Old 02-18-2013, 05:25 PM   #1901
KoreystWRX
Member#: 186324
Aspin White w/ 05 face
Some help please guys.
year: 2002
model: WRX
Wheel style: Varrstoen es3
wheel size: 18x9.5
wheel offset: +34
Tires: 225/40/18
suspension: raceland coilovers Ultimo
front finders rolled and pulled rears rolled slight pull.
anyone know what to do to keep from rubbing suspension? i cant camber that much out of them due to rubbing. I have camber bolts all around and can get up to -3 maybe more but they rub like crazy on the coilover. anyone thats got any ideas help out please.
KoreystWRX is offline   Reply With Quote
Old 02-18-2013, 05:26 PM   #1902
GnosisAdvent
Member#: 345624
year: 2004
model:WRX Wagon
My problem is that I am a noob when it comes to wheels and tires. I've never had a vehicle worth looking into them for. So my question is what are the stock measurements and I am trying to google what they mean as I see them, but if someone has a good explanation it would be quite helpful. I want to upgrade my rims to something nicer looking and maybe slightly lower profile by like an inch or two, but nothing too extreme. I'm not looking to mod my suspension or body yet, just want to get some nice black rims without compromising anything else. So comments and suggestions would be appreciated. Beratements and informing me that I am a noob (which I know) and should search more (which hasn't been much help so far but I am just starting) will not really be appreciated, but hey, free speech and all that so have at it. Anyways, thanks for any help you guys can give me.
wheel model:
wheel size/offset:
tire brand/model:
tire size:
suspension:
alignment:
Suggestions for rim types and sizes:
GnosisAdvent is offline   Reply With Quote
Old 02-18-2013, 05:53 PM   #1903
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by bboylocob View Post
It would only be common sense to run a 245/35 vs. A 245/40.
How much of a pull u willing to do.
It would be if one wanted to maintain the stock diameter but the tire selection in 245/35/18 pales in comparison to 245/40/18.
year: 2002
model: WRX
wheel size: 18x9.5
wheel offset: +34
Tires: 225/40/18
How are you dialing in -3* of camber at the knuckle? Why do you need more than -3* of camber? That setup doesn't require nearly that much camber to clear the rear fenders if they're rolled and slightly pulled. I've got more wheel and tire (17x10 +38 with 255/40/17s) than your setup and I don't rub at all anywhere while running less than -3* of camber all around (-2.5* and -1.7*) with only my rear fenders rolled and slightly pulled. My front fenders are still untouched.
Originally Posted by GnosisAdvent View Post
year: 2004
model:WRX Wagon
wheel model:
wheel size/offset:
tire brand/model:
tire size:
suspension:
alignment:
We can't help you unless you determine a budget for yourself. That's first and foremost.
Start here (skip past service type): http://www.tirerack.com/tires/tirete....jsp?techid=46
Then go here: http://www.tirerack.com/tires/tirete....jsp?techid=25
Then go here: http://www.cars101.com/subaru/impreza/wrxsti2004.html
Then determine a budget for yourself.
And then, we might be able to help. Also, check out Member's Car Gallery so you can look at all the wheels in the world on Subarus.
Old 02-18-2013, 06:08 PM   #1904
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
year: 2004
model:WRX Wagon
wheel model:
wheel size/offset:
tire brand/model:
tire size:
suspension:
alignment:
Like nhat suggested, determine a budget, then determine a style you like (5 spoke, 6 spoke, mesh, etc.) and find wheels in your price range.
Point of advice since you're a noob to this, read a ton. For now, I would stick with an easy fitment and as you grow more comfortable with the platform (through your reading and research) you can start to push the limits. 17 or 18x8 wheels with an offset between 48 and 53 should fit with no problem with a 225/40 tire.
flat4LGT is offline   Reply With Quote
Old 02-18-2013, 06:14 PM   #1905
Filthiest
Member#: 306861
2006 sti
wrb
Originally Posted by nhat View Post
Depends on what you use your car for and what your aesthetic tastes are. Do you prefer more tire or less? Are you aiming to be slammed or just low enough?
Better than? A 245/40/18 won't fit better than either of the sizes he listed. A 245/35/18 will only be easier to fit than the 255/35/18 simply because it's 10mm narrower.
i prefer more tire. i dont like the streched look but a little bit is ok.
car is daily and occasional autox but i drive aggressive and do lots of road carving.
As long as i can keep the stock over fender in rear and not flare out. front are no limit.
245/35 isnt too common and i dont know how it would compare to 255/35. 255/35 is pretty common but it looks like there alot of work needed. what you guys think?
im not trying to be SLAMMED and lose performance since my car is "functional" as well so it will be low enough to be no wheel gap but probably not tucked.
Filthiest is offline   Reply With Quote
Old 02-18-2013, 06:27 PM   #1906
Omegared99
Member#: 277965
2007 WRX
Grey
Originally Posted by Omegared99 View Post
year:07
model:WRX
wheel modelrag DR31
wheel size/offset:18 +55
tire brand/model:Unsure 240/40
tire size:18
suspension:stock
alignment:Stock
fender mods:none
spacers: yes/no? unsure
Will these wheels fit on my car?
Omegared99 is offline   Reply With Quote
Old 02-18-2013, 07:03 PM   #1907
nhat
Member#: 140163
03 STi
hellaflunctional
Those are S2000 spec wheels. 18x9 +55? Too high of an offset to clear the rear struts.
Old 02-18-2013, 07:25 PM   #1908
KoreystWRX
Member#: 186324
really im not sure im still a noob to fitments. I placed the rim on the hub and it poked out past the finder about 3/4 of an inch. although on the inside of the wheel well the rim is about an inch from the coil over and im not sure why. Im worried i wont be able to camber it at all if its that close. I have camber bolts in the rear and from what the guy said when he did my alignment is i was at -4 but something tells me there a little off. not to mention with the other side i was at -7 at one point. (on camber bolts only) if you could pm and maybe give me a little more advise that would be great.
Old 02-18-2013, 08:00 PM   #1909
bboylocob
Member#: 151809
2007 WRX
Check out the federal tires. They are great tires and cost friendly
bboylocob is offline   Reply With Quote
Old 02-18-2013, 11:08 PM   #1910
no12nv
Member#: 326934
Originally Posted by under0athh51189 View Post
i like this thread already. only addition would be maybe wheel and tire brand and model.
year:2005
model:wrx
Wheel model: Miro Stp1
wheel size:18x10
wheel offset:+25
Wheel brand/model: falken ziex 912
tire size:225/40/18
suspension:megan street coilovers upgraded 135mm 10k fronts to go lower, 6k rear
fender mods:rolled and pulled front and rear, no fender liners, tucked harnesses, blow torch and hammer front fender tubs to not rub
Camber: -3.5f -4.5r
Spacers: no, but for brembos you need a 5mm spacers to clear.
omg this thing excites me in the pants :P what off set u running ?
no12nv is offline   Reply With Quote
Old 02-18-2013, 11:09 PM   #1911
no12nv
Member#: 326934
sorry mate i just seen it didnt read it proply lol still this thing is hot :P
Old 02-19-2013, 12:06 AM   #1912
GnosisAdvent
Member#: 345624
How does a budget affect what size the stock wheel well and suspension can handle without modification?
I want to stay very close to stock sizes when it comes to circumference/outside diameter and width of the actual rubber. Just some nicer looking rims that may be larger in diameter than the stock ones, but that don't use tires that are any bigger on the outside edge. Does that make any sense?
I know how to research, and those links are helpful, and I appreciate them. I've learned something new about tires. But I mostly need help understanding what fits on the 04 wrx without modification so I can pick and choose myself what rims I want.
Old 02-19-2013, 12:11 AM   #1913
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
Old 02-19-2013, 12:17 AM   #1914
GnosisAdvent
Member#: 345624
Yeah I was just reading that actually. I missed it before replying to nhat. Thanks for pointing me back to it though.
Edit:And thank you very much for the information, that's exactly what I was looking for.
Old 02-19-2013, 04:48 PM   #1915
d0ugch0i
Member#: 198861
2004 WRX
i posted and no one has helped me out....
2004 WRX Sedan
BC Coilovers
F/R rolled
Rota Grids 18x9.5 +38
im planning on getting 225/40/18 Federal 595SS tires. what are you guys' input on this? i want the fender to sit right above the tire so i have no wheel gap. i know i might have to slightly pull my rear fenders. im going to get my alignment done as well; i need to get new tires.
d0ugch0i is offline   Reply With Quote
Old 02-19-2013, 05:36 PM   #1916
nhat
Member#: 140163
03 STi
hellaflunctional
2004 WRX Sedan
BC Coilovers
F/R rolled
You won't have to pull any fenders to fit a 225/40/18 stretched on an 18x9.5 +38. You'll have to go lower than having the fenders right above the tires in order for this to not look silly.
Old 02-19-2013, 09:13 PM   #1917
John1john
Member#: 347613
2008 WRB WRX Hatch
AVO450-421whp e85
hey guys i could use some help here. Ive searched this thread for about 20 min and found little information on the 08 wrx and the wheel fitment i want.
i was thinking about going with
Year: 2008
Model: WRX Wagon
Wheel Brand: Rota Grid
Wheel Size: 18x8.5 +44
Tire Size: 235/35/18 or 235/40/18
Suspension: stock but will prob be going with swift or STI SPT lowering springs
Fender Mods: stock but can do a fender roll. Dont like that hella flush look, trying to stay away from changing camber
So with all this being said do you guys think that i can pull this off in an 08 with some fender modification like rolling them? Any input would be appreciated!
John1john is offline   Reply With Quote
Old 02-20-2013, 12:23 AM   #1918
nhat
Member#: 140163
03 STi
hellaflunctional
Year: 2008
Model: WRX Wagon
Your answer lies here: http://forums.nasioc.com/forums/show....php?t=1945625
You'll need a combination of fender work and negative camber.
Old 02-20-2013, 03:57 AM   #1919
fredster818
Member#: 313855
2005 Subi STi
year: 2005
model:05 WRX Sti
wheel model: Volk Ce28s
wheel size/offset: 18x8.5 + 40
tire brand/model: ???
tire size: ??
suspension: Tein SS Coilovers not yet installed (on order)
alignment:
fender mods: will I need to?
spacers: no
need help on tires to get and size?
also will I need to roll my fenders. Thank you
fredster818 is offline   Reply With Quote
Old 02-20-2013, 04:59 AM   #1920
j.frank
Member#: 265410
2003 WRX
Year: 2003
Model: Wrx
Wheel Model: rota g-force
Wheel offset/size:18x9+38
Tire brand: Continental dws
Tire size: 245/40/zr18
Suspension: Tanabe springs coils soon
Alignment: stock
Fender Mods: Mild roll in rear
j.frank is offline   Reply With Quote
Old 02-20-2013, 01:08 PM   #1921
KB_06STi
Member#: 308254
2006 STi
Can anyone help!
Rims I'm planing on getting is TE37 for my 06 sti. What would be the best flush look for this car? I really wanted 17x9's. Thanks
KB_06STi is offline   Reply With Quote
Old 02-20-2013, 03:33 PM   #1922
ABeastinWRX
Member#: 239469
2004 WRX
Originally Posted by KB_06STi View Post
Can anyone help!
Offset? Suspension? Tire?
ABeastinWRX is offline   Reply With Quote
Old 02-20-2013, 03:34 PM   #1923
ABeastinWRX
Member#: 239469
2004 WRX
2004 WRX Sedan
BC Coilovers
F/R rolled
What do you want to know?
Old 02-20-2013, 06:15 PM   #1924
KB_06STi
Member#: 308254
2006 STi
That's the thing. What would be set for me? That's what I'm asking. What offset and tire?
Old 02-20-2013, 06:16 PM   #1925
KB_06STi
Member#: 308254
2006 STi
Tein coilovers.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 04:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 02:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 02:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 04:54 PM
