Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 03-08-2013, 04:36 PM   #2076
Scargod
Member#: 260314
2008 STI hatch
Originally Posted by novasteve View Post
really like the Miro 111's. Have a '09 sedan, completely stock. Wondering which if either would be the best fit with little to no modification. The choices are 18x8.5 with 35mm or 18x9 with 40mm.
I like these, too. However, they do not come in 5x114.3!
I can't say for sure that the 18x9 with 40ET will work but I bet with rolling the rears they will work.
Scargod is offline   Reply With Quote
Old 03-08-2013, 07:20 PM   #2077
sc00by4life
Member#: 97135
Hello all,
Hopefully I am posting in the 'right' spot for this question. Looking at new wheels and really like the Miro 111's. Have a '09 sedan, completely stock. Wondering which if either would be the best fit with little to no modification. The choices are 18x8.5 with 35mm or 18x9 with 40mm. I have been looking through the forums but to be honest, I don't really have the time to filter through 86 pages looking for the answer . I'd like to keep thing stockish, not opposed to some rolling. Also what tires would be best? Do NOT want to stretch tires or anything, a huge reason I bought this car is the handling, if this set-up is going to compromise that, I will have to figure out an different choice. Thanks in advance!!!
Steve
Don't want fender mods? You don't need wheels any wider than 8", with an offset of 42-48.
sc00by4life is online now   Reply With Quote
Old 03-08-2013, 09:46 PM   #2078
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Hello all,
Steve
17's - 17x8 +35 at the lowest for offset but anything higher will be better.
18's- widest you can go is 8.5" like scooby4life said.
In my opinions 17's are the best choice. Lighter, cheaper tire cost and look better with stock brakes lol.
KartRacer3 is offline   Reply With Quote
Old 03-09-2013, 10:15 AM   #2079
svynx
Member#: 210371
2002 wrx wrb
'03 Lifted TS
found it
svynx is offline   Reply With Quote
Old 03-10-2013, 01:51 AM   #2080
DarkWr8h
Member#: 349417
2006 Imprez Outbk Sp
Regal Blue / Silver
Originally Posted by bboylocob View Post
He is a tard. As long as its the same or close to the factory diameter its fine. I have had 2 inner and outer boots replaced due yo crappy roads here in NOLA. And the owner of the suby shop was kool as hell with me car.
Okay, thought so. Thanks.
DarkWr8h is offline   Reply With Quote
Old 03-10-2013, 08:28 PM   #2081
AHK
Member#: 237243
SSR Type F
18x9.5 +40
Michelin Pilot Super Sport 265/35/18
Stock Suspension*
AHK is offline   Reply With Quote
Old 03-11-2013, 12:35 AM   #2082
impre55ive01
Member#: 349759
Default wheel fit
hi
apologies if ive posted in the wrong thread, want to know whether the 5 spoke 08 sti wheels will fit on an 07 2.0 impreza hatch (last of the 06-07 shape)?
thanks
impre55ive01 is offline   Reply With Quote
Old 03-11-2013, 04:14 AM   #2083
rj_sti
Member#: 343403
2013 WRX STi
Hello guys I'm a new owner of 2013 sti hatch. I have everything stock. I'm thinking about getting a new set of wheels maybe 18's as long as it won't rub. Can you any one suggest what size of wheel and tires should I get? Maybe 18x8 or 18x9 and 225 or 235+?
year: 2013
model: sti hatch
wheel model: HD wheels clutch
wheel size/offset: 18x9 HPO
tire brand/model: falken 452
tire size:225/40/18
suspension: stock
Would this give me an aggressive look?
Thank you
rj_sti is offline   Reply With Quote
Old 03-11-2013, 10:25 AM   #2084
Buffman
Member#: 189212
2002 WRX wagon
02 WRX bugeye wagon. I want to use the stock 2011 WRX rims. Will those work? ( I know they will bolt up, worried about width and offset) What is the widest tire I can run without needing to roll the fender lip? If I roll the fender, what would be the widest I can then run?
This is on stock suspension
Buffman is offline   Reply With Quote
Old 03-11-2013, 11:51 AM   #2085
nhat
Member#: 140163
03 STi
hellaflunctional
$5 it's been done before.
Old 03-11-2013, 11:53 AM   #2086
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by impre55ive01 View Post
hi
thanks
Does your hatch have 5x114 hubs?
year: 2013
model: sti hatch
tire size:225/40/18
suspension: stock
Thank you
You should do some research. Your thoughts on aggressive fitment are way off.
Old 03-11-2013, 12:10 PM   #2087
Buffman
Member#: 189212
2002 WRX wagon
I've seen it mentioned before on the sedans, but never on the 02 wagon. I've seen an 05 wagon with it, but no confirmation about rubbing with load, or tire size used.
Old 03-11-2013, 03:23 PM   #2088
rj_sti
Member#: 343403
2013 WRX STi
Thanks!
year: 2013
model: sti hatch
wheel model: Rota grid
wheel size/offset: 18x9.5 38+
tire brand/model: any
tire size:245/40/18
suspension: stock
Would this be more aggressive and better?
Old 03-11-2013, 04:21 PM   #2089
UVRUGBY
Member#: 343303
2008 Impreza 2.5
I always get confused when it comes to tires and wheels. I have tried to understand the offset stuff, but it never sticks with me. Just not my forte I guess. Been doing research and can't find to much for my car and year with this offset. I might have over looked it somewhere, but im pretty sure I didn't miss it. Just wanting to see if this size and offset will work on my car.
Thanks in advance
year: 2008
model: 2.5i hatch
wheel model: Primax
wheel size/offset: 17x7 38+
tire brand/model: undecided
tire size:undecided
suspension: stock
UVRUGBY is offline   Reply With Quote
Old 03-11-2013, 05:18 PM   #2090
nhat
Member#: 140163
03 STi
hellaflunctional
Depends on tire size but you shouldn't have any issues with a 225/45/17.
Thanks!
year: 2013
model: sti hatch
tire size:245/40/18
suspension: stock
Yes. I would roll the rear fenders.
Thanks in advance
year: 2008
model: 2.5i hatch
wheel model: Primax
tire size:undecided
suspension: stock
Yes but why +38 offset?
Old 03-11-2013, 08:23 PM   #2091
4ndy
Member#: 279689
2006 Impreza WRX STi
need help
year:2006
model:STi
wheel model:Linea Corse Lemans (BBS LM reps)
wheel size/offset:18x9.5 +30
tire brand/model:Hankook Evo V12
tire size:245/40
suspension: BC BR coilovers
alignment: ??
fender mods: willing to roll fenders
spacers: yes/no? size? do i need????
how much camber/everything else will i need to fit these wheels?
4ndy is offline   Reply With Quote
Old 03-11-2013, 08:35 PM   #2092
slp0313
Member#: 120589
year: 2006
model:wrx
wheel model: xxr530
wheel size/offset: 18x8.75 w/+35
tire brand/model: unsure
tire size: 225/40/18
suspension: bc br coilovers
alignment: have rear camber bolts to install
fender mods: no
spacers: no
Hi everyone.. I'm planning on installing bc coilovers this spring with the wheel fitment listed above. Will I need to get my fenders rolled/pulled or is this something that can wait till the summer?
slp0313 is offline   Reply With Quote
Old 03-11-2013, 09:07 PM   #2093
SubaruBaron
Member#: 289281
2004 STI
Just wondering how some Work XD9s 17x8.5 +32 would fit on my 2004 STI? My fenders are rolled and I'm on Megan Track series coilovers. Also a 245 tire! Would I have any issues? Need anymore work to fit these? Getting a good deal on used that's why the +32 offset rather than the +42
Thanks in advance!
SubaruBaron is offline   Reply With Quote
Old 03-11-2013, 09:11 PM   #2094
UVRUGBY
Member#: 343303
2008 Impreza 2.5
Getting a awesome deal on a set of used.
may start looking to lower on struts and springs. not to aggressive of a drop. I figure I might have to roll the fenders a bit if I drop to low.
Old 03-11-2013, 11:19 PM   #2095
sc00by4life
Member#: 97135
Originally Posted by 4ndy View Post
need help
year:2006
model:STi
tire size:245/40
alignment: ??
too much tire for that sized wheel at that offset.
you'll need to be in the 225-235 range and fairly aggressive camber if you want to get away with only rolling.
also - you might want to check brake clearance. Most LM/LMreps dont clear brembos without spacers.
Old 03-12-2013, 03:41 AM   #2096
Buffman
Member#: 189212
2002 WRX wagon
thanks nhat
Old 03-12-2013, 07:24 AM   #2097
rj_sti
Member#: 343403
2013 WRX STi
Did research and got this:
Year: 2013
model: sti hatch
tire brand/model: hankook v12
tire size:255/35/18
suspension: stock
Fender mods: ???
Will be this a good fit with more aggressive look and won't rub?
Thanks
Old 03-12-2013, 12:37 PM   #2098
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by slp0313 View Post
year: 2006
model:wrx
wheel model: xxr530
fender mods: no
spacers: no
Roll the rear fenders and you'll be fine.
Thanks in advance!
Probably won't need any more work. If it does, it won't require much.
Year: 2013
model: sti hatch
tire size:255/35/18
suspension: stock
Fender mods: ???
Thanks
I would roll the rear fenders but you might not have to. Someone recently posted that they don't rub with an 18x9.5 +40 and 265s.
Old 03-12-2013, 12:37 PM   #2099
robotskillhumans
Member#: 155244
06 ice cream sti
Between the 2, I would opt for the 17x9 every time with a +42 offset +/-3. Then you can run anywhere from a 235 to a 255. You'll need to trim the rear fenders though, can't roll the rear fenders on the '05-07 STi.
Just curious as to why you can't roll the fenders on 05-07 STi. What size tires would you recommend for the 18x8.5? 245/40?
robotskillhumans is offline   Reply With Quote
Old 03-12-2013, 12:40 PM   #2100
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by robotskillhumans View Post
Just curious as to why you can't roll the fenders on 05-07 STi. What tires would you recommend for the 18x8.5?
http://t3hclap.com/archives/49
http://t3hclap.com/archives/385
235/40/18
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 04:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 02:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 02:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 04:54 PM
