Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 03-17-2013, 04:23 PM   #2126
Antiharper
Member#: 350489
09 Impreza 2.5i
Originally Posted by meifert View Post
a buddy of mine in high school lost a foot that way. he was lucky.
Every year ppl die in thier driveway working like that. For my first post I hate strongly advising, but I do this for a living, and although you've done it a million times, it only takes once to kill you. Pls chalk your wheels, always use axle stands.
Antiharper is offline   Reply With Quote
Old 03-17-2013, 04:27 PM   #2127
Antiharper
Member#: 350489
09 Impreza 2.5i
Ok here's the deal. I purchased some konig 17" 5x100 +45 offset. That's what should fit. Get the wheels to the shop and they fit over lugs but studs are right against the inner hole of the "lug hole" no way for a lug to go on. Has anyone run into this? 09 impreza 2.5i 4dr no mods... Yet. What's the fix here? I can't be the first one to have this happen, but can't get any solid info anywhere. I'd rather not use spacers but will. Or did they change the spec for 09? Thanks in advance.
Old 03-17-2013, 04:31 PM   #2128
Antiharper
Member#: 350489
09 Impreza 2.5i
Originally Posted by littlewhitewagon View Post
Best is to just move the TPMS over from the original wheels. Least amount of trouble and cost.
I am not sure with subys but here's a trade secret. 1) make sure the TPMS light is out <--IMPORTANT
2) bust down ur tires including spare tire , remove sensors and replace with rubber stems.
3) take Tpm sensors (all 4 ) and throw them in your spare tire
4) install spare onto spare rim, pump up psi
Now the wheel style TPMS sensors will think all psi is ok, no light on ever... Unless the spare goes flat.
Old 03-17-2013, 06:01 PM   #2129
fedex23
Member#: 133204
2006 WRX TR CGM
356hp/403tq... FTW tuned
Sounds like they are 5x114.3 to me.
fedex23 is offline   Reply With Quote
Old 03-17-2013, 06:23 PM   #2130
suBAEru
Member#: 235979
2011 WRX
So Im a big noob when it comes to wheel setups and stance. I really only know performance, so I need help. Please and thank you!
year:2011
model:WRX (hatch)
wheel model:Work Emotion XD-9
wheel size/offset:18x10 +38
tire brand/model: I'll do the research after I find the size...
tire size:225/40/18? (suggestions?) Dont know what would look good while still being functional.
suspension:Still looking which I really need/want (will take suggestions)
alignment:suggestions.
fender mods:willing to roll
spacers: I want to get 20mm spacers for just the rear, if that works. (to keep it aggressive, and still being able to rotate tires haha)
suBAEru is offline   Reply With Quote
Old 03-17-2013, 07:15 PM   #2131
sc00by4life
Member#: 97135
year:2011
model:WRX (hatch)
You have a lot to learn. Stop looking at wheels, start reading this thread and the other fitment threads.
There will be nothing functional about what you posted.
Old 03-17-2013, 07:41 PM   #2132
suBAEru
Member#: 235979
2011 WRX
What do you mean there will be nothing functional?
Old 03-17-2013, 07:57 PM   #2133
bboylocob
Member#: 151809
2007 WRX
What he means is it will only be good for show being a "hard parker"
bboylocob is offline   Reply With Quote
Old 03-17-2013, 08:39 PM   #2134
Antiharper
Member#: 350489
09 Impreza 2.5i
Ya they are multi fit stamped on back 5x100 5x114.3
Old 03-17-2013, 09:29 PM   #2135
Juks
Member#: 108163
2015 WRX, 2005 STI
year: 2005
model: STI
wheel model: Rays Gramslight DR57
wheel size/offset:18x9.5 +38
tire brand/model: Toyo r888
tire size:265/35/18
suspension: BC Racing BR coilovers
alignment: minimal camber targeted for street to maximize the little tire life I will get, probably 2.5* or so for track days
fender mods: what will be needed? Will a roll/pull be enough? I'm only concerned about functionality when it comes to ride height and being flush.
spacers: hopefully none
Juks is offline   Reply With Quote
Old 03-17-2013, 09:31 PM   #2136
fedex23
Member#: 133204
2006 WRX TR CGM
Lol, you've got them in the wrong holes then. Mine are both bolt patterns also & will do the something. Just put them in the other holes.
Old 03-17-2013, 09:36 PM   #2137
Antiharper
Member#: 350489
09 Impreza 2.5i
I was in a hurry today but I really doubt it.. Now you have me second guessing lol.
Old 03-17-2013, 10:22 PM   #2138
fedex23
Member#: 133204
2006 WRX TR CGM
That is the only thing I can think of that it could be. The 09 WRX is 5x100 just like the rest of them. Just try it again & let me know.
Old 03-17-2013, 10:30 PM   #2139
fedex23
Member#: 133204
2006 WRX TR CGM
^ & the impreza.
Old 03-17-2013, 11:14 PM   #2140
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
1. Chock, not chalk.
2. I wouldn't trust a CV axle to support a car.
Those are just minor quibbles. Otherwise, I agree 1000% and would never get underneath a car not or ramps or jackstands.
Probably something about the 20mm spacer in the rear, for starters.
Counterfit is offline   Reply With Quote
Old 03-17-2013, 11:52 PM   #2141
stewbarurex
Member#: 316996
2006 STI
CGM
can anyone tell me if/how i could make a set of 17x9.5 with 255/40 fit on a 2006 sti with coils? would it fit with rolling all corners and keeping the fenders raised 1/2" - 1" above the tires?
stewbarurex is offline   Reply With Quote
Old 03-18-2013, 08:56 AM   #2142
Antiharper
Member#: 350489
09 Impreza 2.5i
Um... Autocorrect got me with chock and you don't put axles stands on the axle... You can use them on any area that is fit like lift points, sub frame, sills control arms etc and an axle would be perfectly suitable aswell.
Old 03-18-2013, 08:58 AM   #2143
Antiharper
Member#: 350489
09 Impreza 2.5i
^ & the impreza.
Just tried again... No luck , it seems the 5x100 holes are straight thru holes with no lip or chamfer for the wheel nuts to bite. So I guess I need adapter? I've never run into this before. Thoughts?
Old 03-18-2013, 11:40 AM   #2144
meifert
Member#: 301676
2009 Forester XT
it's like a woman.....if it doesnt fit in one hole just put it in the other.
meifert is offline   Reply With Quote
Old 03-18-2013, 12:45 PM   #2145
sc00by4life
Member#: 97135
sounds like you need to get different wheels.
Old 03-18-2013, 06:53 PM   #2146
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Are you using OEM lugs? Pic of the problem?
Digital Dillon is offline   Reply With Quote
Old 03-18-2013, 07:22 PM   #2147
Antiharper
Member#: 350489
09 Impreza 2.5i
New to forum, can't figure out how to add pic. No lugs aren't used.. Studs are tight to the inside of the 5x100 bolt pattern and the holes are straight thru without a chamfer so even if studs were centered in the hole a lug nut wouldn't hold the rim on anyway. I think it may be a defect from factory.. And didnt notice cuz only 114.3 was used until now.
Old 03-18-2013, 07:28 PM   #2148
sc00by4life
Member#: 97135
just because its stamped as dual, doesn't mean it is.
if the holes are straight through with no chamfer or recess, it is not a dual drilled wheel.
Old 03-18-2013, 07:31 PM   #2149
fedex23
Member#: 133204
2006 WRX TR CGM
I've seen this before also & he is correct.
Old 03-18-2013, 07:32 PM   #2150
Digital Dillon
Member#: 288727
2008 WRX premium
Ohhhhhh.... I see what you mean. You need new wheels, unfortunately.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
