Old 07-21-2011, 03:15 PM   #1
bushman95
Member#: 248738
2004 wrx
red
Default How to check timing on 2002 wrx
I have a 2002 wrx with misfires on all four cylinders and I think to I have narrowed down the problem to timing. I am wondering how to check the timing to see if the belt skipped?
If the belt did skip would it be smart to get and new belt and tensioner and any pulleys that might be bad.
bushman95 is offline   Reply With Quote
Old 07-21-2011, 08:12 PM   #2
shibby2821
Member#: 229778
04 WRX
WR blue
how many miles? u might as well do all those things since your goin in there and especially the tensioner would def need to be replaced. i'd never put the old one back in
shibby2821 is offline   Reply With Quote
Old 07-21-2011, 08:25 PM   #3
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
take the front cover off and look at the belt....HUGE thread in the maint forum on timing belt changes
and change EVERYTHING under that cover if you change anything
Old 07-21-2011, 08:28 PM   #4
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
check the timing by pulling the covers off and matching all the marks on the belt are in line with the notches on the rear timing covers
Old 07-21-2011, 09:36 PM   #5
bushman95
Member#: 248738
2004 wrx
red
It has 160k on it, I'm not sure what was replaced with the last timing belt change though. I may just want to do a belt change and any pulleys that seem to be bad.
Do you have to take off the crank pulley to take off the timing belt cover? Or does or just slide off around it?
Old 07-21-2011, 10:57 PM   #6
Uncle Scotty
OK buy Nates beans
dont half ass this....you will regret it....and ya gotta pull the pulley
and you ARE IN THE WRONG FORUM FOR THIS
YOU WANT THE MAINTENANCE FORUM!!!!!
Old 07-22-2011, 01:09 AM   #7
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
http://forums.nasioc.com/forums/show...ht=timing+belt
Watch, learn, do it right, and yes, replace all pulleys and tensioner. If you buy a kit online, they make it REAL easy and give you everything you need. Water pump is at your discretion but recommended.
WRXSD is offline   Reply With Quote
Old 07-22-2011, 02:49 AM   #8
bushman95
Member#: 248738
2004 wrx
red
Ok well I don't want to replace belt right now because it should have another 40k on it. How do you pull the crank pulley? Just un bolt it and pull it off or do I need a pulley puller?
Old 07-22-2011, 03:43 AM   #9
Uncle Scotty
OK buy Nates beans
unbolt it and whack it with a rubber mallet...it should slide right off
DO NOT LOSE THE WOODRUFF KEY!!!!!!!!!!!
Old 07-22-2011, 03:59 AM   #10
bushman95
Member#: 248738
2004 wrx
red
Would I just turn the motor over until the timing marks line up to check if it is on and if they never line up it is off, correct? If it is off I'll just replace the whole kit.
Old 07-22-2011, 04:29 AM   #11
02redwagone
Member#: 87067
02 Old but tasty
SRP
Dammit man! Watch the video in the maint section. It holds answers to all you've asked in step by step format.
In reference to the last question. Yes. you may have to turn it several times to get the marks to line up.
02redwagone is offline   Reply With Quote
How to check timing? lagodcm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-28-2008 04:23 PM
how to check timing? omeskcus Normally Aspirated Powertrain 1 11-17-2008 06:57 AM
How to check timing on 94 L ai42 Newbies & FAQs 0 10-01-2005 08:41 PM
How to check timing with the light gun on a coil on pack wrx? bigbird Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-01-2004 07:00 PM
How to Remove Guard on 2002 WRX klt599 General Community 2 05-15-2003 01:17 PM
