#1 |
Member#: 279437
Vehicle:2011 WRX 5-door |
I'm moving to northwest Ohio and I will not be using my car much at all. It will be sitting outside in the elements, including all the snow. I am looking for something long lasting and not incredibly expensive to protect the paint from the elements and all the snow salt used in the winter. A couple months ago I had the local car wash place put sealtek (i believe) paint sealant on the car and it looked great. Just today I took some polishing compound to the front of the hood and front fenders and installed a clear bra. I of course used polishing compound on a larger area than the bra covers, and since I assume the polishing compound removed any sealant, I need something on those areas soon.
What would you all experienced with waxing, etc recommend for me? What about on the clear bra? I've heard that I should only use spray quick detailer on the clear bra. What about the rest of the car? BTW the car is only a couple months old. Thanks!!
#2 |
Member#: 157348
South East
Vehicle:It's rowdy outside I ain't signin' s*** |
A car cover?
#3 |
Member#: 279437
Hey, I meant to mention that too! I had read unabomber's faq though and he recommended against using a car cover outdoors, so I was mostly staying away from those. But maybe I should consider it? I still would like something on the paint though... at least where I used the polishing compound.
#4 |
Member#: 287416
Good coat of wax, and put the car cover on. make sure you tie the cover tight to prevent rubbing in the wind
| Thread Tools | |
| Display Modes | |
| have you used this for STI seats? or what should i use? | Speedster329 | Car Care & Detailing | 3 | 05-15-2010 11:26 AM |
| What should I use? | Hojai | Normally Aspirated with bolt-on Forced Induction Powertrain | 13 | 04-22-2002 01:31 AM |
| I`m changing my Diff fluid what should i use | Wheels | Factory 2.0L Turbo Powertrain | 2 | 10-11-2001 07:45 AM |
| What should I use for a RS-T Tranny fluid | Jimmy | Normally Aspirated with bolt-on Forced Induction Powertrain | 16 | 07-20-2001 03:39 PM |
| Boost Control!!! What should I use | Jimmy | Factory 2.0L Turbo Powertrain | 5 | 06-14-2001 11:40 AM |
