Old 07-17-2011, 04:03 AM   #1
thisishomer96
Member#: 244497
2004 WRX
Java !!!
Default 04 WRX Brembo swap...Rear e brake wont work...
Hey guys well I have a 04 wrx, did a brembo swap front/rears, rotors, pads, and ss lines. Problems is now the rear emergency brake will not work.. i did everything right with the rear brake adapters and all and i used the DBA rotors that allowed the emergency brake to work. I did not change the emergency brake pads though, i left them alone. the only thing i can think of is maybe i needed to adjust them? and how do I? did I miss anything?
thisishomer96 is offline   Reply With Quote
Old 07-17-2011, 12:30 PM   #2
wheatpaste
Member#: 170747
2004 WRX Wagon
Easiest way is at the rear brake. There is a small slot on the rear of the backing plate at the bottom that has a rubber cap in it. Pop out the cap and you will see the fine adjustment wheel. Use a screwdriver to rotate the adjustment wheel and try to adjust the same amount on each side. You will have to experiment with which way to rotate the adjustment wheel, as I don't remember off the top of my head which direction expands the shoes and which direction contracts the shoes. Do a small amount and pull up on the parking brake lever to see if the brake catches. Repeat until the lever pulls up nicely.
If you can't get enough adjustment that way, you will have to adjust the cable at the lever.
wheatpaste is offline   Reply With Quote
Old 07-17-2011, 02:48 PM   #3
thisishomer96
Member#: 244497
2004 WRX
Java !!!
sweet man ill try that... ill get back to you if it fails....
Old 07-18-2011, 09:04 PM   #4
thisishomer96
Member#: 244497
2004 WRX
Java !!!
Default Rear Brembo brke swap problem in a 04 WRX...
well today itried the adjustment screw to adjust the rear e brake drum thing.. It didnt work, seems like with the DBA rear roters i might need different bigger pads that will fit. i adjusted the rear rotor drum brakes to its max and there is still a huge gap between the drum pads and the drum.. any suggestions or have anyone used or done a rear brembo brake swap into a 04 wrx? I have the DBA slotted rear rotors with the adapters..my goal is to be able to use the emergency brake. thanks
Old 07-18-2011, 09:52 PM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
which DBA rotors did you get exactly (P/N?)
is it possible they are the regular 190mm brake ones not the xx2657?
that sounds the most likely explanation
UkNuck is offline   Reply With Quote
Old 07-18-2011, 10:44 PM   #6
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
You either need the special DBA rotors made just for this swap.
http://www.fastwrx.com/dbastiadro.html
Or special rear e-brake pads found here.
http://www.godspeedbrakes.co.uk/~god...?id_product=92
MD04WRX is offline   Reply With Quote
2004 STI swap in a 04 wrx ABS light on and brakes do not work PLEASE HELP ChrisNJ69 Subaru Conversions 8 04-07-2011 12:23 AM
WRX Brembo vented rear brake upgrade rotors soobaviator Suspension/Brakes/Handling 2 10-12-2009 09:23 PM
04 WRX Complete Drivetrain Engine Trans Brakes... The works $3500 PentUpWrx VIC Private Classifieds 6 01-15-2008 11:28 PM
IPT Race wrx 5spd swap. Trans, axles, brakes, rear + Junior2JZ Drivetrain 15 11-21-2007 06:35 PM
04 Wrx Brembo Brake Question WRX82 Brakes, Steering & Suspension 7 09-29-2006 11:13 PM
