Vancouver Impreza Club
Old 07-14-2011, 06:59 PM   #26
RE3Rotor
Member#: 162465
04 Forester XT
12 Outback 2.5i
I think wagons have wiring for rear wiper.
RE3Rotor is offline   Reply With Quote
Old 07-14-2011, 08:23 PM   #27
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Originally Posted by mcwc View Post
You are making it sound too simple... I wish it were that simple, just literally plug and play.
The half cut didn't come with the rear half of the harness . Isn't there some slight differences between a sedan and wagon harness?
When Chris and I did his wagon we only used the front half off a WRX as well. We just used the wiring diagram and move any wiring that is different between the two.
Originally Posted by jchretien View Post
Are you volunteering yourself?
I think 2 wiring harness swap is enough for any individual
Should be easy to replace the one wiring The side mirrors has 7 wires that needed modifying
minifreak is offline   Reply With Quote
Old 07-14-2011, 09:20 PM   #28
rs420
the cone killer
Member#: 157784
02 swapped bugeye
anthricite
When I did my swap I only had the front half and the fuel pump controller harness. The rear wasn't touched... But I'm also not a wagon.
The motor in and out should be done in a day, maybe 2. The wiring is what took me a long time and required loomins help. That guy is just F'in smart.
I can't offer much help, but anything I can help with let me know...
rs420 is offline   Reply With Quote
Old 07-15-2011, 01:20 AM   #29
jchretien
Member#: 217235
1999 FoLEsTa EsTe-Ai
Canyon Red
Just spent 3 hours trying to separate the tranny and the motor. #(%*@)($*@($in thing is on there good. Thing is, its all on a pallet. Anybody have any brilliant ideas?
jchretien is offline   Reply With Quote
Old 07-15-2011, 01:23 AM   #30
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
don't you have to pull some pin or something in the clutch fork assembly? I hear that holds a lot of people up...?
Zefy is offline   Reply With Quote
Old 07-15-2011, 01:27 AM   #31
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
Old 07-15-2011, 01:30 AM   #32
RE3Rotor
Member#: 162465
04 Forester XT
12 Outback 2.5i
My idea, never tried so I can't promise it will work.
Brace the engine side against a wall. (with something under where the engine and the transmission connect) Tie something strong to the engine to where the pitch fork is and the other end to the wall. Next, rock the transmission until it comes loose?
Old 07-15-2011, 01:51 AM   #33
jchretien
Member#: 217235
Canyon Red
We pulled that damn thing out already... sigh try again saturday
Old 07-15-2011, 02:22 AM   #34
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Take a really thin screw driver/drywall scraper thingy and hammer it in. It actually helps to "drape" the transmission off the engine slightly.
If not then tie engine/transmission to something and use a ratcheting strap to pull them apart.
Old 07-15-2011, 02:42 AM   #35
iht
Member#: 196742
2000 Impreza 2.5rs
that's what i figured. didn't have the right tools for that. -_- so gotta go back on saturday with some right tools and whack it. a bit of a PITA when you don't have the right tools
iht is offline   Reply With Quote
Old 07-22-2011, 03:29 AM   #36
jchretien
Member#: 217235
Canyon Red
So, over the last few days, we pulled all the wiring from the chassis. Big pile of harness came out
We were also able to split the gearbox and the motor. Just needed a few more screwdrivers to wedge in. Damn rusted alignment pins
Put the motor onto the engine stand today and pulled off the timing belt cover in preparation to do the water pump, idlers and belt.
We found this: Busted LH Exhaust cam sprocket =(
wtf? So now I gotta pull the sprocket and get a new one... theres also a funny groove in my belt. Gotta figure out how that happened.
I park the Forester tonight. Insurance expires. Pull the wiring, and prep for merge. Cant do the full harness swap, everything is backwards. Darn RHD
Old 07-22-2011, 04:32 PM   #37
pope_face
Member#: 274373
1997 Impreza OBS
Blue - "Mishka"
Ouch... Are you still gonna make it out to the meets with mcwc or iht? And can't you reinsure it before AirCare expires? I thought that you could do that...
pope_face is offline   Reply With Quote
Old 07-23-2011, 03:11 AM   #38
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
if i were you id just use the sti front harness and mate it to the forester rear. some things will require extra wires like the rear wiper. the only extra wires other than the fuel pump controller.
on the front end its basically getting the lights done and the doors. thats pretty much it.
Loomin is offline   Reply With Quote
Old 07-23-2011, 03:50 AM   #39
jchretien
Member#: 217235
Canyon Red
Its JDM RHD though. ECU is on the left, with the fuse box. All the dash stuff is on the right hand side.
Though, can I still bribe you into helping me with the GD dash swap?
Old 07-25-2011, 03:34 AM   #40
(98)RSti
Member#: 266726
1998 RS Coupe
black
omg one hurdle after another....
(98)RSti is offline   Reply With Quote
Old 07-25-2011, 04:25 AM   #41
HRCboy
Member#: 167075
08 STI & 999R
Just think of the finish line and you'll be okay JC! Keep at her she will be yours!
HRCboy is offline   Reply With Quote
Old 07-26-2011, 04:20 AM   #42
mcwc
Member#: 196262
1999 RSTi, Silver
1990 240DL, Gold
We are still waiting for some parts to come in but today, we sent the flywheel out to be machined, installed new gaskets in the exhaust manifold, installed the up pipe, installed a Whiteline positive shift kit, and partially stripped the Forester's interior.
We also mocked up the EWG
mcwc is offline   Reply With Quote
Old 07-28-2011, 04:08 AM   #43
jchretien
Member#: 217235
Canyon Red
Mounted up my 05 STi rack to the crossmember today.
bolts right up, but hose ends are different from RHD and LHD. Need new lines =(
Old 07-28-2011, 11:14 AM   #44
pope_face
Member#: 274373
1997 Impreza OBS
Blue - "Mishka"
Looks good... That reminds me, I've gotta replace my steering rack. Doesn't look all too difficult though.
Nice to see some progress on this... makes me think I should get back on my project as well.
Any news on when you're sending the wiring harnesses out to get merged?
Old 07-31-2011, 04:18 AM   #45
jchretien
Member#: 217235
Canyon Red
some progress today. Removed the offending cam sprocket. Bent the wrench trying to take if off. Ended up taking the 4ft-ish handle off one of the jacks, stick it on the 10mm hex key and broke the bolt loose. Promptly went back to Canadian Tire to RMA the wrench.
as it stands now, new timing belt idlers/tensioner in, new waterpump in, turbo inlet in (that was a b**ch), also replaced the clamps and fuel injection hose since this model appears to be the same design as the ones with the recall.
Just a small preview: Stock VF30 next to a ????????
edit: An anonymous person has generously donated a cam sprocket. Onward ho!
Old 07-31-2011, 01:03 PM   #46
pope_face
Member#: 274373
1997 Impreza OBS
Blue - "Mishka"
JC: Sorry about not making it out yesterday... we had a dinner at six, and didn't finish our stuff till half an hour before it.
That's some major torque on the wrench though... I was wondering: How are you guys going to torque it back up? You mentioned that the little socket allen keys tend to spin after a certain amount of torque, so you'll have to think of something else. Only way I can think of is to cut off a section of your allen key and stick it inside a 10mm socket, then use that on your torque wrench.
Old 07-31-2011, 01:58 PM   #47
jchretien
Member#: 217235
Canyon Red
Its only torqued on to 79ft-lb, so its not too bad.
Old 07-31-2011, 03:06 PM   #48
iht
Member#: 196742
2000 Impreza 2.5rs
we also got a 10mm 3/8 drive socket hex from my kit so it shouldn't be as bad now.
Old 07-31-2011, 11:44 PM   #49
mcwc
Member#: 196262
1999 RSTi, Silver
1990 240DL, Gold
We used this post as a reference to remove the camshaft sprocket.
http://forums.nasioc.com/forums/show...9&postcount=77
We didn't want to snap Wade's 10mm Craftsman hex socket and we don't have access to nice Snap-on tools.
But yay for asian made tools with a lifetime warranty
Old 08-01-2011, 01:22 AM   #50
mac1124
Member#: 286146
2003 2.5 TS Wagon
Blue Ridge Pearl
Looks good so far. Good job getting over those obstacles jchretien.
mac1124 is offline   Reply With Quote
What do you guys think of a SPT intake? What do you have? chomponthis231 Newbies & FAQs 28 07-07-2009 09:01 AM
Well, I think we know what the OTHER half of the battle is... Asinine Off-Topic 8 02-02-2009 09:32 AM
Ok, I finished the first draft of Sharky's wedding sermon. What do you think? Asinine Off-Topic 98 02-09-2006 12:01 PM
So I removed the front bumper and the two "slide" clips cracked. Now what? Scott4DMny Interior & Exterior Modification 1 01-29-2006 05:23 PM
What do you guys think of the front end of my car? joefocker20 Member's Car Gallery 13 01-29-2003 07:09 PM
