Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 03-03-2013, 10:41 PM   #2026
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by fl4twrx View Post
Why does it suck?
Limits your tire size. Maximum recommended tire width is a 225, which is OK if that's all you'll ever want.
Old 03-04-2013, 12:23 AM   #2027
wrx2630
Member#: 290232
2011 STI Sedan
Originally Posted by nhat View Post
Grab a ruler, walk out to your car, measure 5mm from the outer edge of your tire.
I don't know which post is worse: yours or his. At least he has a set offset in mind. You're asking about a wide range of offsets with 2 different width wheels.
let me re phrase it.
My car is stock height and no fender mods, I dont want to do any fender mods, would a 18x8.5 with a offset of +50 or 189.0 with +55 need any fender mods.
and would they fit a 245/40/18 tire?
wrx2630 is offline   Reply With Quote
Old 03-04-2013, 12:40 AM   #2028
sc00by4life
Member#: 97135
18x9 +55 most likely wont fit. offset is too high for the width of the wheel. With wheels 9"+ you want offsets in the mid 40's.
18x8.5 +50 would be fine.
Old 03-04-2013, 08:10 PM   #2029
SupaDoopa
Member#: 285304
2008 STi
So. I'm openly anticipating being flamed. Let's get that off our chests. I own a 2008 STI. Right now it has 18x8.5 +40 TE's and coming from a FD and other RWD cars, I'd like something a little more aggressive. I was wondering if a 18x10 +25ish would fit. If not, what modifications would need? Just a roll? Maybe a pull? I've searched quite a bit and some say it works, others say it doesn't. I want a wheel with proper offset to clear the brembos but still be a nice aggressive width and offset.
Flame on if you want or maybe be helpful if you want. The choice is yours. Thanks in advance.
EDIT: P.S. I will be lowered on BC's.
SupaDoopa is offline   Reply With Quote
Old 03-04-2013, 08:25 PM   #2030
nhat
Member#: 140163
03 STi
hellaflunctional
Which wheels are you asking about? Also, what tire size are you looking to run? You could be asking about 18x10 +25 TE -37s but I can't be sure.
Old 03-04-2013, 08:44 PM   #2031
SupaDoopa
Member#: 285304
2008 STi
The wheel make and model really aren't a concern. Just wondering what's the most aggressive sizing I can throw on a 08 without having to pull the fenders to oblivion. I am looking for a size I can roll and maybe SLIGHTLY pull but will be the most aggressive size. If I can find a low offset 18x10, I'd love to. If anyone has experience with throwing 18x10's on a 08 STI or any STI hatch for that matter, that would be amazing.
But as for the wheel I was thinking about, Emotion CR Kiwami's.
Old 03-05-2013, 01:56 PM   #2032
nhat
Member#: 140163
03 STi
hellaflunctional
It depends on tire size and alignment.
Also, this thread will help http://forums.nasioc.com/forums/show....php?t=2155863
Also, search and browse threads here and in Member's Car Gallery.
Old 03-05-2013, 03:14 PM   #2033
SupaDoopa
Member#: 285304
2008 STi
I don't really mind stretching a tire alongs it isn't ridiculous. I am coming from the RWD world where stretching was no big deal and done more often than not. I just want to make sure that I'm not having to call a body shop to pull my fenders because that's what it will take.
Old 03-05-2013, 06:59 PM   #2034
dIrTy-StI
Member#: 322280
2002 Subaru WRX
Default Need a little bit of help with tires+rims
I have want to change to larger rims for my 2002 wrx. I was looking at 17 inch xxr's that are 7 wide. I want to be able to run a tire that is a dedicated summer tire that is decent in the rain but will be only used during the warm weather. I would like to put a 235 wide tire on the rims and i do not want to roll or alter my fenders. I need help with the offset too, i have read the stickies and many threads but i would like to ensure that i am doing this the correct way since i have never bought rims or tires and i dont have a ton of cash to play with.
Thanks,
Thomas
dIrTy-StI is offline   Reply With Quote
Old 03-05-2013, 07:54 PM   #2035
bboylocob
Member#: 151809
2007 WRX
Thanks,
Thomas
Might want to think of a wider wheel. A 7inch is pretty small. And a 235 on a 7inch is retarded. I put 235 on my 17x7.5 and thought it was retarded. Now i have 18x9 with 235 and wish i would have went with the 245.
Go with a 215 for the 17x7 offset probl. A 45-48 would be good.
bboylocob is offline   Reply With Quote
Old 03-05-2013, 07:58 PM   #2036
dIrTy-StI
Member#: 322280
2002 Subaru WRX
ok what if i want to run a wider tire what size rim should i get?
Old 03-05-2013, 08:01 PM   #2037
bboylocob
Member#: 151809
2007 WRX
Atleast do a 17x7.5 with a 225 or if ur set on the 235 u can put a 235 on a 17x7.5.
Old 03-05-2013, 08:23 PM   #2038
dIrTy-StI
Member#: 322280
2002 Subaru WRX
would an 8 inch wide rim not fit without modifications to the fenders?
Old 03-05-2013, 09:58 PM   #2039
sc00by4life
Member#: 97135
i wouldn't recommend a 235 on anything less than an 8" wheel.
Old 03-05-2013, 10:07 PM   #2040
dIrTy-StI
Member#: 322280
2002 Subaru WRX
ok so will the 8 inch wide wheel fit under my fender with out any issues?
Old 03-05-2013, 10:18 PM   #2041
nhat
Member#: 140163
03 STi
hellaflunctional
Just look through this thread and you'll find your answer.
Old 03-05-2013, 10:34 PM   #2042
czarrr
Member#: 343937
8 could easily fit. It all comes down to the offset and tire size.
czarrr is offline   Reply With Quote
Old 03-05-2013, 10:57 PM   #2043
dIrTy-StI
Member#: 322280
2002 Subaru WRX
ok ill post back when i figure it out but my choices are a 17x8 XXR 522 with a 48mm offset or a 17x8 Rota G-Force with a 48mm offset, and maybe ROTA GRID 2 17X8 with a 38 mm off set
Old 03-05-2013, 11:35 PM   #2044
bboylocob
Member#: 151809
2007 WRX
Yea i really dont. I ran that size with a 7.5 with no probls. But its up to the end user
Old 03-06-2013, 01:26 AM   #2045
czarrr
Member#: 343937
You should be just fine with any of those.
I have OEM BBS STI rims (17x8 53 offset) with a 25mm spacer making it a +28 set up. 245 tire.
Old 03-06-2013, 11:30 AM   #2046
nhat
Member#: 140163
03 STi
hellaflunctional
You need to provide full details for this post to have any merit.
Old 03-06-2013, 01:03 PM   #2047
rev_this
Member#: 224690
2007 WRX wagon!
vf48 w/ ugly tail lights
I ran an 18x8 +40 on my wagon and it looked just OK...
Just bought a set of 18x9 +35. Going to squeeze that into my wagon fenders. Gonna roll flat and run -3 with a small pull on all 4 corners. Shouldn't have any issues.
Can't wait to get them back from the coaters.
rev_this is offline   Reply With Quote
Old 03-06-2013, 01:21 PM   #2048
littlewhitewagon
Member#: 103068
11 STI sedan
That is 18x10+40 with a 265 R comp tire on there, measures like a 275-285. My car has rolled rears and the suspension is setup for function.
littlewhitewagon is offline   Reply With Quote
Old 03-06-2013, 01:22 PM   #2049
littlewhitewagon
Member#: 103068
11 STI sedan
It will fit, but you won't be able to run all that much meat on the wheels unless you pull a little. Your wagon will also turn like a turd with that sort of camber setup. Here is my wagon with 9" wheels, +45 offset and 255 R comps. The close up image is before camber adjustments. Wagon was made for function.
Old 03-06-2013, 03:04 PM   #2050
czarrr
Member#: 343937
You're welcome.
OEM STI BBS 17x8 +53 offset rims.
245/40 BFGoodrich tires.
+25mm spacers from JonMotoring. A vendor on Nasioc.
Lowered on BC BR coils.
EDIT for Nhat:
Fenders rolled and slight pull.
It's a meatier tire so an aggressive pull is suggested depending on how low the car is.
I'm 10mm below stock height.
No rubbing or hitting fender liner unless sharp turns and a decent bump/dip.
Alignment specs provided in a day or two. Depending when I can leave the hospital with my new baby daughter
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 04:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 02:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 02:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 04:54 PM
