Alaskan Impreza Club
Old 02-24-2012, 06:35 PM   #101
White_Rice
Member#: 160049
That GM Red Goop they use to seal transmissions seems to work pretty good for oil related sealing.
White_Rice is offline   Reply With Quote
Old 02-28-2012, 04:56 AM   #102
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
Finally had some time today to see if the oil leak was still around. Looks to be fixed. Cruised around for awhile to study the difference in 10mm pump vs the 12. My engine seemed to react much better to 10mm pump. Idle pressure was 5-7 psi less and it only took a few hundred more rpms to build 75-80 psi. Also the 12mm pump is known to drop off after around 6000 rpms around 10psi, this is because of the relief in the pump and the way these blocks are designed. They are not designed to take so much volume of oil so when the relief opens the oil tends to go that way instead of in the engine. I don't have any of these problems with 10mm pump. Pressure is 80psi all the way through 7500 rpms. And most importantly its not leaking any more.
Alaskan EJ20 is offline   Reply With Quote
Old 02-28-2012, 03:51 PM   #103
akeric
Member#: 122954
2006 Evo IX
My car is black not
sounds good look forward to checking it out again this summer.
akeric is offline   Reply With Quote
Old 02-29-2012, 06:09 PM   #104
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
Got this in the mail today, version 2.6
And to my pleasant surprise a few extras came with........
02 wrx main harness that can run dual avcs and it came with dual avcs engine harness.
Also had a wideband
Old 02-29-2012, 07:04 PM   #105
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Wow nice one pal!
Marlons101 is offline   Reply With Quote
Old 02-29-2012, 09:54 PM   #106
seascooby
Member#: 133535
06 limited - mine
ww evo 8 - hers
confuse i thought you went with ams....?
seascooby is offline   Reply With Quote
Old 03-01-2012, 12:37 AM   #107
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
i was going to but after much research the hydra is a little more 'support' friendly.
Old 03-01-2012, 03:41 AM   #108
akeric
Member#: 122954
2006 Evo IX
My car is black not
is that all plug and play or will you have to chop up your car side harness at all? What limitations were you running into with the stock ecu and tuning?
Old 03-01-2012, 04:43 AM   #109
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
no cutting, just need to find out if i have to run the avcs because of cam sensors as im non avcs with a single cam sensor. right now the stock ecu is hacked where the values limits are doubled but the resolution is cut in half.
Old 03-01-2012, 04:03 PM   #110
akeric
Member#: 122954
2006 Evo IX
My car is black not
hopefully you'll see some good gains going to the more powerful ecu, is seth still tuning it?
Old 03-01-2012, 05:55 PM   #111
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
Yes, this will help us get to a more aggressive tune safely.
Old 03-01-2012, 06:40 PM   #112
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Plenty more to come. We will use the new baseline software and hardware to show before and after results with whp/tq/quarter time/0-60 time/ etc.
P3Auto is offline   Reply With Quote
Old 03-01-2012, 08:46 PM   #113
akeric
Member#: 122954
2006 Evo IX
My car is black not
nice, excited to see it.
Old 05-22-2012, 04:31 PM   #114
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
Man i had a busy week........ I picked up two certifications in tuning.
1. EFI 101- Basic fuel injection and spark advance. Optimizing power or economy with fuel and spark on engine management systems, Speed density and mass air flow tables
2. EFI Advanced- High Horsepower fuel injection and spark advance. Finding best torque with spark advance. High compression, power adders, forced induction tuning. Standalone EMS tuning. Dyno tuning.
This was what i got my hours and practice on.
1990 Mitsubishi Galant VR4 (684/2000 made in 1990) Fully build up and down 2.3L and tranny with a GT42R, DMP headers and magnus manifold. on pump 92 it made 439HP at 19lbs. The owner had plumbing for nitrous wetshots direct individual port and has a goal of 900HP at around 40psi when he's done.
Old 05-22-2012, 04:44 PM   #115
akeric
Member#: 122954
2006 Evo IX
My car is black not
very cool, maybe I can pick your brain
Old 05-22-2012, 05:15 PM   #116
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
im sure we can pick each others
Old 05-22-2012, 06:12 PM   #117
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
Nice job on the certifications Gabe. That Galant VR4 sounds like it would be a beast. Cool shot of the exhaust manifold on there too.
Dominator is offline   Reply With Quote
Old 05-22-2012, 06:27 PM   #118
Trox
Member#: 36785
05 STi (broke)
03 Focus
Congrats Gabe, guessing you won't be out tomorrow night
Trox is offline   Reply With Quote
Old 05-22-2012, 06:57 PM   #119
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
when do i get to see this garage queen come out
Old 05-22-2012, 08:18 PM   #120
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
whats going on tomorrow night? sorry i just got back so im out of the loop, lol
Old 05-22-2012, 09:22 PM   #121
Trox
Member#: 36785
05 STi (broke)
03 Focus
Test & Tune
Old 05-22-2012, 09:27 PM   #122
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
i just may be up for that tomorrow!!
Old 05-23-2012, 01:42 PM   #123
AK SloPok
Member#: 56464
12 Ram
How were the classes? I have been thinking about something like that for a while now. Not that I am wanting to open shop but just to expand my knowledge. Sadly I am not yet broke in for the test/tune.
AK SloPok is offline   Reply With Quote
Old 05-23-2012, 01:55 PM   #124
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
Really applaud your willingness to go follow your passion Gabe. I think it is a great thing you are doing. Really happy to hear it. Another budding guru adding their knowledge base to this great AKIC community.
Nomadgene is offline   Reply With Quote
Old 05-24-2012, 03:38 AM   #125
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
The classes were great it moves fast, but the hands on you get during the last couple days helps it all come together. I learned a lot about aspects that I thought I knew all about. And how important it is to have a solid electrical system on fuel injected cars. I could go on and on but I'll save it for later. Now I just need a few equipment pieces to get the ball rolling, but I can't even explain how excited I am to build my new maps for the hydra ems.
Project B.O.B. (Baby on Board) my 04 wrx build XdanoX Member's Car Gallery 143 05-16-2012 11:09 PM
My 07 wrx build cruzanspeed Member's Car Gallery 37 08-17-2011 12:32 AM
PSM_02_WRX's 2002 WRX Build PSM_02_WRX Member's Car Gallery 45 08-08-2010 02:52 AM
My 2009 WRX build up thread... cianflok265 Member's Car Gallery 46 04-15-2009 01:53 AM
WTT: My 2002 WRX Utec for your 2002 Accessport w/ StreetTuner Software dubluv17 Private 'For Sale' Classifieds 3 07-03-2006 04:19 PM
