Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 03-31-2013, 03:49 AM   #26
FLUBYUx2
Member#: 3856
2001 Impreza 2.5RS
sedona red pearl
Glad I found this. The gears on my 207 are broken off and my vice grips barely hold the core of the gear at all. I'm definitely doing this tomorrow!
FLUBYUx2 is offline   Reply With Quote
Old 04-30-2013, 04:31 PM   #27
jWuRaXn
Member#: 355084
nice!
jWuRaXn is offline   Reply With Quote
Old 05-16-2013, 02:06 AM   #28
aRODhobbs
Member#: 356566
Wish I came across this trick when mine got stuck
aRODhobbs is offline   Reply With Quote
Old 05-16-2013, 09:38 AM   #29
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
i wonder if this trick would work on other stripped out bolts?
Daddy_Digital is offline   Reply With Quote
Old 06-05-2013, 02:54 PM   #30
StarburstAutos
Member#: 344253
03 WRX Sedan
primer black
Wow nice I will try this next time instead of drilling. Thanks for the video!!!
StarburstAutos is offline   Reply With Quote
Old 06-17-2013, 11:27 PM   #31
prezarevo
Member#: 266930
2004 WRX
1. Remove valve cover
2. Get 1 1/8" wrench
3. Crank up air compressor
4. Place and hold 1 1/8" wrench on end of cam inside of head and firmly hold steady.
5. Apply good 10 mm bit and an ass slamming impact gun to cam bolt ( hold straight)
6. Tell your self " damn i'm good " because you easily removed that bolt.
Dont assume any impact will break these free. A good slammer will free those bolts up in a matter of 6-10 hits. And as someone said " get a good bit". Look into nitro-cat impact guns. They're a bit expensive but a few more dollars will save you lots of dollars.
prezarevo is offline   Reply With Quote
Old 06-21-2013, 07:25 AM   #32
Performance direct
Member#: 360098
Hi I have a Subaru forester none turbo. After 2000 km there is no engine oil. What could be the problem?. Any assistance?.
Performance direct is offline   Reply With Quote
Old 08-06-2013, 03:45 PM   #33
Storm
Member#: 5218
96L Most Over-
Developed Beater
This is an excellent way to shear the head castings which locate the cams fore and aft. (thrust clearance).
Do not use a manual impact tool on the cams.....it is not even close to the right way to remove these pain in the butt bolts.
Jay
Old 08-07-2013, 10:33 PM   #34
johnno419
Member#: 290519
02 bugeye
black
nice tip!
johnno419 is offline   Reply With Quote
Old 10-02-2013, 07:14 PM   #35
EvenTheScore
Member#: 367790
2004 Imprezza wrx
white
Very helpful
EvenTheScore is offline   Reply With Quote
Old 11-05-2013, 03:51 PM   #36
oldiesubie
Member#: 372874
This would have been great to see a few years back! I'm glad it's compiled for people now to use.
oldiesubie is offline   Reply With Quote
Old 01-20-2014, 10:11 AM   #37
AlexWRXbruh
Member#: 373710
2002 Subaru WRX
Porsche White
Ive only done this once, but at first i had issues removing the cam bolt with the valve cover on...
If you have the motor on a stand grab an adjustable wrench with a good length handle (you'll need the torque. Put in on the hex part of the camshaft inside the valve cover and hold it still while another person takes a breaker bar to the cam gear bolt. Works without failure every time. Now hopefully you WONT strip ur cam gear bolts anymore
AlexWRXbruh is offline   Reply With Quote
Old 01-22-2014, 01:48 AM   #38
subazone
Member#: 272745
2005 Impreza WRX
Very creative BUT BEFORE YOU USE 10mm ALLEN TOOL, guys, make sure to use SNAP-ON ONLY! The problem with the cam bolt is not the bolt itself but cheap auto parts store quality of the tool. I purchased 1/2 inch drive 10mm Allen from SNAP-ON and it works like a champ! No more problems, and I rebuild lots of EJ motors. Good luck! everyone!
subazone is offline   Reply With Quote
Old 02-20-2014, 03:59 AM   #39
Bugeye_Scoob
Member#: 382173
Great video
Bugeye_Scoob is offline   Reply With Quote
Old 02-23-2014, 12:03 PM   #40
Jimbo000222
Member#: 382596
2004 Impreza WRX
Subie Blue W/Red Mudflaps
Sweet!
-Jim
Jimbo000222 is offline   Reply With Quote
Old 03-17-2014, 10:49 AM   #41
xmakrav22
Member#: 384811
2003 Impreza WRX
Hey that was very useful. Thanks
xmakrav22 is offline   Reply With Quote
Old 06-17-2014, 12:17 PM   #42
J_Levesque1
Member#: 381337
awesome, this may come in handy someday!!
J_Levesque1 is offline   Reply With Quote
Old 07-26-2014, 06:21 PM   #43
qwiksubi
Member#: 353385
great information. thanks!
qwiksubi is offline   Reply With Quote
Old 08-07-2014, 12:42 AM   #44
SubiDR
Member#: 398372
2002 Wrx impreza
I just came across this for the first time now that I'm a subi owner. Bolts were installed by Zeus himself I'm sure of it. Either way, I used an Irwin bolt extractor. Hammered that puppy on used 1 1/8 wrench on cam and HWAMMY. It's all she wrote. I like this method even for bolts that aren't stripped because you can reuse the bolt and only use Allen for torquing on install not removal. P.s. I broke my snap on 10mm socket with a breaker bar.
SubiDR is offline   Reply With Quote
Old 09-17-2014, 03:41 PM   #45
Forest Gibbany
Member#: 401886
02 wrx
Awesome, I will definitely keep this in mind
Forest Gibbany is offline   Reply With Quote
Old 10-11-2014, 07:44 AM   #46
bigdogtrucksales
Member#: 403128
2004 Impreza WRX
Java Black Pearl
awesome tip
bigdogtrucksales is offline   Reply With Quote
Old 10-16-2014, 04:56 AM   #47
sadadcz
Member#: 404064
where was this when my friend too FOREVER to saw the damn gear off lol
sadadcz is offline   Reply With Quote
Old 10-26-2014, 02:06 AM   #48
kohlby777
Member#: 271073
2003 Impreza WRX
Wish I would of seen this a month ago... Had to cut my right exhaust cam bolt off with an angle grinder when it stripped out
kohlby777 is offline   Reply With Quote
Old 10-27-2014, 07:07 AM   #49
fsdgfsd
Member#: 404892
Wicked sweet, had to do the same with some suspension hardware,
fsdgfsd is offline   Reply With Quote
Old 11-01-2014, 12:42 PM   #50
lnhljkhk
Member#: 405305
I'm not even a slick spammer.
lnhljkhk is offline   Reply With Quote
Stripped cam gear bolts scoobywagon06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 04-13-2011 08:59 PM
How do you fix a stripped seat bolt? Jncominco2 Rocky Mountains Impreza Club Forum -- RMIC 11 02-19-2009 08:32 PM
stripped cam sprocket bolt limestoner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-02-2006 08:55 AM
Stripped banjo bolt hole in brake caliper? Fix it!!! thrdeye Brakes, Steering & Suspension 0 10-14-2005 03:10 PM
Anyone ever have a Intake Cam bolt snap off while driving???? fastlane Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-16-2005 05:18 PM
