#1 |
Member#: 220204
SCIC
***********We have seen a lot of posts regarding the removal of stuck cam bolts and methods of how to hold the cam gear in the futile attemps to remove these bolts with success. We have heard of horror stories of drilling, special bits and long times to do it, we have personally seen the results of dealerships using cut-off wheels/air chisels and the damage left behind on the gears that the dealer reinstalls.
the video was not edited, the motor we have is a ej205, three of the four cam bolts came loose with an impact gun, the forth one did not. this method for us is so fast that it's not worth the time to clamp the timing belt together, nor to use the cam tool. On really tight ones with the tool, we have chipped the gears. we have also seen broken head castings due to using a wedge/prybar on the cam lobes. Often the cam bolt get really tight due to heat cycles, with the welding we do, the rapid heat applied to a stripped bolt makes them come off like butter, not damaging the cam gear at all. If you are local to us, we would perform this operation for $20 per bolt <iframe width="425" height="349" src="http://www.youtube.com/embed/WjZ0XtLYtzc" frameborder="0" allowfullscreen></iframe> http://youtu.be/WjZ0XtLYtzc
#2 |
Member#: 162174
Vehicle:05 CGM STi - SOLD 13 SWP STi - TITS |
Thanks for the video. This will come in handy when I pull my heads off.
#3 |
Member#: 220619
Vehicle:04 wrx wagon silver |
nice trick! what i always do is put some valve grinding compound in the allen head, prevents it from striping
#4 |
Member#: 268354
NESIC
Vehicle:02 WRX 05 LGT Slow Automatics |
Awesome! Thanks for the advice, wouldnt have thought of doing that
#5 |
Member#: 136396
Vehicle:2012 wrx white |
Very cool thanks for posting up!
Mike |
#6 |
Member#: 265692
SCIC
is there a way to post/embed the video so it plays in the forum and not a link to it?
#7 |
Member#: 218435
NESIC
Vehicle:2001 18g'd Rs Coupe 2 doors less whores |
where was this when my friend too FOREVER to saw the damn gear off lol
#8 |
Member#: 245333
Vehicle:2002 WRX psm |
done this more times than i can count that trick works 90% of the time on almost any broken or stripped bolt... great post!!!
#9 |
Member#: 290942
NWIC
Vehicle:96 impreza ugly green for now lol |
good deal!
#10 |
Member#: 292465
awesome write up, will use this in the future!
#11 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
nice vid guys
#12 |
Member#: 275239
Vehicle:2002 Rallying WRX Rock chipped MBP |
very awesome trick!
#13 |
Member#: 186271
NESIC
Vehicle:2002 Bugeye Sedan WRB |
God damn... I know what I'll be doing if I round out an Allen bolt now.
Awesome vid. |
#14 |
Member#: 244085
Not to ruin anything......but the zipp zipp of that impact gun is a little bit less than realistic....(maybe in a perfect world) so what does he tell you about what the cam dowell is rounding out ?when they dont just pop off? truth be told....FYI....leave the belt on, use a strong 10mm bit, and buy the damn cam wrench cheapskates......if you dont/won't then go ahead and weld yourself a CAI for a flood zone because your obviously retarded....I know its sounds great but this is not your normal occurance, for it to be that easy........in a worst case senario use a craftsman sprialed nut remover or use a die grinder and cut the top of the bolt into a hexagon and use a 17mm 12pt socket to remove it with (the cam sprocket tool! cheapskates!!!!!!)
#15 |
Member#: 214243
thanks for the video
#16 |
Member#: 297389
lol thats what i had to do
#17 |
Member#: 81247
South East
Vehicle:2005 PSM WRX TD04L-19T Stage 2ish |
Wicked sweet, had to do the same with some suspension hardware,
#18 |
Member#: 20765
RMIC
Vehicle:2008 Forester XT 6mt/18g-xt |
awesome, thanks.
Just stripped one of mine last night - now I have to see if I can get my friend to bring a welder over to the house. |
#19 |
Member#: 243512
Awesome video and a great tip. Thanks!
#20 |
Member#: 3782
South East
Vehicle:02 WRX WFC#040 Clean on 19's |
Genius level
#21 |
Member#: 147056
Vehicle:7 sti |
does the composite cam gear warp under heat load from the welder?
i. always break cam bolts loose with a breaker bar,pipe extension wedged in between the hoist and turn the cam itself, with the timing belt still attached. ive never had a problem with my method. :edit: nice thinking out of the box +1 |
#22 |
Member#: 188705
Vehicle:GD Widebody STI Lexus Pearl White |
Thanks for the advice! Very helpful
#23 |
Member#: 303909
PRSIC
Vehicle:2002 wrx silver |
tremendo video! buen trabajo!!
#24 |
Member#: 341930
Vehicle:o3 wrx Psm |
i just did this on ALL FOUR CAM BOLTS! good thing i had 4 brand new axle nuts laying around. i pulled out my miller welder and welded em on and broke out my 3/4 in mikita impact gun and BAM! off like butter!!! I DUNNO ABOUT $20 a piece to remove but i did it myself for free
#25 |
Member#: 120152
Vehicle:2006 06 WRX, 86 FMOD Blue, White/Red |
Wish I saw this a little while ago. Tried welding allen keys to the inside of the bolt and ended up shearing those in half. Now I have a mess to clean up before I can try this method.
| Thread Tools | |
| Display Modes | |
| Stripped cam gear bolts | scoobywagon06 | Factory 2.5L Turbo Powertrain | 25 | 04-13-2011 08:59 PM |
| How do you fix a stripped seat bolt? | Jncominco2 | Rocky Mountains Impreza Club Forum -- RMIC | 11 | 02-19-2009 08:32 PM |
| stripped cam sprocket bolt | limestoner | Factory 2.0L Turbo Powertrain | 4 | 06-02-2006 08:55 AM |
| Stripped banjo bolt hole in brake caliper? Fix it!!! | thrdeye | Brakes, Steering & Suspension | 0 | 10-14-2005 03:10 PM |
| Anyone ever have a Intake Cam bolt snap off while driving???? | fastlane | Factory 2.0L Turbo Powertrain | 6 | 05-16-2005 05:18 PM |
