Old 07-27-2002, 06:49 PM   #1
NickWRX
Member#: 15948
2001 2.5RS
317awhp-277ft./lb
Default $944= 214.9 AWP/224.2FT/lb(cheapest and best route for power!)
Now, I hope this doesnt start a debate among some of yous, but I have the sheets! So, heres my suggestions for quick and easy power, and most of all... CHEAP power!
Greddy Profec B = $275
TurboXS turbo back(stealth) = $669
both bought brand new, and proff. installed. I spent less than $1000, and put down 215 AWP, and a sweet 224.2 ft.lb
The dyno is www.BMTranny.com in NJ, the first ever in NJ. Close to 7-10 wrx's showed up to put down the power. Surrounded by Unichips, and 3" $1000+ exhaust, I figured I would put down the least of all. I was dead wrong. 2 others with TXS stage II put down close to the exact same numbers as me!!! 1 with same xhaust, other with BPM, both with unichips! We were all shocked. Not knocking those guys in the least bit, there cars were very nice, but the UNICHIP? That day cleared the way for the AFC. NotoriousWRX ( damn did that sound good, and smell good ) started with 225, with about 15 min of tuning dished out almost 20 more ponies!. No unichip, just great power.
I ran pig rich at a ratio of 10:0!!!!!!! The guys at BM told me to get an AFC, and ill easily pick up 15hp if not more in the fuel filled midrange.
So, there it is, questions anyone?
Nick:
NickWRX is offline   Reply With Quote
Old 07-27-2002, 07:07 PM   #2
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Congrats on the new numbers! Those are very impressive numbers for the mods you have. I am going the same route as you but with a EBC and S-AFC together.
Not to jump off subject, but how would you rate your experience with them and their ability on tuning? I plan on having them tune my WRX as well. Thanks.
Need4Boost is offline   Reply With Quote
Old 07-27-2002, 07:09 PM   #3
qtrmile
Member#: 14780
2002 wrx
white
Thumbs up 214.9 awp
how much boost? no air filter? no uppipe?
thanks al
qtrmile is offline   Reply With Quote
Old 07-27-2002, 10:38 PM   #4
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Default Re: $944= 214.9 AWP/224.2FT/lb(cheapest and best route for power!)
Nick:
Does not suprise me at all. This is why I hate mail order maps. Had someone been there to tune those unichips those guys would have picked up power and made more then you. But, They where tuned on another car in another location with different gas.. Out of the 4 WRX's here running TXS unichips ALL of them ran faster at the strip when I suggested they take the chip out. All but 2 sold the chip off.
Get the AFC and go back there for a tune. Get that AF to run 11.5 to 1 and you will indeed pick up power. Do not do this on a reset ECU. Turn the AFC off and drive 40 miles. Then turn it on and have them tune it. If you tune on a reset ECU you will be tuning on the default RICH and low advance map. LAter.. You lean out and ping and your tune is worthless.
CT
AZScoobie is offline   Reply With Quote
Old 07-28-2002, 11:58 AM   #5
Baluchitherium4
Member#: 6480
00' WS6
Red
How much boost were you running? Does the Profec B hold full boost all the way to redline?
Thanks,
Dale
Baluchitherium4 is offline   Reply With Quote
Old 07-28-2002, 12:42 PM   #6
MadWagon
Member#: 14076
2003 WRX Sedan
Thanks,
Dale
Depends on atmospheric conditions. It will not hold 15psi at redline in 4th or 5th with a stock exhaust.
MadWagon is offline   Reply With Quote
Old 07-28-2002, 02:01 PM   #7
NickWRX
Member#: 15948
2001 2.5RS
317awhp-277ft./lb
Yeah, my bad guys...
Low Boost setting: .90 bar = about 12+- lbs
High Boost setting: 1.2 bar = about 16.5-17 lbs
Mind you, these were read off of my Blitz Dual TT, which reads a little high in my opinion.
And I forgot to mention, in low boost I put down 197 AWP. So from low to high, I made more than 15 HP!
But yes, it holds boost great in warm weather, cold its a lil spikey. But BM said boost fell off a lil bit in High Boost near redline. But still, it holds great.
QTmile: silencer removed, no air filter, no up-pipe
AZScoobie: thanks for the advice man, I really appreciate that.
Need4Boost: Yeah, BMTranny are great guys. All i needed to do is look around at there place(DSM heaven) and I found all I needed to feel good about them. They took Notorious's car that put down 225 first pull, and dialed in different numbers on his AFC by looking at his midrange curve on the sheet. Within 15 min he had almost 20 more HP! It was cool to see them go to work. And now that we have been there, and they have used our cars, there familiar with them. CALL THEM NOW!
Thanks for the replys and the compliments
Nick
Old 07-28-2002, 02:47 PM   #8
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Thumbs up
Its nice to see others finally realizing the true potential of the WRX without WASTING tons of $$.
I'm qurious what my car would dyno @.
~v6
Like I have said all along... :monkey: unichip
V6TurboTA is offline   Reply With Quote
Old 07-28-2002, 10:21 PM   #9
Electronsmurf
Member#: 14523
Blue -239.9WHP 247.7WTQ-
do you guys think a WRX with MBC at 16-16.5 psi with catless uppipe and 3 inch catless dp will put down similar #s?
Electronsmurf is offline   Reply With Quote
Old 07-29-2002, 04:55 PM   #10
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Isn't the TurboXS Stage II tuned for 15psi?
-Jon
www.nothingserious.net
Old 07-29-2002, 05:13 PM   #11
NickWRX
Member#: 15948
2001 2.5RS
317awhp-277ft./lb
Jon: Im not sure what the XS stage II is set at, i thought it was 16, but the other guys turned up there XS manual boost controllers to close to 16.5 or right around there. They went from around 205 AWP, to 215 when turning up the boost.
ElectronSmurf: I believe you could put down close to 200 AWP. Who knows, I didnt believe I could put down that much. So theres hope
Nick
Old 07-30-2002, 11:10 AM   #12
SleeperWRX
Member#: 8179
If there was a good S-AFC tuner locally then I'll pick one up, but there's no 4 wheel dynos near Rochester as far as I know.
-Mike
SleeperWRX is offline   Reply With Quote
Old 07-30-2002, 11:22 AM   #13
VetteVert
Member#: 5961
2005 STi
CGM
Think about what you just said for a moment.
I believe what he was saying is that he doesn't have an aftermarket air filter or up pipe.
He could run with no filter in the airbox, but he'd have an awfully hard time putting down 215hp without an uppipe
VV
Originally posted by SleeperWRX
what's the point of dynoing a car in trim that you ca't run on the street?
Yea Unichips blow ass...I made X more HP than you and I have no air filter or uppipe I bet they drove home faster and didn't spend hours putting their uppipe back on.
-Mike
VetteVert is offline   Reply With Quote
Old 07-30-2002, 11:28 AM   #14
SleeperWRX
Member#: 8179
lol that's what happens when I try and do too many things at once
-Mike
Old 07-30-2002, 11:40 AM   #15
NotoriousWRX
Member#: 9026
That was too funny!
VV
NotoriousWRX is offline   Reply With Quote
Old 07-30-2002, 11:50 AM   #16
jimb
Member#: 9923
2005 Legacy GT
RIP MBP WRX
Just a quick observation. It's all about the boost, without a decent BC, you won't make good dyno numbers. You've got to be able to hold the boost at 5.0-6.0k. I'm not saying hold full boost, just higher than stock. That is pretty much where everyone is seeing the big numbers.
jb
jimb is offline   Reply With Quote
Old 08-01-2002, 03:07 AM   #17
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
You could save almost $200 off that setup by using a $20 MBC instead of a $200+ Greddy Profec B. So really you can get that same power for about $750ish.
Jay
Diversion is offline   Reply With Quote
