013, 01:53 PM   #1888
spacecowboy13
Member#: 309066
2003 WRX
Midnight Black
Well if you read everything, I'm not worried about rolling my fenders! Was wondering if I could get away with them on while I wait for my coilovers to get here!
Old 02-17-2013, 02:48 PM   #1889
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
+38 with only an 8" wide wheel is going to put added stress on your wheel bearings. For comparison, I'll be running the same offset with a 9.5 in a couple weeks when I get everything ready for install.
Old 02-17-2013, 05:07 PM   #1890
nhat
Member#: 140163
03 STi
hellaflunctional
Technically, yes. But there's very little evidence to support it.
Old 02-17-2013, 05:45 PM   #1891
CarverSnell
Member#: 256218
2004 Impreza WRX
FP Black, 380whp
Thanks for the clarification!
Old 02-17-2013, 07:06 PM   #1892
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
True, basic physics says it should put extra stress on the wheel bearings, but there haven't been any real "scientific" tests to prove or disprove this.
Old 02-17-2013, 10:07 PM   #1893
Omegared99
Member#: 277965
2007 WRX
Grey
year:07
model:WRX
wheel modelrag DR31
wheel size/offset:18 +55
tire brand/model:Unsure 240/40
tire size:18
suspension:stock
alignment:Stock
fender mods:none
spacers: yes/no? unsure
Omegared99 is offline   Reply With Quote
Old 02-17-2013, 10:15 PM   #1894
A.childress
Member#: 324437
2007 Impreza
I have probably a noobish question so I apologize, and I am honestly not sure if this goes here. But I looked around for it, and all I see are fitments for the STi, not base imprezas and I want to be 100% clear on things is all
This is my current car. It is just a regular stock Impreza. no STi or wrx
year: 2007
model: Impreza
wheel model: 16 x 6.5 in.
wheel size/offset: Stock (No clue)
tire brand/model: Michelin (not sure exactly)
tire size: stock
suspension: stock
alignment: stock
fender mods: stock
spacers: stock
long story short I lost a tire and damaged the rim so I want to put new ones on.
Is it possible to put something like a 17 x 8.0 in. wheels with 245/40R18 93W tires (stock 07 STi) or 18 x 8.5 in. wheels with 245/40R18 93W tires (stock 13 STi) without having issues with putting them on?
I am just afraid of clearance issues as the tires are new sizes, but I have heard of people putting tires like this onto their cars. Just trying to see if some modification is needed or if they do bolt on and work just fine as it is.
Thanks for any help in advance.
A.childress is offline   Reply With Quote
Old 02-17-2013, 10:26 PM   #1895
fedex23
Member#: 133204
2006 WRX TR CGM
356hp/403tq... FTW tuned
year: 2007
model: Impreza
tire size: stock
suspension: stock
alignment: stock
fender mods: stock
spacers: stock
07 STI & 13 STI wheels are 5x114.3. You are 5x100. I'll let someone else handle the tire question.
fedex23 is offline   Reply With Quote
Old 02-18-2013, 12:33 AM   #1896
nhat
Member#: 140163
03 STi
hellaflunctional
An 18" tire isn't going to fit on a 17" wheel.
Your base Impreza isn't any different body-wise from the WRX and STi.
Old 02-18-2013, 03:09 PM   #1897
Filthiest
Member#: 306861
2006 sti
wrb
year: 2006
model: sti
Wheel style: klutch sl14
wheel size: 18x9.5
wheel offset: +30
tire size: unknown 255/35 or 235/40
suspension: isc n1 coilovers
fender mods: soon to be rolled and pulled
what tire size do you recommend?
Filthiest is offline   Reply With Quote
Old 02-18-2013, 03:13 PM   #1898
bboylocob
Member#: 151809
2007 WRX
Originally Posted by Filthiest View Post
year: 2006
model: sti
wheel size: 18x9.5
wheel offset: +30
245 probably fit better
bboylocob is offline   Reply With Quote
Old 02-18-2013, 03:36 PM   #1899
nhat
Member#: 140163
03 STi
hellaflunctional
year: 2006
model: sti
wheel size: 18x9.5
wheel offset: +30
Depends on what you use your car for and what your aesthetic tastes are. Do you prefer more tire or less? Are you aiming to be slammed or just low enough?
Better than? A 245/40/18 won't fit better than either of the sizes he listed. A 245/35/18 will only be easier to fit than the 255/35/18 simply because it's 10mm narrower.
Old 02-18-2013, 03:44 PM   #1900
bboylocob
Member#: 151809
2007 WRX
It would only be common sense to run a 245/35 vs. A 245/40.
How much of a pull u willing to do.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
