Old 03-12-2013, 02:40 PM   #2101
rj_sti
Member#: 343403
2013 WRX STi
Originally Posted by nhat View Post
Roll the rear fenders and you'll be fine.
Probably won't need any more work. If it does, it won't require much.
I would roll the rear fenders but you might not have to. Someone recently posted that they don't rub with an 18x9.5 +40 and 265s.
really.. i just hope it won't rub. thanks!
rj_sti is offline   Reply With Quote
Old 03-12-2013, 07:04 PM   #2102
J. Rowdy
Member#: 300192
2009 Impreza
red
Model. 2009 impreza 2.5i hatch
Wheel size. 18x8.5
Current tires. 215 35r18
Suspension. Stock
Tires are stretched a bit much for my liking. Also I want to fill more of the wheel opening without any rubbing issues or doing any rolling or cutting splash shields. I've been looking on this thread but still confused. What should I run?
225/40 235/40??
Please help!!! Looking to buy rubber this week
J. Rowdy is offline   Reply With Quote
Old 03-12-2013, 07:47 PM   #2103
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Wheel size. 18x8.5
Suspension. Stock
225/40 235/40??
Offset? Should be running a 235/40 with that width
Digital Dillon is offline   Reply With Quote
Old 03-12-2013, 10:16 PM   #2104
J. Rowdy
Member#: 300192
2009 Impreza
red
I wasn't sure the offset so I looked online how to measure and calculate. And I came up with an offset of 63.5. Does that sound normal if so hopefully someone can help me with what tire size I can get in there without problems or mods thanks. -Jerry
Old 03-12-2013, 10:53 PM   #2105
J. Rowdy
Member#: 300192
2009 Impreza
red
Wheel size. 18x8.5
Offset. 63.5
NEED RUBBER
Running stock suspension wanting to go for a meatier look but not too much
What will fit??
From looking through this thread i gathered possibly?
235/40r18
Any help would be appreciated wanting to buy rubber this week. Thanks. -Jerry
Old 03-13-2013, 02:47 AM   #2106
sc00by4life
Member#: 97135
et63.5? Either you read wrong, or you ordered the wrong wheels. Those will not fit. Period.
Old 03-13-2013, 03:10 AM   #2107
J. Rowdy
Member#: 300192
2009 Impreza
red
Thank you for replying. I must be confused. Is et the offset? Meaning if the back of my wheel has an "et48" the offset is 48? Everytime I do the measuring method I come up with 63.5. I am a wheel newbie please clarify to me. Haha also the wheels came with 215/35r18. I test fit them and they fit no problem no rubbing. But I am buying new rubber and want 235/40r18. If those slightly stretched tires fit the tire difference should make that big of a difference should it? Thanks
Old 03-13-2013, 06:17 AM   #2108
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
What are you measuring that gives you 63.5?
Counterfit is offline   Reply With Quote
Old 03-14-2013, 12:36 AM   #2109
STI-AWD-FTW
Member#: 284868
2015 WRXx
2006 sti
Stock suspension
Only shaved front and rear fenders (no pull)
Need help determining whether I can squeeze mb battles 17x9 with 225/45/17 without any rub .. Front looks like no issue .. Rears are where I'm concerned .. Especially with more play on mushy suspension .. HELP
STI-AWD-FTW is offline   Reply With Quote
Old 03-14-2013, 12:47 AM   #2110
sc00by4life
Member#: 97135
Originally Posted by STI-AWD-FTW View Post
2006 sti
Stock suspension
Offset? +15's will require more modification or less tire.
Either way that will look gay as **** if you aren't fender on rim.
Old 03-14-2013, 01:01 AM   #2111
STI-AWD-FTW
Member#: 284868
2015 WRXx
+ 30 ... Suspension in near future .. When you own my sti you can do whatever you want .. Simple questions
Old 03-14-2013, 05:35 AM   #2112
rj_sti
Member#: 343403
2013 WRX STi
So I already have new wheels and tires but need help still if I should get new set of TPMS so my warning light wouldnt come on. Anyone here got issues when they switch to a whole new set of tires? Like their warning light comes on? Thanks
Old 03-14-2013, 12:54 PM   #2113
errmax99
Member#: 304129
2011 STI Limited
Plasma Blue
2011 STI limited
18x9.5 38 offset WORK EMOTION 11R
265/35/18 Potenza RE760
bc br coil 2 finger gap
cusco lca
aliment 1.8 all around
errmax99 is offline   Reply With Quote
Old 03-14-2013, 03:53 PM   #2114
sc00by4life
Member#: 97135
+30 will be fine with a roll all around (or shave).
Just saying it won't look even close to how you think it will.
Old 03-14-2013, 04:16 PM   #2115
littlewhitewagon
Member#: 103068
11 STI sedan
Best is to just move the TPMS over from the original wheels. Least amount of trouble and cost.
littlewhitewagon is offline   Reply With Quote
Old 03-15-2013, 09:26 AM   #2116
topherrwrx
Member#: 319759
2012 WRX Hatch
Ok so I have done my research and used the search bar a plenty. I have also called bc racing personally. I have a set of bc br standard coilovers for my 12' hatch. I also have 18x9.4 + 34 varrstoen es1 wheels. My concern is that I want low. I am trying to figure out lowest height on bc br standard coils and minimum drop height on bc br extreme low. I can send my coils to bc to exchange for extreme low. How much lower are he extreme low compared to standard? Any input is appreciated.
topherrwrx is offline   Reply With Quote
Old 03-15-2013, 11:28 PM   #2117
1BAD_STI
Member#: 188228
2010 Female Driven
STi Special Edition
Question Need advice please.
Want to get some new wheels/tires with my tax money. Running stocks right now. Not looking to drop it very low or anything crazy. Just need some of the experts here to let me know what is the widest wheel I can go, lowest offset and ofcourse tires.
Thanks in advance!
For a 2005 STi:
Stock Struts/Lowered Springs(Eibach)
Rolled Fenders (All 4)
Want TE37SL
1BAD_STI is offline   Reply With Quote
Old 03-16-2013, 05:10 PM   #2118
Scargod
Member#: 260314
2008 STI hatch
Thanks in advance!
For a 2005 STi:
Want TE37SL
Should call yourself "1bad_lazy_STI". Info is everywhere.
I am reluctant to ask, but I will anyway, What is a "2010 Female Driven
STi Special Edition"? Did this one come with a chauffeur?
Scargod is offline   Reply With Quote
Old 03-16-2013, 05:26 PM   #2119
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
17s or 18s?
18x9.5 +35-38 with a 245/35-40 or 255/35 tire should fit with only a little bit of camber adjustment.
flat4LGT is offline   Reply With Quote
Old 03-16-2013, 09:19 PM   #2120
1BAD_STI
Member#: 188228
2010 Female Driven
STi Special Edition
Impreza WRX STi (Sigh)
Here ya go little buddy...
This is a 2010 'Female' (cause 'I' drive it) STi. SE cause they only made a limited number for that year/color. Oh and thank God it doesn't come with a chauffeur.
Now back to my question, asking 'cause my project car is an '05 STi i'm working on. (Yes I have 2.) Pays to work hard ya know, that's why when you say 'lazy', hmm, I don't think so. Anyway, just trying to figure out how wide can I go on that '05. Thanks in advance.
Old 03-16-2013, 09:23 PM   #2121
Counterfit
Member#: 124254
"The Scoobinator"
Please tell me you are not underneath a car supported only a jack.
Old 03-16-2013, 09:24 PM   #2122
1BAD_STI
Member#: 188228
2010 Female Driven
STi Special Edition
Thumbs up
Originally Posted by flat4LGT View Post
17s or 18s?
Thank you.
Old 03-16-2013, 10:36 PM   #2123
Cliffmaster
Member#: 319507
2012 Wrx
Vehicle: 2012 sti sedan
Suspension: cobb springs
The plan: 18x9 mb battle +38 w/ 255 35
Iv tried searching for fitment info and pics of the +38 18" but haven't had any luck yet. Does anyone know if these clear brembos? I expect to roll the rear fenders at the very least.
Cliffmaster is offline   Reply With Quote
Old 03-16-2013, 10:57 PM   #2124
meifert
Member#: 301676
2009 Forester XT
a buddy of mine in high school lost a foot that way. he was lucky.
meifert is offline   Reply With Quote
Old 03-16-2013, 11:45 PM   #2125
Counterfit
Member#: 124254
"The Scoobinator"
A guy in RI got crushed and died that way a couple years ago.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
