Welcome to the North American Subaru Impreza Owners Club Wednesday August 5, 2015
Old 03-03-2001, 08:00 PM   #1
Tangmere
Member#: 572
Post GRM says SCCA putting WRX into A Stock
Not that I'm complaining. It certainly doesn't belong in GS with the normally aspirated RS. The Audi TT goes in AS too.
Tangmere is offline   Reply With Quote
Old 03-03-2001, 08:12 PM   #2
autorex
Member#: 3677
Post
But it was put in GS. Before the classing, I believe that most people thought it would go into AS. However, during the February SEB meeting, it was classed into GS.
Given the time it takes to go to press, I'm sure that GRM put that in way before the meeting.
autorex is offline   Reply With Quote
Old 03-03-2001, 08:13 PM   #3
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Post
Let hope the PAX is big...otherwise its going to get killed in AS
Old 03-03-2001, 09:57 PM   #4
kelley nelson
Member#: 135
Post
Agreed with autorex, it is a lead time issue. They had to put that text together probably 3 months before it shows up on the newsstand. Perhaps even a bit longer considering that GRM is a bi-monthly mag.
The latest info I have seen from Howard Duncan, the car classification expert is GS for the WRX.
kelley nelson is offline   Reply With Quote
Old 03-05-2001, 01:22 PM   #5
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
I beleive the Type R is/was more dangerous in GS than the WRX could ever be. the ITR has much better handeling out of the box, and the little bit of turbo lag in the WRX wont help it in the low speed tight turns of an Autocross...This is an old worn out debate of the ITR in GS.....the WRX is gonna be in GS, like it or not. If you dont like it move up to STS or STR to get away from it.I did, and now I have an STR prepped Integra GSR to fight with....grrrrrrr
STiShawn is offline   Reply With Quote
Old 03-05-2001, 02:52 PM   #6
hillman
Member#: 1303
2007 Not a Subaru,
thank God.
Post
I'll be well and truly shocked if a WRX is not faster than a Type R.
<table>
<tr><td><td>WRX<td>ITR
<tr><td>HP <td>227@6000 <td>195@8000
<tr><td>Torque <td>217@4000 <td>130@7500
</table>
The Integra is a lot lighter, but it will need to be and then some.
hillman is offline   Reply With Quote
Old 03-05-2001, 03:10 PM   #7
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Post
I don't think it would get killed in AS. I think it would kick@ss. I compared my times in STS to a boxer and a S4 in AS here is the KC Region SoloII and I ran about the same times. At the time, I only had springs, catback and an intake.
I would love to run in AS with a WRX on a set of BFG or Kumho race tires and some adjustable struts.
Pat
MY00 Impreza RS Sedan
Tires SO-2 PP's
[This message has been edited by KC_TopDog (edited March 05, 2001).]
Patrick L is offline   Reply With Quote
Old 03-05-2001, 03:10 PM   #8
jeffg
Member#: 2958
2001 WRX (GC8)
Post
Faster is not the issue. Comparing stock cars the ITR is amazing. It handles much better than a lot of "mod'ed" cars do. IMHO: The secret to autocross is balance. The ITR does a lot of things really well, where as some other cars are good in one field, but lacking in others. A good AutoX course will challenge all of the fields of a car. Acceleration, corner turn in, handling on throttle, and many more. I will be eager to see what happens.
Jeff
jeffg is offline   Reply With Quote
Old 03-05-2001, 04:31 PM   #9
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Pat-- STS has a very soft PAX, so don't put too much stock in that. Besides, the S4 is one of the many doormats of A Stock. If you want to compare, you should compare to a competitive AS car, like a Porsche 968, Boxster, or Honda S2000. Trust me, the WRX would get annihilated against those cars.
I think 550lb is sufficiently lighter to make the difference in autocross. Like I said, this year will tell... and we'll also see how the cars stack up in NASA's Touring Car events.
ColinL is offline   Reply With Quote
Old 03-05-2001, 05:03 PM   #10
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Post
ColinL...I totally agree with you...you forgot about a more agile/lighter TT Quattro
Old 03-05-2001, 05:16 PM   #11
David S. Wallens
Member#: 3492
2000 Impreza wagon
Porsche 911, Miata, Mini
Post
Just another thought: A lot of Stock class ringers aren't dominant during their first year, as it usually takes a little while to get up to speed. For example, the Neon didn't win D Stock until 1996, the Type R didn't win G Stock until 1999, and the MR2 Spyder didn't win B Stock last year. I'm looking at national-level results, so your mileage may vary.
David S. Wallens, managing ed
Grassroots Motorsports www.grassrootsmotorsports.com
[This message has been edited by David S. Wallens (edited March 06, 2001).]
David S. Wallens is offline   Reply With Quote
Old 03-05-2001, 08:55 PM   #12
autorex
Member#: 3677
Post
Another thing to consider is that you really can't compare the cars at a local level. I really believe the true test is at the National levels where the drivers can really push the car to the limit.
David is right about taking time at the national level. Everybody thought that the new Celica GT would win ES. The old Celica won this past year.
At my local level, I'm looking forward to the car being in GS. One of our best drivers in GS drives a ITR. A friend (who is just as good or better as the ITR) is also getting a ITR. I stink in autocrosses and I'm hoping that I can better judge my skill and improvements against these drivers. I figure I should be able to tell a whole lot better than trying to run in my fully prepped CRX that hides too many of my mistakes.
Old 03-05-2001, 10:59 PM   #13
AutoXr
Member#: 2047
'04 Audi S4
Red
Post
. . .And one more thing, stay on stock tire this year too. 'Nothin' better to show up your mistakes than stock tires, especially RE92's. I plan to use mine up this year and put winter studs on the stock wheels next year.
AutoXr is offline   Reply With Quote
Old 03-06-2001, 12:01 AM   #14
David S. Wallens
Member#: 3492
2000 Impreza wagon
Post
When the current issue went to press, the WRX was slated to go into A Stock. Then it was moved to G Stock, but by then the issue was already at the printer. That's why we usually remind people to get the official word from the SCCA, as sometimes things do change at the last minute. Sorry for the confusion.
We can usually make correction up until about two and a half or three weeks before you guys see the mag.
Old 03-06-2001, 12:23 AM   #15
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
This has been covered, and I don't see the WRX as being any more dangerous than the Integra Type R in GS. This year will tell, and if it turns out to be a year of dominance for the WRX in GS then the stock class reorg will take care of that... assuming it happens in 2002.
Old 03-06-2001, 10:37 AM   #16
hillman
Member#: 1303
2007 Not a Subaru,
thank God.
Post
Colin, where do you get a 550 pound difference from? The published stock weights give a 400 pound difference. Still massive; but is that enough to cancel the 75% peak torque advantage?
'Horsepower sells cars; torque wins races.'
Old 03-06-2001, 11:05 AM   #17
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
There is this nifty thing called gearing-- it might be worthwhile to calculate torque at the wheels if you're going to compare. I definitely agree that torque wins races, but a peak torque figure doesn't tell you much. Considering the boost bleedoff, I have trouble believing the dyno chart SOA has published in the WRX brochure.
While you're doing that you might also notice that the ITR has a much closer ratio gearbox, a nice thing for autocross (especially fast ones, like a National Tour event) and particularly useful for roadracing.
At any rate, acceleration is but one thing. Weight works against you in cornering and braking as well, and even a 400lb weight difference could be enough.
And again, let's wait and see.
Old 03-07-2001, 08:58 PM   #18
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
Post
With the WRX going into GS I can tell you that it will be a very potent autoX'er if it handles anything like my AWD talon.
ChrisW is offline   Reply With Quote
FS : 09 WRX Dark Grey Stock Rims + Stock Tires mrfisch13 Wheels/Tires 11 11-06-2010 05:24 PM
quick question about putting wrx brake into a RS qualityracer Brakes, Steering & Suspension 4 11-19-2008 11:42 PM
so they say people who are into guns are also into knives... lionken07 Off-Topic 33 10-10-2008 06:57 PM
Any one put WRX suspension into a GC? Impreza911 Brakes, Steering & Suspension 1 06-02-2005 10:21 PM
