Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 07-12-2011, 02:04 PM   #1
Cannibal
Member#: 133023
2005 WRX STi
Default Subaru Extra S in Cold Weather
I would like to know people's opinion of how the Subaru Extra S transmission fluid performs in cold weather (<20 deg F). What kind of problems have you experienced in the winter using this fluid?
This trans fluid is recommended in one of the stickies related to trans fluid and after searching it seems like people generally have good opinions about it. But I have not seen many people talk about how it performs in the cold. I found one or two posts about because the fluid is not synthetic that it won't perform as well as a full synthetic in the cold but I think that was just one person stating that. I would like to hear a few more people's opinion on it before I make the switchover. I have Redline in there now and had some problems shifting when the trans was cold. I don't want to go through the winter again with these problems.
Cannibal is offline   Reply With Quote
Old 07-12-2011, 05:14 PM   #2
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
I had redline and extra s. Their both good. Redline one I felt was a bitch to change your first 2-3 gears in cold but once it warmed up(1-2miles) it was fine. Extra S is a lot better. Shifts no problem and does better in cold. Just my 2 cents though
talvai is offline   Reply With Quote
Old 07-13-2011, 03:02 AM   #3
littlewhitewagon
Member#: 103068
11 STI sedan
Been down to 13F, no problem with extra s.
littlewhitewagon is offline   Reply With Quote
Old 07-13-2011, 03:55 AM   #4
dobie0791
Member#: 72713
2005 STi
Extra-S is good stuff and comes as factory fill. It should be fine for all conditions.
dobie0791 is offline   Reply With Quote
Old 07-13-2011, 04:35 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
and done
Old 07-14-2011, 05:30 PM   #6
Cannibal
Member#: 133023
2005 WRX STi
What are the drawbacks of the Extra S being non-synthetic?
I would also still like to hear others opinions of this fluid in the cold.
Old 07-15-2011, 12:56 AM   #7
littlewhitewagon
Member#: 103068
11 STI sedan
The drawback is that your wallet will be heavier which slows your car down.
Old 07-15-2011, 06:50 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
d0000000000000000d........just stop and pull your head out and smell the fresh air
there...wasnt that nice????
now....lets just get this clear.....THERE IS NO PROBLEMS WITH THE EXTRA-S IN ANY WEATHER OR TEMPERATURE UNLESS YOU ARE ABOVE THE ARCTIC CIRCLE
this is what subaru puts in their transmissions from the factory and THAT MEANS that it has to work right
or do you not understand this and why this is important????
jesus...where DO these guys COME from?????
Old 07-15-2011, 10:46 PM   #9
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
On come on Uncle Scotty you should know better. If you have racing fluid for your transmission you get 5times its life and at least 30whp gain.
OP trust me lots of fluids out there. Most will actually cause harm to your syncros. The good ones like the Motul I had are good but not in cold, cause extra whine/noise and only help during race conditions. Why did I choose it then. I needed fluid and most dealerships wouldn't sell me extra s. Took me 2 months to find and convince a dealership to sell it to me.
Get Extra S and be done with it. As good as anything else if not better. I have yet to find 1 thread that is better than it. And best part is, extra s is a lot cheaper.
Old 07-18-2011, 10:05 AM   #10
Cannibal
Member#: 133023
2005 WRX STi
Scotty...Jeez. Calm down a bit. I have every right to ask for more opinions. Yes, I respect your opinion and I thank you for giving it to me but that doesn't mean I can't ask for more. In my car Subaru also spec'd out non-synthetic engine oil. That means they picked out a non-synthetic oil design that works for all the conditions the car will see. But does that mean you would recommend putting non-synthetic oil into your car? I don't think so. Subaru changed the new STi's to coming stock with synthetic engine oil and they had to do it for some reason. Just because they haven't changed to a different design does not mean that there is nothing better out there nor that Subaru doesn't necessarily want to. I just wanted to get some more opinions about this oil over what I found from searching. I have every right to do that without being so much called an idiot on this forum. I did my due diligence and searched before I asked questions and yet I still get this kind response....
I don't need any more responses. Thanks to those who commented back. I will be buying Extra S.
Old 07-18-2011, 12:35 PM   #11
bluesubie
Member#: 767
04 FXT
The cold weather performance of Extra-S is why I won't be running it again. Below freezing, it takes a couple of miles to warm up. Since I do not warm up my car, I got tired of not being able to downshift to 2nd at a turn about a half mile from my house (would just leave it in third). Switched to Mobil Delvac and did not have that problem last winter.
-Dennis
Old 07-20-2011, 05:33 AM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
i have been here a long time and have not seen posts of people being unhappy with the extra s
one of the issues with these gearboxes is that they DO take a mile or 2 to warm up....bfd....deal with it
it never ceases to amaze me that people want to jump into a stone cold mechanical device in below freezing temperatures and expect it to function just the way it does on a bright sunny summer day
subaru likely spent a great deal of research $$$ in extra s and made sure that its performance was temperature balanced as well as they could engineer it
jesus christ
waaaaaaaaaaaaaaaaaaaa....my seat is cold...waaaaaaaaaaaaaaaaaaaa wipe my ass for me please.....waaaaaaaaaaaaaaaaaaaaaaaa
Old 07-21-2011, 04:25 PM   #13
talsnic
Member#: 163097
get the spec sheet, it says it all.
i personally use motul gear 300, with its -60 C (-76F) pour point. smooth even in -40 for me.
too bad i have to hear the carbon syncro's scream every -20 or colder startup (common 08+ STI issue)...
talsnic is offline   Reply With Quote
Old 05-16-2012, 11:26 AM   #14
mattvivsound
Member#: 240772
2011 Impreza 2.5i
Spark Silver Metallic
What is considered the "cold" temperature these problems with Extra S begin?
The reason I ask, is that the cold in Florida is a very different than being cold in Maine.
mattvivsound is offline   Reply With Quote
Old 05-16-2012, 09:07 PM   #15
Web Foot STi
Member#: 39086
2004 STi
I've driven with Extra-S down into the mid teens. The shifts are a little heavy and slow for the first 1/2 mile, or so. Not a big deal, but you can't rush the shifts when you first start out.
Web Foot STi is offline   Reply With Quote
Old 05-17-2012, 08:43 AM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
oh jesus....yer a REAL ****ing idiot arent ya
are your parents related???
Old 05-17-2012, 09:03 AM   #17
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
+1 but got you 1 better. Left car all night out, completely covered to the roof with snow. Outside temp gauge in car read 4 with wind bringing it lower than that. Just like web foot. Dont rush first shifts when you start out. Worked like a champ. Sure somebody out there got worse than me with extra s
Old 05-18-2012, 03:53 PM   #18
mphwang
Member#: 242297
2001 Getter of
Groceries
-15 degree with old extra-s the last couple of winter, things are fine. If you're worried it's too cold, shift through 1-5 with the clutch in, and then go.
mphwang is offline   Reply With Quote
Old 05-21-2012, 08:51 PM   #19
Jimiboon10
Member#: 318027
2008 Wrx
Silver (for now)
you should be fine... been down to 10 F as long as you let it run for a little...
Jimiboon10 is offline   Reply With Quote
Old 05-23-2012, 04:38 AM   #20
subi400
Member#: 216984
1996 Impreza outback
Green
That one guy earlier who doesn't let his car warm up a bit when it is cold and then complains why the trans is stiff is a moron...no really...
You go lay out in like 10 degrees all night and see stiff you will be...
This is going to sound a bit off but will be taken care of soon enough...
I have the lucas 80w90 in my 5 spd tranny and it was a little stiff in the cold but once it warmed up a bit it was much better like after 5 minutes of driving or so.
Going with the extra-S as soon as my wallet has some money in it...
subi400 is offline   Reply With Quote
Old 05-23-2012, 09:35 AM   #21
WRXSleeper
Member#: 43853
2004 WRX Sedan Stg 2
Platinum Silver
imo Extra-S is too expensive, $15 a qt!! If I am going to pay $60 for tranny fluid I am going with Mobil Delvac 75w-90. That is my plan for my next fluid change coming up next month.
WRXSleeper is offline   Reply With Quote
Old 05-23-2012, 10:40 AM   #22
drewmob
Member#: 214192
2003 WRX
Use whatever you want, but to complain about the price of something that you replace every 30k? Come on, that's just silly. Using delvac will save.... $20? Over the course of 30k miles that's 0.0006 cents per mile.
IMO spend the extra & prevent doing it twice.
drewmob is offline   Reply With Quote
Old 05-23-2012, 12:30 PM   #23
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Sounds like you got ripped off. Went to local dealership with my own containers. Sold it to me for $6 a quart. You should probably start calling around for pricing instead of complaining about
Old 05-24-2012, 11:34 AM   #24
littlewhitewagon
Member#: 103068
11 STI sedan
Or some of us have small drums in our garage and are willing to sell it at a very reasonable price...
Old 01-07-2014, 01:31 PM   #25
ShadowIMg
Member#: 31519
2012 Torque Egg
2001 2.5RS Coupe
Necro'ing this because holy crap cold winter.
I have Extra-S in the spec.B, and I can say that at -18F (-40F windchill), it's not OK. I park the car outside, and park in gear as one should. I should not have in this temperature.
Extra-S is less than 15k old, only street driven, so reasonably fresh.
It was actually hard to get the car out of gear and into neutral, stick just didn't want to move. Once it was into neutral, it was so thick that just letting the clutch out stalled the motor. After about 1min warmup it was fine idling in neutral. After about 3 min I could get into all of the gears and started on my way. From there it was much like driving in the <20F temps, just sluggish shifts and a little grindy 1->2 if you go too fast. Took about 10 full minutes before it was reasonably normal in behavior.
There was also an awful pump-sounding noise for the first 5 seconds or so after starting the car, have a feeling this was the pump responsible for trying to move the trans fluid.
I think 5w30 is also a bit thick for these temps, but that's a different discussion.
ShadowIMg is online now   Reply With Quote
Engine Break In, in cold weather gnode Newbies & FAQs 12 11-18-2009 09:45 PM
people who commute on a motorcycle in cold weather and complain about being cold cnw Off-Topic 51 10-20-2009 03:09 PM
Mazda Hydrogen Vehicle Takes Part in Cold Weather Testing in Hokkaido, Japan NYCshopper Non-Subaru News & Rumors 1 02-20-2007 11:50 PM
'Kick' while cruising in cold weather? SlideWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-27-2002 11:08 AM
to those in cold weather climates (clutch problem)... shukes24 Normally Aspirated Powertrain 5 11-18-2000 07:13 AM
