Old 07-18-2011, 12:41 PM   #1
clkoontziii
Member#: 128389
2006 impreza wrx
steel gray
Default Just sharing my first log 2010 Stg OTS 1
https://spreadsheets.google.com/spre...RCSXc&hl=en_US
Let me know how it looks !!!
Thanks for any input
MODS: AP OTS Stg 1
STOCK CAR
clkoontziii is offline   Reply With Quote
Old 07-18-2011, 05:42 PM   #2
Sheltonmega
Member#: 265204
2009 WRXCobbProtuned
CattedAEMCAIPerrinTMIC93
I have knocks in cylinder 2 and 4 too. none in 1 and 3.
Sheltonmega is offline   Reply With Quote
Old 07-18-2011, 05:57 PM   #3
clkoontziii
Member#: 128389
2006 impreza wrx
steel gray
From the reading I have done the knock sums are meaningless.
I think we should be looking @ the knock learning.
I was hoping someone with real knowledge could educate me (us) a little.
-CK
Old 07-18-2011, 06:27 PM   #4
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Yes, the knock sum value itself it meaningless because it increments even at idle and very low load when the knock detection set-up is extremely poor at distinguishing knock from other noise (which is why the ECU will not respond to those events). You need to look at when it increments. Or, it may be easier to just look at the DAM, feedback knock correction, and fine knock learning.
Your log looks good. No feedback correction or fine knock learning and the DAM is at 1.0.
Keep in mind that the occasional feedback or fine learning correction is normal, especially if it is a single event (generally -1.4 deg., depending on ECU). If you have repeatable feedback correction during a wide open throttle (WOT) run (except for the first few lines after you mash the throttle) or you have a more severe correction for fine knock learning at higher load (2+ events, for example, -2.8 corr. or less) that is more of a concern that random corrections.
Bill
Old 07-18-2011, 09:30 PM   #5
clkoontziii
Member#: 128389
2006 impreza wrx
steel gray
Thanks Bill I was hoping you would weigh in just to put my mind at rest. The OTS tune feels great!! Glad I went with COBB
Thanks for a great product and service.
-CK
Old 07-24-2011, 04:41 PM   #6
snchz197
Member#: 269121
'11 WRX
I'm seeing a few fine knock learn events at stage 1 on a 2011. DAM is at 1 consistently and feedback knock is always 0. They seem to appear sort of consistently between 4500 and 5500rpm at WOT and are 5-10 rows of "-0.7" and "-0.35" mixed together.
From what I've read this is ok and nothing to worry about unless they're getting up over -2 but it would be nice to have that confirmed. Earlier this year in march when ambient temps were much lower there was no fine learn at all.
Link is here
https://spreadsheets.google.com/spre...9GYUE&hl=en_US
snchz197 is offline   Reply With Quote
Just did my first Logs Chasey Newbies & FAQs 7 11-28-2010 06:29 PM
My first logs - input please! z28dreams Open Source Reflashes 0 07-12-2008 03:07 PM
My first log! Autopilot747 UTEC 7 07-29-2007 11:47 PM
Just got my 06 STi.. Just had my first accident ever. *pics* Drive_STIck General Community 50 06-20-2007 06:35 PM
My first logs second attempt. BBBsti LTD Engine Management & Tuning 6 03-20-2007 06:44 PM
Message Board Statistics All times are GMT -4. The time now is 01:41 PM.
