Old 07-17-2011, 04:55 PM   #1
wrxwagon1992
Member#: 208475
2002 wrx wagon
aspen white
Default How to change throttle cable?
Hello, for removing and replacing the throttle cable how do you disconnect the cable from where it goes into the firewall?
wrxwagon1992 is offline   Reply With Quote
Old 07-17-2011, 05:22 PM   #2
wrxwagon1992
Member#: 208475
2002 wrx wagon
aspen white
never mind
Old 08-31-2012, 01:41 AM   #3
Luizwrx
Member#: 188577
2003 EJ207
How did you do it? where did you get your cable?
Luizwrx is offline   Reply With Quote
Old 04-07-2013, 11:02 AM   #4
25rsti
Member#: 166324
Didn't want to make a new thread.
I replaced my throttle cable and now the throttle body is a little under a 1/4 way open. I can't adjust it. Cable is pulled as far as possible. My old one was frayed and I measured it next to the new one, it's identical length...
Old 04-07-2013, 12:36 PM   #5
25rsti
Member#: 166324
Anyone ever dealt with this?
Old 04-08-2013, 12:48 AM   #6
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Double check and make sure the cable is routed 100% correct, take your time and double check.
There should be no way that your cable is that far adjusted and still 1/4 out.
recce02 is offline   Reply With Quote
Old 04-08-2013, 08:44 PM   #7
25rsti
Member#: 166324
I've looked 20 times, I've taken it out and put it back in 10 times. It doesn't make any sense to me.
There really is only one way to install it too.
Old 04-08-2013, 09:04 PM   #8
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
is the grommet pulled through the firewall enough? or check if there is tension from the cruise control cable.
fastnoypi is offline   Reply With Quote
Old 04-08-2013, 09:53 PM   #9
25rsti
Member#: 166324
Yeah, It was pulled all the way through.
I don't have cruise on my jdm engine.
how to remove throttle accelerator cables from intake manifold? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-03-2007 07:00 AM
How do you open forward opening hoods and how to change bulbs on headlights of cars t rice h8r Off-Topic 18 05-18-2006 10:36 PM
Confused on how to disconnect throttle cable.. jefersun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-28-2005 04:12 PM
How to change filter w/o changing oil? TimStevens Service & Maintenance 11 04-29-2003 07:49 AM
changed dash color/how to change cruise control light? wrx_n_ah Electrical & Lighting 16 04-24-2003 02:01 AM
