Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Alaskan Impreza Club
Old 07-15-2011, 03:25 AM   #1
0x444A
Member#: 270008
2014 MB CLA45 AMG
2015 Audi Q3
Default My WRX can sing?
Hey guys,
So just yesterday I noticed a whooshing sound coming from my engine bay when I put in some boost. Chano describes it almost like a cat hissing. It doesn't make the sound unless I'm under load. Best part is, when I go into WOT, the hiss turns into a very low pitch whistle around 4000-42000rpm and on.
I figured it was some kind of leak so i took some logs. Weird thing is the car seems to run perfectly fine. Oil was good, logs show that i'm hitting target boost, AFR doesn't dip below 11.1:1, and no knock detected at all.
The sound seems to be coming from the driver side more near the center. So I figure id check the BPV gasket, looked perfectly fine. I'm completely out of ideas on what it could be.
I'm setting up an appointment with conti to check it out sometime next week but hoped someone might know a quick solution so I don't have to leave the car there all day.
Anyone have any ideas?
Thanks!
0x444A is offline   Reply With Quote
Old 07-15-2011, 03:53 AM   #2
crash907
Member#: 250938
Check all the hoses and clamps to the intercooler. My 02 was doing the same thing after I pulled the intercooler one time, I thought it was the bpv leaking as well but it turned out I forgot to tighten the hose connecting the intercooler to the intake manifold.it was building pressure and leaking causing a whistling sound under engine load.
crash907 is online now   Reply With Quote
Old 07-15-2011, 11:44 AM   #3
0x444A
Member#: 270008
2014 MB CLA45 AMG
2015 Audi Q3
Ah ok I'll go take a look. I just find it annoying that I haven't touched anything around there yet its pretty obvious that something in that area went loose.
Is it a pain in the ass to get to that hose?
Old 07-15-2011, 01:35 PM   #4
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
If this is a 2011 WRX you don't have the hoses described by crash unless you have changed your stock setup. Boost leak check the car with a boost leak tool maybe. Easy to build one or stop by a local shop that has one.
TurboSetch is offline   Reply With Quote
Old 07-15-2011, 01:44 PM   #5
0x444A
Member#: 270008
2014 MB CLA45 AMG
2015 Audi Q3
Yea its a 2011 completely stock setup for the hoses. I do have an invidia divorced DP and Q300, but nothing outside of that was touched. Just looking around and poking at hoses, everything seem to be pretttty darn tight. As far as boost leak is concerned, i'm not entirely sure what the symptoms of that are but wouldn't the car lose boost? I'm boosting 16.5-16.8 PSI and holding there pretty well, which is where i've always been.
If it was a boost leak, where might the problem exist?
I've also set up an appointment with Continental to look at it next Tuesday.
Thanks for all your guys' help btw, love this community.
Old 07-15-2011, 01:51 PM   #6
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
It could be something as simple as an oring, a small hole in the intercooler, loose hose clamp on the intake.
A very small boost leak can make noise but not cause a boost drop due to the fact the turbo can still work harder to compensate for the leak. Symptoms however tend to be a richer than normal condition in some cases, increased knock, increased intake air temps. Again a slight leak may have only very slight symptoms.
Check the hose clamps around the throttle body area on the drivers side of the intercooler.
Old 07-15-2011, 02:02 PM   #7
0x444A
Member#: 270008
2014 MB CLA45 AMG
2015 Audi Q3
These seem pretty tight:
Can you see anything that I might b missing?
Old 07-15-2011, 03:25 PM   #8
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
its the torco!!!!
Marlons101 is offline   Reply With Quote
Old 07-15-2011, 03:29 PM   #9
0x444A
Member#: 270008
2014 MB CLA45 AMG
2015 Audi Q3
Originally Posted by Marlons101
its the torco!!!!
LOL
Old 07-15-2011, 03:32 PM   #10
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
lol sorry.
id contribute...but im pretty stumped on your problem myself and I know little about '11 engine bays.
Old 07-15-2011, 03:39 PM   #11
0x444A
Member#: 270008
2014 MB CLA45 AMG
2015 Audi Q3
lol sorry.
Thats ok man lol thanks anyways, if this problem adds to the community's pool of knowledge then awesome
Old 07-15-2011, 03:52 PM   #12
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
what side of town you on?
Old 07-15-2011, 03:53 PM   #13
0x444A
Member#: 270008
2014 MB CLA45 AMG
2015 Audi Q3
Southside by lake Otis and 68th
Old 07-15-2011, 04:04 PM   #14
SaxMan9801
Member#: 128034
2004 SVT Cobra
11' BMW X3 12' Tundra
DJ -just keep your right foot securely pegged to the floor-then you will no longer hear the noise
SaxMan9801 is offline   Reply With Quote
Old 07-15-2011, 04:07 PM   #15
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
Check the intercooler, specifically where the end tanks are clamped on. Those are notorious for coming loose.
retrac is offline   Reply With Quote
Old 07-15-2011, 04:08 PM   #16
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
so whats the last mods you installed? exhaust?
edit. follow retracs advice. subaru mad scientist
Old 07-15-2011, 04:14 PM   #17
0x444A
Member#: 270008
2014 MB CLA45 AMG
2015 Audi Q3
LOL that works
Old 07-15-2011, 04:18 PM   #18
ridestreet84
Member#: 132030
2007 obp STI
broken again
They even make a kit to fix it, it's a common problem, I mean look at the intercooler it has a metal core and a plastic endtanks
ridestreet84 is offline   Reply With Quote
Old 07-15-2011, 04:20 PM   #19
0x444A
Member#: 270008
2014 MB CLA45 AMG
2015 Audi Q3
Invidia dp but that was about 2 months ago, I'll triple check the clamps when I get home
Old 07-15-2011, 05:03 PM   #20
0x444A
Member#: 270008
2014 MB CLA45 AMG
2015 Audi Q3
Shud I need to get under the car for anything?
Old 07-15-2011, 06:50 PM   #21
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
No...Unless you like the way it feels. lol
Where the IC bolts to the turbo there is an oring. Doubt this has failed or pushed out but worth a look...
Boost leak check tool right now would be your best friend.
If you don't find it and want to take it to my shop in wasilla I will take a quick look at it.
Old 07-15-2011, 06:56 PM   #22
0x444A
Member#: 270008
2014 MB CLA45 AMG
2015 Audi Q3
Pm sent
Old 07-15-2011, 07:30 PM   #23
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
At least you still are under warranty as well I assume.
Old 07-15-2011, 07:33 PM   #24
0x444A
Member#: 270008
2014 MB CLA45 AMG
2015 Audi Q3
Well I hope they don't give me grief about my exhaust
Old 07-15-2011, 07:43 PM   #25
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Don't know for sure but I doubt it. Unless the warranty specifically states what voids it I think they have to prove your modification caused the failure.
http://www.impalaclub.com/naisso/magmoss.htm
Antonio Banderas can sing well! RA29 Off-Topic 8 11-13-2006 06:26 PM
Let me sing you a Christmas song.. Then you can sing one! Sephro Off-Topic 4 12-08-2005 11:18 AM
Here's something all my people can sing... JewPac42 Off-Topic 8 03-25-2005 12:57 AM
Scott Baio can sing. xfactor834 Off-Topic 14 01-14-2004 01:46 PM
U 2 can sing along !! Weasel 555 Tri-State Area Forum 3 10-18-2001 06:12 PM
