Old 04-10-2013, 12:15 AM   #1
Vaultorb
Member#: 351747
2003 WRX
Default Replacing instrument cluster affect number of miles?
Hey guys, im thinking about replacing my current cluster with a used 02-03 wrx cluster cause my current one is too much of a hassle to try fixing. My question is will my odometer still read the correct mileage e.x. 90,XXX miles should i put in a different cluster? Thank you
Vaultorb is offline   Reply With Quote
Old 04-10-2013, 12:37 AM   #2
pezcore
Member#: 178045
06 WRX
CGM
No, the mileage is stored in the cluster so it will be wrong if you swap clusters. Read up on reprogramming the clusters, there are people that can do it for you and make it read the mileage you want.
pezcore is offline   Reply With Quote
Old 04-10-2013, 12:37 AM   #3
10panxianshi
Member#: 345272
2008 WRX
Most cars the mileage stays in the cluster. I'd bet subarus are the same, but I can't say definitely
10panxianshi is offline   Reply With Quote
Old 04-10-2013, 02:29 PM   #4
Vaultorb
Member#: 351747
2003 WRX
Thanks for the responses guys, after reading up on how to reprogram a cluster to read the correct mileage people were stating that it was illegal to change the mileage reading on the cluster? Is there any legal way to reprogram the new cluster to read the correct mileage? located in CA btw
Old 04-10-2013, 03:36 PM   #5
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Yes. There are certified repair shops who are allowed by law to set the odometers. They will usually require some proof like the old cluster and the new cluster together.
Off the top of my head, I think one place was called Tacoma cluster? Or something like that. I know searching NASIOC will bring up threads with this info.
Old 04-10-2013, 04:35 PM   #6
Vaultorb
Member#: 351747
2003 WRX
okay well i contacted this guy selling this cluster on ebay
pictures:
however, he's saying that it was from an AT and will not work for MT? is that actually true? because i don't see how it wouldn't work on MT when its the exact same thing?
Old 04-10-2013, 04:39 PM   #7
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
The MPH will be off because the final drive in an AUTO is different then the MANUAL. It will work fine but you will be going slower then you think you are.
dangerousatom is offline   Reply With Quote
