Old 07-26-2002, 04:22 PM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Question Would an 02 sensor be effected by a Catalytic convert?
I have heard conflicting data on this. If an 02 sensor was place before and behind the cat would it effect the reading?
I assume so. I ask for a couple reasons.
1st I have the oportunity to have a 2.5l exhaust pipe as part of my custom exhaust. My car only has a front 02 sensor. At first I was just thinking to block the other port. But would I be able to connect an A/F meter to it?
2nd If the cat does effect A/F how the heck do they measure A/F when dynoing a car?
Thanks
Old 07-26-2002, 06:01 PM   #2
Julian
Member#: 1182
MY00 RS
BRP
You could connect an A/F gauge to the rear O2 sensor on the RS exhaust system.
The ECU determines A/F ratios from the front O2 sensor, the rear O2 sensor is just used by the ECU to make sure everything is hunky-dory.
Julian is offline   Reply With Quote
Old 07-26-2002, 06:33 PM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Default Re: Would an 02 sensor be effected by a Catalytic convert?
Thanks
Being that your car is a 1990, it doesn't have a wide-band O2 sensor and you can just plug an A/F meter directly to your front O2 sensor Just plug the rear hole
Eric
Eric SS is offline   Reply With Quote
Old 07-26-2002, 07:24 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
My point was to have an 02 sensor dedicated to the meter. I probably will just plug the rear hole.
You guys still didnt answer my question though!
Need an 02 sensor for an 06 wrx NOW! Alaskan_awd Alaskan Impreza Club Forum -- AKIC 1 05-01-2007 12:35 AM
Not a newbie....but when is an 02 Sensor change due? Scott4DMny Newbies & FAQs 8 03-29-2006 04:44 PM
Anyone in MD have an 02 sensor and a hand? Sputt Mid Atlantic Impreza Club -- MAIC 4 03-13-2006 10:56 PM
Can your MAF intake sensor be destroyed by water? natoli4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-13-2005 11:20 PM
Would an updated reflash be needed if I would add intercooler hoses? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-09-2003 10:54 PM
