Old 04-30-2013, 07:10 PM   #2376
02MysteryMachine
Member#: 307632
2002 wrx
black
Ok I went threw the first 100 pages and didn't find what I needed so I'm just gonna ask. Will a 18x9.75 +20 fit with out fender mods (for now) on my stock suspension 02 wrx wagon. I know it'll look stupid on stock suspension but it'll only be for a little while
02MysteryMachine is offline   Reply With Quote
Old 04-30-2013, 07:17 PM   #2377
sc00by4life
Member#: 97135
hell no. not even close.
that ain't even gunna fit a wagon without SIGNIFICANT work.
SIGNIFICANT work.
I can't stress that enough. I've done similar fitments on wagons before, its HARD getting that much wheel under the fenders.
I would NOT recommend this fitment to anyone that does not have prior experience with VERY aggressive setups. That means you. You'll be getting in FAR over your head.
Old 04-30-2013, 07:20 PM   #2378
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Is that a serious question?
Counterfit is online now   Reply With Quote
Old 04-30-2013, 10:34 PM   #2379
prescottn6ft7
Member#: 268918
2002 WRX Wagon
Not even if you used rubber bands for tires. Hope you haven't already bought the wheels.
prescottn6ft7 is offline   Reply With Quote
Old 05-01-2013, 10:01 PM   #2380
boostedsoob
Member#: 300761
Setup I'm looking for:
2006 STi
BC racing BR series coilovers
255/35R18 BFGoodrich GForce KDW
18x10 +30 Rota SVN-R
I don't want to slam the car. Just lower it enough for an aggressive look.
Let me know people!
boostedsoob is offline   Reply With Quote
Old 05-02-2013, 03:06 AM   #2381
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
My stuff...
year: 2009
model: Impreza 2.5i Hatch
suspension: BC BR Coilovers (rears at max low, front can still go a tiny bit lower), Cusco Rear Lower Control Arms
alignment: Camber is at -1.5 front and -1.0 rear. Zero toe front and rear.
fender mods: Rolled with a slight pull. (Done after the photos were taken.)
spacers: None.
wheel model: Rota Silpstream
wheel size/offset: 16x7+48
tire brand/model: Bridgestone Potenza RE92
tire size: 205/55/16
wheel model: Rota G-Force
wheel size/offset: 17x7.5+48
tire brand/model: Kumho Ecsta ASX
tire size: 225/45/17
wheel model: Rota P45F
whee; size/offset: 18x8+48
tire brand/model: Toyo Proxes T1R
tire size: 235/40/18
**New Setup**
suspension: Koni inserts with 2012 WRX springs
alignment: Camber is at -1.4 front and -1.3/-1.7 rear. Zero toe front and rear.
spacers: None.
wheel model: Enkei RPF1
whee; size/offset: 17x9+45
tire brand/model: Dunlop Direzza Z1 Star Spec
tire size: 235/45/17
JourdanWithaU is offline   Reply With Quote
Old 05-02-2013, 11:46 AM   #2382
spoolya05
Member#: 308104
2005 STI
Aspen white
anyone know of any good sites for buying new wheels and tires, im not really sure what i want just yet. Im riding on XXR 522 18x8.5 and I dont really like them.
spoolya05 is offline   Reply With Quote
Old 05-02-2013, 07:17 PM   #2383
iStubz
Member#: 355185
okay, ive been looking through here for a while, what's the most aggressive functional fitment without stretching tire (I like the meatiness) I can fit on a 2008 WRX sedan, thats going to be lowered on coilovers.
I'm looking for 18x9 for the lowest width...
Of course I'll get a roll and moderate pull if necessary.
From what I've seen the 08s cant get too wide
iStubz is offline   Reply With Quote
Old 05-02-2013, 07:21 PM   #2384
sc00by4life
Member#: 97135
if you want the most meat you can get, you wont do it on a 9" wheel on the narrowbody.
Old 05-02-2013, 10:27 PM   #2385
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Why not?
I've seen 265 on a narrow body and it fit pretty good on 9" wheels.
I've got 9" and I'll be shooting for 255 with my next set of tires.
Old 05-03-2013, 12:29 PM   #2386
Preludecris
Member#: 348191
2013 WRX Sedan
PBP
Last edited by Preludecris; 05-03-2013 at 01:31 PM. Reason: nevermind i figured it out, did a little more research
Preludecris is offline   Reply With Quote
Old 05-03-2013, 04:50 PM   #2387
tricktraxxas3
Member#: 288312
2007 WRX STi
Monkiboy over on wrx forums is/was running 18x9.5 DPT's with 265/35 star specs on his 08 WRX.
tricktraxxas3 is offline   Reply With Quote
Old 05-03-2013, 07:12 PM   #2388
sc00by4life
Member#: 97135
Originally Posted by JourdanWithaU View Post
Why not?
With enough fender work, anything is possible....BUT...
Monkiboy has extensive suspension modification to gain the camber + clearance needed for that setup. It aint gunna fit with "just coilovers" and a ****load of fender work. And I wouldn't call -3* on a street driven car exactly...functional.
Old 05-03-2013, 09:39 PM   #2389
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
I was thinking of Kyle's car... I can't remember what his handle was here.
That's 265 on a 18x9+35. All he (said he) had was rolled fenders and 0 camber in the front. Stock linkage in the rear.
Probably not the most functional, but it is certainly at the very edge.
Old 05-05-2013, 12:16 AM   #2390
younoleit
Member#: 329150
2011 WRX 4-Door
Will they fit? Should I go with a 245 or 255 tire width?
year: 2011
model: WRX Sedan
wheel model: Enkei Raijin 18x8.5 +45
wheel size/offset: 18x8.5 +45
tire brand/model: BF Goodrich g-Force Sport COMP-2
tire size: 245/40/18 or 255/40/18
suspension: Stock
younoleit is offline   Reply With Quote
Old 05-06-2013, 10:24 AM   #2391
GYR0
Member#: 303517
2011 WRX Ltd. Sedan
SSM
Would Legacy GT 5-spokes on a '11 WRX work for a winter Setup? Everything else would be stock...
GYR0 is offline   Reply With Quote
Old 05-06-2013, 04:08 PM   #2392
prescottn6ft7
Member#: 268918
2002 WRX Wagon
Wheels:
www.wheeldude.com
www.oakos.com
www.fastwrx.com
Tires:
www.discounttiredirect.com
www.tirerack.com
year: 2011
model: WRX Sedan
suspension: Stock
They will fit with no issues. With the 8.5 with 245 would be more appropriate than 255.
Old 05-06-2013, 05:23 PM   #2393
Washingtonduck20
Member#: 355637
I have a 2010 impreza 2.5i wagon.
Does any one happen to know if a set of 16x7 RS six spokes will fit my car?
I am new to the forum but have searched all over here and the web and can't come up with an answer. Any help is greatly appreciated, thanks!
Washingtonduck20 is offline   Reply With Quote
Old 05-06-2013, 07:09 PM   #2394
sc00by4life
Member#: 97135
yep, they'll fit fine.
Old 05-06-2013, 08:17 PM   #2395
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
+1, stock wheels are 16x6.5"+50something...
KartRacer3 is offline   Reply With Quote
Old 05-06-2013, 08:20 PM   #2396
Washingtonduck20
Member#: 355637
Awesome thank you for the help! I will post the results once I get them!
Old 05-07-2013, 12:58 PM   #2397
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
year: 2005
model: STi
wheel size/offset: 17x9 +45
tire brand/model: Kumho XS
tire size: 255/40/17
suspension: BC Racing coilovers (camber plates in front), camber bolts in the rear
alignment: currently at -1.8* f, -2* rear
fender mods: none so far
spacers: none so far, have 3mm ones not being used
Wondering if these tires will be too big. Don't mind rolling the front if need be, or dialing in a bit more camber. Looking for more of a flush look than the high offset 2011 STI enkei's I had previously.
danny_d19 is offline   Reply With Quote
Old 05-07-2013, 01:27 PM   #2398
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Originally Posted by danny_d19 View Post
year: 2005
model: STi
It will be close to your strut with that offset and tire size. I ran the same setup on my bugeye and had to run atleast a 5mm spacer. I am now planning on running a 17x9 et45 w/ a 10mm spacer with 255/40. Fenders will need to be rolled.
dburgoon is offline   Reply With Quote
Old 05-08-2013, 09:34 AM   #2399
jrushing11
Member#: 300260
Rally Blue
ok so I'm wanting to go from a 225/45/17 on a 7.5 diameter wheel to a 8 or 8.5 diameter wheel on 235/40(or45)/18. My front fender are rolled and my back fenders are pulled. what exactly do i need? like offset and everything, i am a motor and tranny guy all the way. complete noob to the flush/wheel game
jrushing11 is offline   Reply With Quote
Old 05-08-2013, 12:59 PM   #2400
ViolentDecay
Member#: 355838
04' sedan, ksport kontrol pro coil overs, everything stock as of now.. Coil overs on the way. Just not sure on wheels and tires yet. A lot of it is foreign to me, I know I want an 18x9 or so, and I'd like to mildly stretch the tires on while clearing all struts and looking pretty flush. Not going real low because its my daily and I get to enjoy plenty of speed bumps throughout the day, but I'm going to definitely go as low as I can.
Just need to know what wheel size/offset, and tire size would fit.
ViolentDecay is offline   Reply With Quote
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
