Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Perrin Performance
Old 07-20-2011, 04:14 PM   #1
PERRIN
NASIOC Manufacturer
Vendor Sales Rating: (10)
Member#: 6776
Default Two New Heat Shield Products From PERRIN
New From PERRIN Performance - Two Great New Products
Turbo Heat Shield
Don't leave your turbo uncovered! Protect your intercooler from radiant heat from your turbo!
Design
The PERRIN turbo heat shield is CNC formed from 304 stainless steel. The backside of the shield is cut to fit all aftermarket downpipes. It is also adjustable front to back allowing the tuner to cover as much of the turbo as possible from application to application. High quality stainless steal hardware included.
No Rattles
The PERRIN Heat shield uses only high quality spot welds that pass the "Nugget Test". During a production run We actually rip apart a test joint. The sheet metal should fail before the weld, leaving a small "nugget" of metal behind. verifying the spot weld penetrated all layers of metal.
Why Do I Need One
The PERRIN turbo heat shield is perfect for those not wanting to cut OEM turbo heat shield when installing our PERRIN down pipe. The PERRIN heat shield covers more of the turbo than competitors shield.
Turbo Heat Blanket
Keep the heat in your turbo, not radiating to the intercooler and intake.
Design
The PERRIN Turbo blanket fits snugly around turbine housing of your turbo to keep nearly all radiant heat away from your intercooler, intake and other engine components. The Turbo blanket features 3 Layers of construction including an outer cover made from Silicone Impregnated Fiberglass, an inner layer made of Calcium Magnesium Silicate Insulation and stainless steel mesh used to contain the inner layer.
Installation
Stainless steel rivets are mounted to the blanket and stainless steel wire is supplied to secure the blanket to your turbo.
Performance
The PERRIN Turbo Blanket will reduce turbo spool and under hood temperatures. As your exhaust temps cool down from thermal losses from headers and turbine housings, they loose energy and velocity. The turbo blanket keeps hot exhaust gases hot, which in turn keeps the velocity of exhaust gases high, improving response while decreasing underhood temps.
Get Both!
These two items actually work together if you choose to. Install the Turbo Heat Blanket then install the Turbo Heat Shield over it for the ultimate in good looks and heat control.
Turbo Heat Shield
MSRP $79.99 - Most coupons will work on this item to save you some money.
Turbo Heat Blanket
MSRP $109.99 - Most coupons will work on this item to save you some money.
PERRIN is offline   Reply With Quote
New Turbo inlet Hose From PERRIN Performance PERRIN Perrin Performance 33 07-14-2011 01:18 AM
SPT Intake/heat shield, UTEC and Perrin Recirc rpmrevs440 Engine/Power/Exhaust 4 03-28-2010 11:12 AM
Stock STi downpipe and NEW heat shield GeorgeRex Engine/Power/Exhaust 6 09-02-2007 04:25 PM
Stock STi donwpipe and brand new heat shield GeorgeRex Engine/Power/Exhaust 5 06-22-2007 04:48 PM
