Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 03-06-2013, 02:21 PM   #2051
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by czarrr View Post
You're welcome.
OEM STI BBS 17x8 +53 offset rims.
245/40 BFGoodrich tires.
+25mm spacers from JonMotoring. A vendor on Nasioc.
Lowered on BC BR coils.
Try again. We need alignment and fender modifications at a minimum.
Old 03-06-2013, 10:50 PM   #2052
ssrow18
Member#: 346349
2002 Subaru WRX
Hello. I have an 02 wrx that I did an 04 sti transmission swap into. This includes the hubs suspension and brembos. I have skunk2 springs on stock struts all around with Tein camber plates on the front. and I am currently running on 18x8 rims offset is 35 with 225x40 tires. My fenders are rolled and pulled in the rear nothing up front yet. I just had it aligned and the camber on the rear is at -1.5 the front is at -0.5. I'm looking to purchase a second set of wheels for track days around the 9.5 range with 245x40 tires. What offset would you recommend and do you think they will rub on this suspension setup? Thanks.
ssrow18 is offline   Reply With Quote
Old 03-07-2013, 09:40 AM   #2053
nhat
Member#: 140163
03 STi
hellaflunctional
I would recommend upgrading your suspension, specifically the springs, and fixing your alignment before looking at new wheels.
Old 03-07-2013, 09:45 AM   #2054
ssrow18
Member#: 346349
2002 Subaru WRX
Ok, thank for your response. What do you see wrong with alignment? And what springs would you recommend?
Old 03-07-2013, 09:59 AM   #2055
bboylocob
Member#: 151809
2007 WRX
U have to much camber in the rear for what suspension u are running and not enough in the front. U need either coils or a good spring and shock combo.
bboylocob is offline   Reply With Quote
Old 03-07-2013, 10:28 AM   #2056
ssrow18
Member#: 346349
2002 Subaru WRX
Camber I can fix easily enough. I guess I knew coils where going to be recommended as that's the way I want to go I just haven't scraped together the funds for it yet. Good to know info though. Now back to original question though when I do get some say BC coils and my camber is addressed what offset would you recommend for 18x9.5 setup?
Old 03-07-2013, 01:02 PM   #2057
nhat
Member#: 140163
03 STi
hellaflunctional
Anything is better than Skunk2. Doesn't necessarily mean coilovers are recommended. Better springs would go a long way.
Why are you set on 18x9.5? If you can't afford a set of BC coilovers, I would recommend sticking with a 17x8 or 17x9 and run a 245/40/17. Same tire size, easier to fit, and far easier on your wallet.
If you're set on getting coilovers and a set of 18x9.5s, a +35 to +40 offset would be ideal. A 245/40/18 isn't though.
Old 03-07-2013, 02:46 PM   #2058
ssrow18
Member#: 346349
2002 Subaru WRX
I'm not set on the 18x9.5 I was reading about several other people going that way for track day thinking this would give me the most traction for my buck. I guess I jumped on the perverbial wheel wagon with them. I'm very open minded to different suggestions and ideas. By the way I do appreciate your candor and suggestions. This gives me a whole new path to follow with the 17x9 and different struts and springs combo. Thanks.
Old 03-07-2013, 03:49 PM   #2059
robotskillhumans
Member#: 155244
06 ice cream sti
year: 2006
Model: STi
wheel model: Rota grid
wheel size/offset: 18x8.5 or 17x9
tire brand/model:Hankook ventus v12
tire size: 235/40 but open to suggestions
suspension: sitting on BC br coilovers with rear camber plates
alignment: stock alignment
fender mods: no fenderwalls, prepared to roll if needed
spacers: yes/no? size? None
I am looking for help deciding what size wheels and tires I should get. I want an aggressive look but I don't want to sacrifice performance. I live in Hampton roads Virginia and the roads are pretty crappy. So please take that into consideration. Thanks.
robotskillhumans is offline   Reply With Quote
Old 03-07-2013, 05:41 PM   #2060
dIrTy-StI
Member#: 322280
2002 Subaru WRX
Alright i think ive figured out what i am going to do with my 2002 wrx. Im going to buy a set of 17x8.25 XXR 527 35mm offset and put on Hankook Ventus V12 Evo K110 235 wide for my tire. Do you guys think this set up will look good and also have pretty good performance from the tires?
dIrTy-StI is offline   Reply With Quote
Old 03-07-2013, 06:05 PM   #2061
nhat
Member#: 140163
03 STi
hellaflunctional
I think it's a good path to take. It'll keep your costs down significantly, especially if you're attending track days. 18s will look better but the general rule is to keep your wheels as small as possible. Only go to 18s if you need brake caliper clearance.
Between the 2, I would opt for the 17x9 every time with a +42 offset +/-3. Then you can run anywhere from a 235 to a 255. You'll need to trim the rear fenders though, can't roll the rear fenders on the '05-07 STi.
Sure.
Old 03-07-2013, 06:10 PM   #2062
dIrTy-StI
Member#: 322280
2002 Subaru WRX
Sure.
ok thanks but im not going to alter the fenders right now since its my first car and dont have any experience doing stuff like that yet
Old 03-07-2013, 06:13 PM   #2063
sc00by4life
Member#: 97135
Then stick to wheels no wider than 8" with an et40-48.
Old 03-07-2013, 06:26 PM   #2064
dIrTy-StI
Member#: 322280
2002 Subaru WRX
Excuse my ignorance but would the 8.25 fit
Old 03-07-2013, 08:01 PM   #2065
nhat
Member#: 140163
03 STi
hellaflunctional
Yes, but not with an offset lower than +45.
Old 03-07-2013, 08:50 PM   #2066
DarkWr8h
Member#: 349417
2006 Imprez Outbk Sp
Regal Blue / Silver
First time Subaru owner with maybe a simple yet dumb question. Wife and I picked up an 06 Impreza OBS SE a week ago. Loving it so far. When asking a service tech on the wheel specs of the new WRX I mentioned I wanted to mount something similar to my wifes 06. The tech then told me not to change the wheel size and tire size and stick to stock as it will mess/damage the transfer case or rear differential. He told me he gets people going in all the time for this type of repair due to the wheels people install on their Subaru's and how costly it is.
I also questioned him if I would be able to keep the same outside rolling diameter I would be fine and he still stated no because my wheels were built and designed around the car. Now I never heard of not being able to upgrade on wheels on a car even if I was to go with stock wheels from say another model of the same chasis. I have seen many pictures of the 06 WRX wheels on the 06 Outback Sport SE as well as other make/brands being placed on wagons on here as.
Now offset I am familiar with and staggered being a no no is a no brainer but am I being fed bull**** or is he correct? I can see where the wheels may be designed around the car but to not be able to upgrade? I find it absurd.
DarkWr8h is offline   Reply With Quote
Old 03-07-2013, 09:02 PM   #2067
Ccube09
Member#: 309146
2005 WRX
Needing some help.. I have a 05 wrx on tien s-tech springs. I'm looking at purchasing wheels that are 17x9 +35. I am a fan of the wide tire look so i would like to put some beefy tires on. I was thinking a 245 or a 255 width tire. Is this doable? Any kind of fender work?
Ccube09 is offline   Reply With Quote
Old 03-07-2013, 09:04 PM   #2068
dIrTy-StI
Member#: 322280
2002 Subaru WRX
ok so there wouldnt be a way to make those xxr's with a 35mm offset fit i guess
Old 03-07-2013, 10:02 PM   #2069
bboylocob
Member#: 151809
2007 WRX
He is a tard. As long as its the same or close to the factory diameter its fine. I have had 2 inner and outer boots replaced due yo crappy roads here in NOLA. And the owner of the suby shop was kool as hell with me car.
Old 03-07-2013, 10:18 PM   #2070
bugeyeryan
Member#: 343656
02 WRX
WRB, 02c
Default Help?
year: 2002
model: WRX Sedan
wheel model: XXR 527
wheel size/offset: 17x9.75 +35
tire brand/model: TBD
tire size: 225/45/17
suspension: BC BR Types
fender mods: Rolled
spacers: yes/no? none planned
Will this work?
bugeyeryan is offline   Reply With Quote
Old 03-07-2013, 10:35 PM   #2071
bboylocob
Member#: 151809
2007 WRX
Not an expert but i would personally do atleast a 235 tyre. As far as fit it should fit with the right camber.
Old 03-08-2013, 02:13 AM   #2072
sc00by4life
Member#: 97135
No.
Chances are he'll still need to slightly pull the rear at the least even with a 225.
Old 03-08-2013, 08:12 AM   #2073
bboylocob
Member#: 151809
2007 WRX
There u go slight pull also
Old 03-08-2013, 02:04 PM   #2074
novasteve
Member#: 349500
OMGHi2U
Hello all,
Hopefully I am posting in the 'right' spot for this question. Looking at new wheels and really like the Miro 111's. Have a '09 sedan, completely stock. Wondering which if either would be the best fit with little to no modification. The choices are 18x8.5 with 35mm or 18x9 with 40mm. I have been looking through the forums but to be honest, I don't really have the time to filter through 86 pages looking for the answer . I'd like to keep thing stockish, not opposed to some rolling. Also what tires would be best? Do NOT want to stretch tires or anything, a huge reason I bought this car is the handling, if this set-up is going to compromise that, I will have to figure out an different choice. Thanks in advance!!!
Steve
novasteve is offline   Reply With Quote
Old 03-08-2013, 03:29 PM   #2075
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by novasteve View Post
Hello all,
Steve
Neither. Both will require more than a little fender modification. Stick to OEM sizing since you don't have enough time to do your own research.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
