Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Closed Thread
Old 07-21-2011, 10:47 PM   #1
g00dhum0r
Member Sales Rating: (6)
Member#: 159025
2004 STI
As the title states, I need an a/c hose for the HP side. I think goes from the compressor to the condenser and has the H service port on it. Sits right on the top. My hose has a hole in it and needs to be replaced because the FMIC pipe rubbing up against it. I'm not sure if other year wrx/sti hose fits it but if you have one please let me know how much you are willing to sell it to me for. Thank you.
Looks like this:
g00dhum0r is offline
Old 07-22-2011, 12:25 PM   #2
g00dhum0r
Member#: 159025
2004 STI
Bumppp
Old 07-22-2011, 01:27 PM   #3
apache
Member Sales Rating: (2)
Member#: 160799
O2 WRX
You're probably better off buying a new one...these things leak all the time. I bought a used one and it leaks in almost the same exact spot that the original one did. No FMIC here.
A line off any Impreza '02-'07 should fit though.
apache is offline
Old 07-22-2011, 06:50 PM   #4
Rex A. Peel
Member Sales Rating: (9)
Member#: 85007
2005 Impreza WRX STi
Aspen White Stage 2
Can the schrader valve on the fitting be swapped? If so I have one.
Rex A. Peel is offline
Old 07-23-2011, 01:36 PM   #5
g00dhum0r
Member#: 159025
2004 STI
Well mine has a huge hole in it.
Im not sure if the valve can be switched. Why do you want to swap it?
Old 07-23-2011, 05:59 PM   #6
Rex A. Peel
Member#: 85007
Aspen White Stage 2
Mine was leaking from the schrader valve. I didn't bother looking into swapping the valve instead I just coughed up the hundred some odd dollars to buy the whole line. If it is possible to remove the valve from yours and put it on the line I have then I may be able to help you out. I just don't know if that valve is removable nor do I have the tool to do so.
Old 07-23-2011, 06:50 PM   #7
apache
Member#: 160799
O2 WRX
Yes the valve is removable.
Rex A Peel - if he doesn't get that one off you I'll take it.
apache is offline
Old 07-23-2011, 06:54 PM   #8
Abnormal
Lil Curious
Member Sales Rating: (45)
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Valve can be switched, it threads in just like any other schrader valve. Problem is finding one.
Usually the lines leak from elsewhere first, so there's not a huge aftermarket source for the Subaru AC valves. GM though...
Abnormal is offline
Old 07-23-2011, 09:56 PM   #9
nhat
Member Sales Rating: (42)
Member#: 140163
03 STi
hellaflunctional
i've got a spare high pressure line laying around.
nhat is offline
Old 07-31-2011, 12:21 PM   #10
g00dhum0r
Member#: 159025
2004 STI
Bump...
Old 08-06-2011, 01:02 PM   #11
g00dhum0r
Member#: 159025
2004 STI
Bumpppp
Old 08-18-2011, 02:18 PM   #12
g00dhum0r
Member#: 159025
2004 STI
Got it from craigslist!
Closed Thread
WTB : a/c high pressure hose for an 04 wrx defy_piff Private 'Wanted' Classifieds 8 07-29-2011 04:16 AM
WTB: 04 STI a/c high pressure hose AudiobahnSTI Private 'Wanted' Classifieds 0 08-05-2009 07:59 PM
WTB: Dirt cheap wheels that fit 04 STI ToesWRX MAIC Private Classifieds 1 04-22-2009 10:47 PM
WTB one wheel that fits 04 sti pj_cab NWIC Private Classifieds 3 01-31-2007 12:37 PM
WTB: 17" Wheels that fits 04 STI jal723 Vancouver Impreza Club Forum -- VIC 10 09-10-2005 12:40 PM
