Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Alaskan Impreza Club
Old 08-18-2011, 08:34 PM   #76
Tripster
Member#: 226944
2009 Subaru SSM
Element Auto Sponsored
Originally Posted by bjcarter2
^^^A Meth whore's bumper sticker I suspect.
That could make some since I suppose, thanks for clearing up the Fail.
Tripster is offline   Reply With Quote
Old 08-22-2011, 05:58 AM   #77
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
added a scoop delete, home made with plastic until i can come up with something better.
Alaskan EJ20 is offline   Reply With Quote
Old 08-22-2011, 11:14 AM   #78
JesseL
Member#: 169556
07' OPB STi BW S256
01' 2.5rs GM6 w/leather!
Looks good! Wingless/scoopless ftw!
JesseL is offline   Reply With Quote
Old 08-22-2011, 12:40 PM   #79
Trox
Member#: 36785
05 STi (broke)
03 Focus
I'll check it out Friday.
Trox is offline   Reply With Quote
Old 08-22-2011, 03:05 PM   #80
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
you got a new tune i assume
Old 08-22-2011, 09:19 PM   #81
Trox
Member#: 36785
05 STi (broke)
03 Focus
Not yet waiting on higher flowing fuel pump
Old 08-25-2011, 06:10 PM   #82
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
well i got a new tune.
23psi, meth 50/50. I think the car could fly if it had wings. Its about 420-430 hp based on the logs. The engine is seeing loads as high as 4.1 and absolutely no knock. AFR's are 11.2-11.3 which is still on the rich side. Im sure at around 11.8-12.0 id gain a good 20 hp. The roads got real busy so we had to stop here but i know we can go further on boost as well. 30R's are most efficient around 25-26psi. Not sure how much timing is added right now but with no knock what so ever and meth im sure it can go up more too.
But i say this thing is damn fun to drive right now.
Old 08-25-2011, 07:26 PM   #83
akeric
Member#: 122954
2006 Evo IX
My car is black not
niiiiicccceeeee
akeric is offline   Reply With Quote
Old 08-25-2011, 08:01 PM   #84
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Still shaken from that tune session and my neck hurts... Thanks for bringing the car out and I hope the weather holds for Friday!
P3Auto is offline   Reply With Quote
Old 08-25-2011, 08:14 PM   #85
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
anytime Seth and thank you p3 for the tune.
Old 08-26-2011, 03:34 AM   #86
akeric
Member#: 122954
2006 Evo IX
My car is black not
sounds like you've got a beast on your hands. Maybe I'll make some time to go out tomorrow and watch you run but we'll see.
Old 08-26-2011, 08:11 PM   #87
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
ill be leaving around 6:30-7 to go out tonight.
Old 08-27-2011, 03:45 AM   #88
akeric
Member#: 122954
2006 Evo IX
My car is black not
I didn't make it, what did you run?
Old 08-27-2011, 03:30 PM   #89
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
didnt pass tech, small oil leak discovered . just happen to drip on my header when he was looking in engine bay. "i smell burning oil" he got out his magnifying glass and found it. had i been there an hour earlier he wouldnt have looked so closely.
Old 08-27-2011, 11:37 PM   #90
akeric
Member#: 122954
2006 Evo IX
My car is black not
sucks
Old 11-29-2011, 09:53 PM   #91
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
figured id post these vids here and give an update:
put some RA flaps on with 04sti bbs and Nokian Hakka's for November 20th's Rallycross event. I placed First in AWD modified and overall
oil leak in still present and have not had time to tear into it yet but ive been keeping a close watch of it. Car sits at home for the most part this winter except for this one event.
vids:
Old 11-29-2011, 10:36 PM   #92
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
All I heard was turbo this and turbo that...
Marlons101 is offline   Reply With Quote
Old 11-29-2011, 11:53 PM   #93
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
sssssssssssssssSSSSSSSSSSSSSSSSSS................ ppsstt!!!!
Old 11-30-2011, 03:46 AM   #94
insane_one
Member#: 301431
2005 Evolution VIII
NICE! congrats with the win @ the event
insane_one is offline   Reply With Quote
Old 02-10-2012, 09:28 PM   #95
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
fixed pesky oil leak, put racing belt on and nice new tomei crank timing guide, beefy unit compared to stock.
Old 02-10-2012, 11:05 PM   #96
insane_one
Member#: 301431
2005 Evolution VIII
sexy!!
Old 02-10-2012, 11:48 PM   #97
seascooby
Member#: 133535
06 limited - mine
ww evo 8 - hers
i like the tomei guide def a huge difference
cosworth guide.... the tomei is way sexier
seascooby is offline   Reply With Quote
Old 02-12-2012, 05:40 PM   #98
White_Rice
Member#: 160049
Gabe....you should fab up/buy a vent panel in place of a the scoop plug.
White_Rice is offline   Reply With Quote
Old 02-24-2012, 07:12 PM   #99
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
round three of fixxing the leaking oil pump, Napa has an idiot working for them that recommended this crap red silicone gasket maker he said it had the best temp rating, which was correct but it doesnt hold up to oil. I used ultra grey this time and hope it will do the trick. also down graded pumps to a 10mm for an experiment for the built motor gurus.
Hydra 2.6 with wideband is in the mail
Old 02-24-2012, 07:21 PM   #100
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
We have been down this road a few times...lol
1. NEVER use any aftermarket crank oil seal.
2. Its VERY easy to screw up the crank oil seal and have the spring come off of it or have it get folded or kinked. Try installing the oil seal after the oil pump is mounted on the block (if this is a problem)
3. We use the anaerobic gasket maker and have never had a single issue.
Project B.O.B. (Baby on Board) my 04 wrx build XdanoX Member's Car Gallery 143 05-17-2012 12:09 AM
My 07 wrx build cruzanspeed Member's Car Gallery 37 08-17-2011 01:32 AM
PSM_02_WRX's 2002 WRX Build PSM_02_WRX Member's Car Gallery 45 08-08-2010 03:52 AM
My 2009 WRX build up thread... cianflok265 Member's Car Gallery 46 04-15-2009 02:53 AM
WTT: My 2002 WRX Utec for your 2002 Accessport w/ StreetTuner Software dubluv17 Private 'For Sale' Classifieds 3 07-03-2006 05:19 PM
