Closed Thread
Old 07-08-2011, 09:59 AM   #1
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
Default the motorsport fitment thread: because race car!
this thread encompasses all things motorsport: street light warriors, backroad running aka touge, auto-x, track, drag strip, gymkhana, hill climb, stage rally, rally-x, oval, etc.
please follow this format:
year:
model:
motorsport:
wheel model:
wheel size:
wheel offset:
tire brand/model:
tire size:
suspension:
alignment:
fender mods:
spacers:
nhat is offline
Old 07-08-2011, 10:22 AM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
year: 2006
model: STI
motorsport: Track Days
wheel model: Wedsports TC105N
wheel size: 17x9
wheel offset: +49
tire size: 255/40-17
suspension: KW V3's
fender mods: Slight roll in rear
notes: Run 3mm spacers in from to clear the suspension.
year: 2006
model: STI
wheel model: Advan RZ
wheel size: 17x9
wheel offset: +45
suspension: KW V3's
mav1c is offline
Old 07-08-2011, 10:38 AM   #3
jamesw95
Member#: 270830
2008 STi
year: 2008
model: STi
wheel model: Volk TE37SL
wheel size: 18x10
wheel offset: +40
tire size: 275/35-18
suspension: 22mm Perring sway bars, Kartboy endlinks, Whiteline sway mount braces
fender mods: rears rolled
jamesw95 is offline
Old 07-08-2011, 11:15 AM   #4
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
year: 2006
model: STI
motorsport:Autox
wheel model: SSR Type C-RS
wheel size: 18x10.5
wheel offset: +17
tire size: 285/30/18
suspension: JRZ RS pro
fender mods: cut fenders and fender flares
pignoseSTI is offline
Old 07-08-2011, 12:14 PM   #5
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
year: 2011
model: STI hatchback
motorsport: Autocross
wheel model: Rota Grid
wheel size: 17X9.0
wheel offset: +42
tire brand/model: Dunlop Star Spec
tire size: 265/40/17
suspension: stock (except swaybars and additional camber bolts in the front)
fender mods: Rolled rear fenders
alignment: -2.0 Front / -1.2ish Rear
spacers: none
dbrier is offline
Old 07-08-2011, 01:29 PM   #6
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
year: 2005
model: WRX WAGON
motorsport: Auto-x, track
wheel size: 17x8 (STX auto-x limit)
wheel offset: +48
tire size: 245/40-17
suspension: KW V3, GC front camber plates
fender mods: Aggressive rear w/ no pull, none in front
dantastic is offline
Old 07-09-2011, 11:08 AM   #7
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
added to the format to include more information which most of you have already added
nhat is offline
Old 07-09-2011, 08:08 PM   #8
Wintershredder
Member#: 160089
2004 STi,330xi,328xi
WRB, Black, White
year:2004
model:STi
motorsport:Track
wheel model:NT03+m
wheel size:18x10.5
wheel offset:30
tire size:285/30-18
suspension:RCE T2 600/500
alignment:TBD
fender mods:Cut front and rear w/ flares
spacers:Hub/Wheel centric 20mm
Wintershredder is offline
Old 07-09-2011, 11:07 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Year: 1997
Model: Legacy 2.5GT sedan
Motorsport: Auto-x and track days
Rim model: Volk TE-37
Rim size: 15x8"
Rim offset: +45mm
Tire brand/model: Kumho V710
Tire size: 225/50-15
Suspension: RCE T2s (for a GD)
Alignment: Unknown. Hasn't been aligned in 18 months or more, in which time I installed the T2s with Cusco camber plates, then installed GD STI front control arms and a Whiteline roll center kit, then installed Vorshlag camber plates. Lots of front camber, not as much rear camber, eyeball'd toe so the steering wheel is straight.
Fender mods: Rolled rears, removed rubber strip from rear lip
Spacers: Nope
Patrick Olsen is online now
Old 07-09-2011, 11:51 PM   #10
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Fedex Field?
Byzantium is offline
Old 07-10-2011, 12:48 AM   #11
SoCal_Scooby
Member#: 210777
Don't worry bout' it Brah
year: 2006
model: wrx
motorsport: on/off ramps, touge, track
wheel model: Rota Torque
wheel size: 18x8.5
wheel offset: +48
tire brand/model: Toyo R1-R
tire size: 255/35/18
suspension: Eibach prokit, 24mm adj Sways
alignment: none yet
fender mods:Slight Roll
spacers: none
SoCal_Scooby is offline
Old 07-11-2011, 09:01 PM   #12
wantsti
Member#: 134764
04 sti
java black pearl
year: 2004
model: sti
motorsport: Auto X
wheel model: Rota DPT
wheel size: 18x9.5
wheel offset: +44
tire brand/model: Toyo R888
tire size: 265-35-18
suspension: RCE T'2 f/r sways, every bushing replaced, vorshlag rear plates at full negative (gives more wheel clearance for high offset) struts are slotted to get positive camber back, Ground-Control front plates.
alignment: -2.5 f -2 r 0 toe 7 caster
fender mods: front rolled rear/pull 7~mm
spacers: none
wantsti is offline
Old 07-11-2011, 09:22 PM   #13
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
how do you not rub at full lock? i rubbed with an 18x9.5 +40 and 265/35/18 victoracers...but my car is a bit lower than yours.
i don't rub at all with a 17x10 +38 and 255s which will soon have 265s.
nhat is offline
Old 07-13-2011, 10:26 AM   #14
wantsti
Member#: 134764
04 sti
java black pearl
I dont know its close but doesnt rub. I'm at 13.75" front. My wheels touch the front of my fender liners.
wantsti is offline
Old 07-17-2011, 04:29 PM   #15
Moes07sti
Member#: 197488
2007 STI EFI Logics
Default HELP!!!!!! ENKEI NT03 18X9.5 27MM how wide can i go????
I have Enkei NT03's that are 18x9.5 with a 27 offset.
the car currently has 245/40/18's on right now and I had Rally Armour mudflaps on but took them off because I had a slight rubbing issue with the spacer for one of the screws inside the mud gaurd that holds the mudflaps in.
I took them off so now I have no rubbing issues but now I'd like to go with a wider tires....
I'm thinking 275/35/18 Dunlap Direzza Z1 Star Specs
Need help because i'm looking to do this on Wednesday, Also i'm going for wider tires so that I can get more grip on the track because the car is killing the 245's on the track and they def. dont have the level of grip i'm looking for.
Thanks in advance guys
Moes07sti is offline
Old 07-18-2011, 12:14 AM   #16
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
interesting. i'll have to test fit again because all i heard was rubbing when i had a set of 18x9.5 +40 with 265/35/18s on
i would stick with 255/35/18 or 265/35/18. it'd help if you gave us the information requested in the first post
nhat is offline
Old 07-19-2011, 10:34 PM   #17
jutes85
Member#: 127232
Do You
Even Subaru
Originally Posted by Wintershredder View Post
year:2004
model:STi
motorsport:Track
wheel model:NT03+m
wheel size:18x10.5
wheel offset:30
tire size:285/30-18
alignment:TBD
Pics?
jutes85 is offline
Old 07-24-2011, 03:36 AM   #18
mikecampafool
Member#: 256069
2007 STI
beautiful
Default Help on rim size rpf1
Okay so i want to start tracking my car within the next year these rims are light i heard they're pretty nice for the track how wide and what offset is recommended?
mikecampafool is offline
Old 07-24-2011, 03:41 AM   #19
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
wheels
WHEELS
cars have wheels
wheels have rims
Uncle Scotty is offline
Old 07-24-2011, 06:30 PM   #20
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
we're going to need more information. desired tire size, suspension mods, fender mods, alignment.
nhat is offline
Old 07-26-2011, 02:28 PM   #21
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Originally Posted by Uncle Scotty View Post
cars have wheels
wheels have rims
Thus, logically, cars have rims.
Old 07-26-2011, 02:49 PM   #22
Black94Snake
Member#: 274499
2007 CGM VF'd WRX
12.9 @ 105mph
But installing a rim (or barrel), without a center disc... won't get you anywhere!
Black94Snake is offline
Old 08-02-2011, 07:09 AM   #23
arf80
Member#: 125580
2011 WRX 5dr
What's the more "correct" tire width for a 9" wheel, 255/40/17 or 265/40/17? I know both are well within spec, is the difference so close that it just comes down to the particular tire brand?
arf80 is offline
Old 08-02-2011, 07:28 AM   #24
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
I run 255/40-17 on 17x9 +45 or +49. I think that's ideal if you don't want to do a lot of fender mods. 265/40-17 is starting to get a bit large in diameter, and will require some sort of roll/pull of the fenders. Also, there are a lot less choices in 265/40-17.
mav1c is offline
Old 08-02-2011, 07:31 AM   #25
Byzantium
Member#: 207826
85k 2002 WRX
245/40/17 - 255/40/17
Closed Thread
U.S. Rallycross (NJ Motorsports Park): Oct 03- Pictures of Racing, Cars, etc. LICheckmate Motorsports 27 09-29-2011 08:31 AM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
my car in the pit lane with the JGTC Cusco Impreza race car JDM addict Member's Car Gallery 29 08-17-2009 11:32 AM
Message Board Statistics All times are GMT -4. The time now is 01:44 PM.
