Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Services
Closed Thread
Old 07-19-2011, 03:52 PM   #1
maperformance
Vendor Sales Rating: (80)
Member#: 141043
2015 WRX
Default Super sale on services! No one Ports, Polishes, or Coats as well as we do!!
The MAP Race Program||||Why Choose MAP?||||Our Services||||Inventory Clearance||||What Our Customers Say
Porting & Polishing Services
Our porting guru Bob Schreiber has worked on everything from NA applications to boosted nitrous applications, and from single cylinder recreational vehicles all the way to high performance super cars like the Dodge Viper SRT-10, and everything in between. Pulling from his education in fluid dynamics, airflow theory, physics, thermal dynamics, and his real world testing, he is able to bring us nothing less than the best porting and polishing solutions. Over the years he has developed custom tooling (unlike the competition) that allows him to port 'line of sight' and be able to get everything in a manifold even if it is a Viper intake plenum that is ~26" long!
If you are after the most from your setup, and need nothing less than the best porting solutions, look no further than your performance specialists at Modern Automotive Performance.
Products we port include:
  • Intake Manifolds
  • Exhaust Manifolds
  • Turbos
  • Heads
Advanced Ceramic Coating
Approximately one third of all energy put into the combustion process is lost due to heat transfer. This means in stock components, you will have less exhaust velocity and less potential power than engine components that are ceramic coated.
There are a few main categories of ceramic coatings: thermal dispersants (coatings that help pull heat out of a substrate), thermal barrier coatings (reduce heat transfer), and dry film lubricants. Each have a specific role in the engine.
Thermal Dispersants
Thermal dispersants are usually applied to intake manifolds but can be applied to any surface that would benefit such as a radiator or intercooler. Essentially any part designed to cool something via heat transfer. This coating is only available in a black/dark charcoal finish.
Thermal Barriers
Thermal barriers come in an array of solutions based on where they are to be used and the environment they are in. One example is a thermal barrier that can be used on a firewall to help cool vital non-metal components such as tubing or wiring. This same coating can be placed on on the flange of an intake manifold to minimize the heat transfer from the head. This will result in a cooler air charge after the engine gets hot, when compared to an uncoated manifold. Cooler air equals.....more power.
Other thermal barriers have specific formulations to withstand the internal combustion process itself. Coatings designed for the tops of pistons, valves, combustion chambers, and exhaust ports will fall into internal combustion coatings where as external thermal barriers will have a more durable finish and be designed with aesthetics in mind as well. This will also reduce engine bay temps by as much as 150-200 degrees. These coatings are available in red, orange, black, blue, and even a chrome look.
Yet another application for a thermal barrier is an oil shedding thermal barrier. This is a great addition to any intake manifold in a 'V' type engine. Normally, the engine will splash hot oil up onto the bottom of the intake manifold. By applying an oil shedding thermal barrier to this surface, not only will it shed oil quicker, reducing the time the oil has to transfer heat, but it will also act as a thermal barrier minimizing any heat to be transferred to the intake. Again, keeping your air charge cooler, longer, for more power in the long haul.
Dry Film Lubricants
The last form of advanced coatings would be dry film lubricants. This is the best solution for any moving part subject to sliding or rolling friction such as valve stems, cam journals, side skirts of pistons, and main bearings. This coating will minimize galling and scuffing thus increasing part life. Clearances are not effected when this coating is utilized.
All combined, these coatings will yield lower part temps for longer part life and an increase in exhaust velocity by minimizing heat lost in the process, resulting in a boost in power (~1-6% depending on application), not to mention they look good. All from just a coating!
Combine these coatings with cryo treatment and you will have performance parts that last!
PM for your personalized quote on these services!!!
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
I want to earn your business, PM me and tell us how we can become your one stop shop for performance parts today!
ACL / AEM / ACT / Cosworth / Grimmspeed / Invidia / Ksport / Manley / Mishimoto / PTE / Tomei / Turbosmart / Wiseco
maperformance is offline
Old 07-19-2011, 05:57 PM   #2
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 07-20-2011, 04:57 PM   #3
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 07-21-2011, 07:03 PM   #4
maperformance
Member#: 141043
2015 WRX
Thursday is YOUR day to save!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 07-22-2011, 04:45 PM   #5
maperformance
Member#: 141043
2015 WRX
Save on the weekend @ www.maperformance.com
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 07-25-2011, 06:23 PM   #6
maperformance
Member#: 141043
2015 WRX
Monday Bump!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 07-26-2011, 05:18 PM   #7
maperformance
Member#: 141043
2015 WRX
PM Me For Great Deals!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 07-27-2011, 06:03 PM   #8
maperformance
Member#: 141043
2015 WRX
PM's Sent and Replied!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 07-28-2011, 03:31 PM   #9
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-01-2011, 05:00 PM   #10
maperformance
Member#: 141043
2015 WRX
Not Our Friend Yet? Go Ahead, Join The Fun!
http://www.facebook.com/modernautomotiveperformance
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-02-2011, 05:20 PM   #11
maperformance
Member#: 141043
2015 WRX
Tuesday is YOUR day to save!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-03-2011, 05:12 PM   #12
maperformance
Member#: 141043
2015 WRX
Want The Latest News On New Products? Bookmark This Page!
http://www.maperformance.com/blog/
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-04-2011, 05:14 PM   #13
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-08-2011, 07:06 PM   #14
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-09-2011, 06:21 PM   #15
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-10-2011, 06:43 PM   #16
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-11-2011, 06:55 PM   #17
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-12-2011, 06:31 PM   #18
maperformance
Member#: 141043
2015 WRX
save Big This Weekend
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-15-2011, 06:19 PM   #19
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-16-2011, 04:39 PM   #20
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-17-2011, 06:16 PM   #21
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-18-2011, 04:23 PM   #22
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-23-2011, 06:56 PM   #23
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-24-2011, 06:59 PM   #24
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-25-2011, 06:33 PM   #25
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Closed Thread
Crucial Racing Turbocharger porting, polishing, and coating services! <<< REALLY nice Crucial Racing Services 55 02-18-2008 05:47 PM
PE1820, ported, polished, ceramic coated paulw Private 'For Sale' Classifieds 0 12-09-2004 04:38 PM
More stuff on our site new for sale section as well as my new exhaust... MPREZYA Southern California Impreza Club Forum -- SCIC 2 09-06-2000 03:34 PM
