Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 07-23-2011, 07:17 AM   #1
CaseDoc
Member#: 279370
Default Removing residue from glass
Just bought an 05 STI and the previous owner had a tint on the back window that had been removed. There is a sticky residue on the window now that is painfully difficult to remove with windex. What's the best product to get this stuff off?
CaseDoc is offline   Reply With Quote
Old 07-23-2011, 07:44 AM   #2
polarisboy385
Member#: 222041
2009 Impreza 2.5i
PRP
clay bar
then follow up with some stoners invisible glass.... multiple applications.
simply speculation. i have no experience with this situation. but its what i would try
polarisboy385 is offline   Reply With Quote
Old 07-23-2011, 08:08 AM   #3
TheNewThatGuy
Member#: 148041
2000 Rally Impreza
Blue and Gold, baby
goo gone
TheNewThatGuy is offline   Reply With Quote
Old 07-23-2011, 08:44 AM   #4
Subydude81
Member#: 118266
2007 Lexus IS250 RWD
6MT
If the tints on the inside which it should be do not clay bar it, you could mess up the defroster lines.
Something like this will work if http://www.detailersdomain.com/3M-Ge...983_p_272.html
Possible to get at a local hardware store. Just go easy on the defroster lines with whatever you use.
Subydude81 is online now   Reply With Quote
Old 07-23-2011, 09:28 AM   #5
CactuSTI
Member#: 283143
06 STI
Acetone and a razor blade. Takes like 3 minutes tops.
CactuSTI is offline   Reply With Quote
Old 07-23-2011, 09:38 AM   #6
TGUN11
Member#: 287255
2011 WRX Limited LRP
Tuned by MotionLab
i would use something like googone but make sure when you are wiping you are going in the direction of the defrost lines to insure you don't mess them up.
TGUN11 is offline   Reply With Quote
Old 07-23-2011, 11:06 AM   #7
polarisboy385
Member#: 222041
2009 Impreza 2.5i
PRP
oh darn, i forgot about those.
yeah goo gone might be a good bet.
or even some simple green
Old 07-23-2011, 11:19 AM   #8
CaseDoc
Member#: 279370
Thanks for all the responses! I'm gonna try googone.
Old 07-23-2011, 12:21 PM   #9
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
any cleaners that have ammonia in them, will take the glue right off.
Black94Snake is online now   Reply With Quote
Old 07-23-2011, 01:09 PM   #10
alx8283
Member#: 225024
2002 wrx
its been a while so i may be wrong but rubbing alcohol or denatured alcohol
alx8283 is offline   Reply With Quote
Old 07-23-2011, 05:38 PM   #11
Madtinter
Member#: 236237
2009 WRX
World Rally Blue
Try ammonia, spray the inside of the window and let it sit for few then hit it with a bath towel. If you have a garment steamer, that would also help.
Madtinter is offline   Reply With Quote
Old 07-23-2011, 06:31 PM   #12
jxkim
Member#: 239150
2003 WRX Sedan
goo gone didnt work for me
jxkim is offline   Reply With Quote
Old 07-24-2011, 01:13 AM   #13
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
of course not. You need something that disolves the glue, not smears it around.
Glass cleaners with ammonia will do the trick EVERY time
Old 07-24-2011, 01:55 AM   #14
hdempsey
Member#: 126374
2001 Impreza 2.5RS
Pure Aspen White
Doesn't windex contains ammonia?
hdempsey is offline   Reply With Quote
Old 07-24-2011, 06:47 PM   #15
wteGDF
Member#: 201665
2005 MmmMM CF....
Unique Starts Here....
Goo gone does work as I used it to remove the same issue the OP has on my gf's neons back window
wteGDF is offline   Reply With Quote
Old 07-24-2011, 07:17 PM   #16
lotarg
Member#: 90940
Razor blade and soap water! Works amazing, I use it to remove inspection stickers. No need to use acetone like someone above said, you don't want that dripping on your interior.
lotarg is offline   Reply With Quote
Old 07-24-2011, 07:29 PM   #17
nevin95 LSi
Member#: 219571
'02 wrx wagon 284k+
'95 SVX ebony mica
I use #0000 steel wool on all of my cars and all of our customer cars. It also works AMAZING on chrome bumpers and trim too. Make sure you get #0000 and not a heavier one though, (like 0 or 00) cause the coarser grits WILL leave scratches. The super fine grit works amazing though. Takes overspray off glass, bugs, dirt, hard water stains, etc...
Just start in one corner and work your way down, spray some glass cleaner on it first, (like invisible glass) and when you're all done go over it with some cleaner again. (IMO invisible glass it is the only glass cleaner worth the money) Your windows will look brand new when done.
nevin95 LSi is offline   Reply With Quote
Old 07-24-2011, 07:36 PM   #18
will.s
Member#: 280503
2007 WRX
+1 for super-fine steel wool. I just removed the tint off my two rear windows today and it took off the residue with minimal effort and no scratching.
will.s is offline   Reply With Quote
Old 07-25-2011, 10:50 AM   #19
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....I think a lot of you folks are missing the fact that the OP is removing residue from inside his back window. He wont be able to get as aggressive as he might with other windows due to the defroster.
Kean is offline   Reply With Quote
Old 07-26-2011, 01:19 PM   #20
izzodesh
Member#: 68274
2013 FJ Cruiser
cardomain.com/id/izzodesh
for me googone did not work just ALOT of windex, patience and a a razor blade
From another forum:
Time: 1-3 hours
Materials:
Warm sunny day
Tarp
Large plastic garbage bag
Undiluted Ammonia
Windex (a glass cleaner)
Paper towels
Fine steel wool
Razor blades
Tips:
The difficult thing about removing tint is that most film is constructed of two layers of tinted polyester. When you try to peel the film off the glass, the top layer will usually pull right off leaving the second layer behind. This second layer will not peel off, it will just flake and tear like a price tag.
Step 1:
To over come separation between layers you must soften the adhesive so that both layers peel at the same time. This is very important, if you peel the just the top layer, you may as well just use razor blades as there is no way to peel the second layer off without picking at it for a few hours. You MUST try to peel both layers at once.
NOTE:
You are more than likely to damage one or more of your defroster lines, when this happens, the cut line will not work anymore. Some cars have radio antennas mounted alongside the defrosters made of the same material. If you damage these, your radio antenna will not work! Be careful! Taking it to a tint shop to be done greatly increases the odds of saving the lines, but even a tint shop can not promise to save your lines, sometimes the film is just to far gone.
Step 2:
First, clear the window of any obstructions, like the brake light, speaker covers etc.
Step 3:
Next cut open the garbage bag so that it will be big enough to cover the entire window. Spray some water on the outside of the back window and the lay plastic bag over the glass. Cut away excess plastic so that it is now roughly the same shape as the glass.
Step 4:
Next, lay a tarp over rear deck and seat, spray ammonia liberally on the inside of the back window. (Ammonia is very strong, I suggest you hold your breath during this step) and cover ammonia soaked tint with the plastic bag so that it won't evaporate.
Step 5:
Park the car with rear window facing the sun for about an hour. The film should now be ready to peel.
Step 6:
When you are ready to start peeling, leave the plastic in place so the ammonia wont dry. Get the peeling started with a razor blade in a corner where there are no defroster lines. Try to peel film off in one piece. If the ammonia dries as you peel, the glue will get hard again, so spray a bit of ammonia on the area as you peel.
Step 7:
Once the film is peeled you will need to scrub the adhesive off with ammonia and fine 0000 steel wool. Mop up scrubbed areas with paper towels before they dry. Finish up with window cleaner and paper towels.
Removing tint from side windows
Soaking is not nessesary here. You may want to use a simple razorblade holder. Cut a notch onto the upper area of the film so that you have a piece to pull. Try to peel the film, it will probably come off in two or three pieces. Spray the remaining adhesive with soapy water, and scrape the adhesive off with a razor blade, avoiding the edges of the glass until last to keep the blade sharp. You may need to use a few blades as they dull quickly. Finish up with window cleaner and paper towels. Inspect for missed glue (its clear and hard to see)
Removing tint using a Steamer
If you have access to a Jiffy steamer or similar steam machine, you can make quick work of stripping. Apply the steam to a small spot for a few moments and use a blade or the spout of the steamer to peel the area just steamed, when you have enough to hold, just peel slowly as you steam just ahead of the area you are peeling.
This will bring both layers of tint off and sometimes the adhesive too, without presoaking for an hour.
izzodesh is offline   Reply With Quote
Removing wax residue from clear bra edge. TRooper Car Care & Detailing 8 03-18-2010 03:35 PM
how to remove streaks of white paint from glass maramaralula Interior & Exterior Modification 9 01-03-2007 10:02 PM
Removing sticky residue from paint.. Christoff Off-Topic 8 01-11-2004 06:18 AM
How can i remove the molding/glass from the wagon rear? ^jynx^ General Community 1 10-19-2003 03:54 PM
Removing soft drink residue from interior chkltcow South East Region Forum 7 07-06-2002 12:51 AM
