Tire & Wheel Forum sponsored by The Tire Rack |
07-15-2011, 01:02 PM | #1 |
Member#: 91212
Vehicle:2011 WRX 5DR Satin White Pearl |
How long is it safe to run the space saver spare? (2011)
How long (miles) is it safe to run the factory space saver spare on a 2011 WRX? With the diameter differences, is it even safe to limp to the next exit?
I have a 100-mile daily commute and if I were to get a flat, I don't want to put on the spare and then kill a diff trying to limp the car back home if it is not safe. Edit: This is a pre-emptive question...knock on wood, I don't have a flat. Thanks in advance.
07-15-2011, 01:46 PM | #2 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
07-15-2011, 01:56 PM | #3 |
Member#: 91212
07-15-2011, 02:37 PM | #4 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
for as little time and as few miles as possible and below 50mph
just like the owners manual says |
07-15-2011, 02:40 PM | #5 |
Member#: 91212
The owner's manual in my old Legacy made no mention of differential damage. I had not read all of the way through the WRX manual (amended or otherwise). At any rate, the manual does not always seem to have the best info.
I appreciate the response. |
07-16-2011, 06:57 PM | #6 |
Member#: 192599
Vehicle:2004 STI 2007 Outback Wagon |
Your 2011 WRX has open diffs I believe. So it doesn't matter
07-16-2011, 07:37 PM | #7 | |
Member#: 73223
SCIC
Vehicle:2009 STI |
While it's arguably one of the most redundant manuals i've ever read the information it does provide will help maintain your warranty. I'll take that advice over a stranger's on the internet anyday...
07-16-2011, 10:44 PM | #8 |
Member#: 192599
nice.... They want you to drive as few miles as possible and under 50 because the tire itself is a pos. Not that you will damage the diffs. I don't have time to explain how diffs work. You've been on here long enough, read the stickies. |
07-17-2011, 04:33 PM | #9 |
Member#: 197488
Vehicle:2007 STI EFI Logics WRB |
i say scrap the spare and just buy a full rim and use that as a spare
07-17-2011, 08:33 PM | #10 |
Member#: 192599
winning |
07-18-2011, 02:32 AM | #11 |
Member#: 239875
TXIC
Vehicle:2010 STI |
the spare they give you (I'm pretty sure) = the same diameter as your stock set up.
So shouldnt matter to limp to the nearest tire shop. |
07-18-2011, 12:15 PM | #12 |
Member#: 178811
Vehicle:2011 White Corolla Over 400hp |
It's within 2% of your stock diameter I believe. The reason for any caveats in the manual is as another poster said: it's a POS tire. It'll pop if you get it to hot (read: drive over 50, drive too long).
is it safe to run OBX cam gears? | chubifcr | Built Motor Discussion | 7 | 06-08-2011 03:25 PM |
Is it safe to run a stage 2 with a perrin sticker? | NJ_wrx | Engine Management & Tuning | 3 | 06-04-2011 09:46 AM |
If the government shuts down, how long is it likely to last? | Capt Crunch | Political Playground - Chaotic Neutral Edition | 42 | 03-03-2011 01:16 AM |
is it safe to run a 6 spd w/o an dccd controller | brandonswrx | Transmission (AT/MT) & Driveline | 14 | 09-22-2008 06:02 AM |
is it safe to run synthetic now | subarific | Newbies & FAQs | 13 | 02-21-2007 11:01 PM |
