Old 04-25-2013, 08:58 PM   #2351
bboylocob
Member#: 151809
2007 WRX
Its awd all wheels need to be the same diameter
bboylocob is offline   Reply With Quote
Old 04-25-2013, 09:03 PM   #2352
sc00by4life
Member#: 97135
Originally Posted by Alphawolf26 View Post
Question guys and sorry if its stupid.. But is it bad for a subie to have different size tires on the back than on the front? Ive got 245/40/18 on the back and 215/45/18 in the front since i needed two front tires asap i got those, please let me know what you think?
you need to have the same sized wheels and tires on all corners.
if you cant afford to properly R&R your car, you can't afford the car.
Old 04-25-2013, 09:04 PM   #2353
japanesestar
Member#: 212037
2005 wrx sedan
black
According to my quick math, they are only .1 inches in diameter different. However, that does not mean it's ok. Sidewall stiffness alone will differentiate them once weight is put on them. Maybe in an emergency, but not for any extended driving. Unless of course you can afford to potentially damage something.
japanesestar is offline   Reply With Quote
Old 04-25-2013, 09:06 PM   #2354
Alphawolf26
Member#: 347300
2003 2.5RS
MBP
Thanks for the advise guys, im a little low on cash with bills and stuff, how immediately should i change them? Because if its really bad, ill max my credit card tmrw haha ive only driving two days on them
Alphawolf26 is offline   Reply With Quote
Old 04-25-2013, 09:19 PM   #2355
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
What's cheaper? 2 more tires or replacing your center differential?
Psychoreo is offline   Reply With Quote
Old 04-26-2013, 06:40 AM   #2356
Scargod
Member#: 260314
2008 STI hatch
Percentage-wise, I do not know when the front to rear ratio difference will start doing immediate damage. If you think about it, you have different ratios as you turn. It changes as the tires wear. It may be way off when you run your spare. It is not good because you are making the differential work harder than it's designed to. It could cause heat buildup if seriously different.
I would get a piece of ribbon or a soft sewing tape measure and see what you have. Drive over it and then measure the circumference of front and rear tires. Then you will know the real difference. That might give you some peace of mind... or not.
One of the problems with this tire mismatch is poor driving characteristics you are likely to encounter. When different tires are mixed you get into differing sidewall responses. This can result in annoying behavior or downright scary behavior at differing speeds and during turns. I once put just different brands of tires on the front and back of a Chevy Nova street rod and it got downright scary to drive after forty MPH. It started this uncontrollable weaving oscillation!
Then there's the fact that a WRX understeers already. You are making that worse with a smaller tire up front.
Scargod is offline   Reply With Quote
Old 04-26-2013, 12:46 PM   #2357
Alphawolf26
Member#: 347300
2003 2.5RS
MBP
Thanks a lot guys, i really appreciate it, im new to the whole wheel fitment thing but getting there aha i changed my front two just recently now they are all black lion 235/40/18
Old 04-26-2013, 12:58 PM   #2358
sc00by4life
Member#: 97135
mathmatically.....
not all tires are created equal. most manufacturers specs will vary from the advertised specs anywhere from 1-3mm even up to 10mm some times. the advertised sizing is only a standardization for the naming/fitment conventions.
Old 04-26-2013, 01:40 PM   #2359
japanesestar
Member#: 212037
2005 wrx sedan
black
Originally Posted by sc00by4life View Post
mathmatically.....
Touche.
I do understand that...I should have been more clear about that. I was merely trying to point out the fact that they might work on paper, but that doesn't mean they will on the road. Now that you mention it, all the manufacturers list exact measurements for their tires and it is remarkable how much the "same size" tires will vary in all dimensions from width and tread depth and overall height.
Old 04-26-2013, 02:07 PM   #2360
deanwrx
Member#: 188997
2007 STI
...all the manufacturers list exact measurements for their tires and it is remarkable how much the "same size" tires will vary in all dimensions from width and tread depth and overall height.
And even this is not necessarily reliable. You have to measure them in person.
deanwrx is offline   Reply With Quote
Old 04-27-2013, 08:41 PM   #2361
fedex23
Member#: 133204
2006 WRX TR CGM
356hp/403tq... FTW tuned
year:2006
model:WRX
wheel model:Enkei Kojin
wheel size/offset:18x9.5+45
tire brand/model:Cont DWS
tire size:255/35/18
suspension:Tein H-tech
alignment:06-07 STI specs
fender mods:Willing to roll if needed
spacers:NO
Is this possible without a pull? Do I need to go with a different size tire or just stick with a 9 in width? Thanks guys.
fedex23 is offline   Reply With Quote
Old 04-28-2013, 01:28 PM   #2362
prescottn6ft7
Member#: 268918
2002 WRX Wagon
year:2004
model:WRX STi
wheel model:Rota T2R
wheel size/offset:18x9.5+38
tire brand/model:Falken Ziex 612
tire size:245/40/18
suspension:Tein S-tech fronts, RCE Yellow rear
alignment:-2 camber in front -1 in rear 0 toe
fender mods:rolled rear flat
spacers:none
prescottn6ft7 is offline   Reply With Quote
Old 04-28-2013, 02:00 PM   #2363
paukert11
Member#: 327666
02 slow psmwagon
looks good.
paukert11 is offline   Reply With Quote
Old 04-28-2013, 05:05 PM   #2364
fedex23
Member#: 133204
2006 WRX TR CGM
Originally Posted by fedex23 View Post
year:2006
model:WRX
tire size:255/35/18
spacers:NO
[quote=prescottn6ft7;39691473]year:2004
model:WRX STi
tire size:245/40/18
spacers:none
Do you think I would have any problems with the inner clearance with the+45?
Old 04-28-2013, 08:30 PM   #2365
prescottn6ft7
Member#: 268918
2002 WRX Wagon
I don't think you would be able to dial in the camber you'd need without the tires hitting the struts. I can barely fit a penny in-between my 245's and the struts in the rear and thats with just -1 degrees of camber. So yeah, even with 5mm spacers I believe you would have issues with this offset. If you got them on the car with no rubbing it'd still look a little goofy in the back.
Old 04-28-2013, 08:44 PM   #2366
fedex23
Member#: 133204
2006 WRX TR CGM
That's what I was looking for, thanks man. Guess I'll just stick with 9in wide or less wheel. By the way, your car looks good.
Old 04-29-2013, 06:26 AM   #2367
bugeyeryan
Member#: 343656
02 WRX
WRB, 02c
model:2002 WRX Sedan
wheel model: XXR 527
wheel size/offset: 17x9.75 +35
tire brand/model: TBD
tire size: 225/45/17
suspension: BC BR Types
fender mods: Rolled
spacers: yes/no? none planned
Will this work?[/quote]
bugeyeryan is offline   Reply With Quote
Old 04-29-2013, 12:53 PM   #2368
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
This is what i have and want to do. What else will i need to do for this to work?
year:03
model:WRX
wheel model:Rota d
wheel size/offset:18x9.5 +40
tire brand/model:
tire size:235/40/18
suspension:tein super street with pillow mounts full drop
alignment:
fender mods:no
spacers: no
Thanks,
Mike
SUBYS R US is offline   Reply With Quote
Old 04-29-2013, 09:29 PM   #2369
prescottn6ft7
Member#: 268918
2002 WRX Wagon
fender mods: Rolled
Will this work?
[/quote]
read this thread: http://forums.nasioc.com/forums/show....php?t=2285133
year:03
model:WRX
wheel model:Rota d
tire brand/model:
tire size:235/40/18
alignment:
fender mods:no
spacers: no
Thanks,
Mike
What do you mean by "full drop" You'll have to roll and maybe even slightly pull the rear with at least -2 degrees of camber all around, you'll also be hitting the fender liners in the front with the wheel completely turned (thats with just a 2" drop). I would not lower the car more than 2" in the front and rear personally but you may be able to go lower... you'd need to add more camber the lower you go. You'll chew through tires. 235/40 tires will mess with your gearing and speedometer. 245/40 or 255/35 would be ideal.
edit: Just searched on google and found these rota d's on a GD... that is one hell of a fender pull on the rear, but not much camber at all...
Old 04-29-2013, 11:08 PM   #2370
tomislav
Member#: 321161
Guys i need an advice bout my future setup.
This is what i want:
Year: 2011
Model: sti sedan
Wheel model: rota t2r
Wheel size/offset: 18x9,5 / +38
Tire brand/model: dunlops- stock one
Tire size: 245/40/18
Suspension: RCE yellows
Alignment: stock
Fender modes: stock
Spacers: none
Currently i am runing stock wheels and tires on rce yellows. I want to buy rota t2r next month. What kind of prep do i have to do before the installation to fit those? Do i need fender rolls, alignment spec, spacers?
tomislav is offline   Reply With Quote
Old 04-30-2013, 08:46 AM   #2371
prescottn6ft7
Member#: 268918
2002 WRX Wagon
Year: 2011
Model: sti sedan
Alignment: stock
Fender modes: stock
Spacers: none
I just mounted these on my GD chassis. You will have zero issues. If anything maybe a custom alignment. Search around for alignment specs on a GR8... GR and GV chassis have more fender clearance than the earlier models. I personally prefer to have about -1.8 to about -2.0 in the front and rear for cornering and handling reasons. If you want to go "flush" and roll your fenders you may need 3-5mm spacers, or look at the 18x10 et36 seen here on a GV with 255/35/18's
Old 04-30-2013, 09:01 AM   #2372
CNYOBSMITH
Member#: 354869
2007 Outback Sport
Evergreen Metallic
year: 2007
model: impreza outback sport
wheel model: stock subaru
wheel size/offset: stock 16"
tire brand/model:Goodyear eagle
tire size: 205-55-r16
suspension: stock
alignment:stock
fender mods: none
spacers: none
Hoping to eventually lift it one or two inches and throw on some general grabber at2s. But as a broke high school student soon to be broke college student this will take a while to do.
CNYOBSMITH is offline   Reply With Quote
Old 04-30-2013, 09:48 AM   #2373
prescottn6ft7
Member#: 268918
2002 WRX Wagon
Originally Posted by CNYOBSMITH View Post
year: 2007
suspension: stock
alignment:stock
fender mods: none
spacers: none
Look in the Subaru Forester owner threads for someone getting rid of their stock suspension. That's a 2" lift. You'll want saggy butt spacers for the rear from Mach V motorsports because you're in a wagon... would look like this:
Old 04-30-2013, 10:00 AM   #2374
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
Subtle Solutions makes a lift kit that's pretty high quality. I helped my friend install the kit on his 06 wagon last summer. The kit comes with the 1" machined block spacers that go between the strut and the body and extended top hat bolts. I have no idea how much it cost him compared to Forester take-offs and saggy butt spacers.
Picture for reference. Running 16s with a meaty tire (can't remember the specs off the top of my head).
flat4LGT is offline   Reply With Quote
Old 04-30-2013, 02:37 PM   #2375
sc00by4life
Member#: 97135
the problem with strut spaces ONLY is that they don't offer any more tire clearance.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
