Old 07-23-2011, 10:20 AM   #1
Subaru_WRX
Member#: 287575
2008 WRX
Obsidian Black Pearl
Default Subwoofer & Navi
Is it possible to connect a subwoofer & amp to the stock Navi in an 08 WRX? Mine didn't come with a subwoofer from the factory, or the previous owner removed it
Subaru_WRX is offline   Reply With Quote
Old 07-23-2011, 07:45 PM   #2
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Yes!
The 2008-2011 OEM Kenwood Navi HUs have a 24-pin harness for nav-related functions and A/V inputs and outputs. The HU's socket includes pins for a line-level subwoofer output that is only used in some Foresters.
See OEM Navi HU information I've posted here (in my 'Subaru Stock HU FAQ' thread, second half of post #11).
Rear of your 24-pin plug:
This line-level subwoofer output is controlled by the on-screen menus:
Note that these settings do not apply to the OEM under-seat accessory subwoofer or the OEM Kicker subs -- those types have harnesses that tap off of the HU's front main speaker outputs.
I can make a cable with a female RCA jack (along with a separate pin/wire for amp remote turn-on) with pins that you can snap into your car's harness. E-mail me for details (see my profile).
The Navi's subwoofer output is mono. To connect to an amp or powered sub that requires signals on dual inputs, I recommend running a single RCA cable from the HU to your amp, and add an RCA Y adapter at the amp (such as this or this).
SVXdc is offline   Reply With Quote
Old 07-24-2011, 10:02 AM   #3
Subaru_WRX
Member#: 287575
2008 WRX
I sent you a email. I would love to have one of those cables.
Old 07-24-2011, 05:32 PM   #4
whteWRX
Member#: 285967
I can make a cable with an RCA jack (along with a separate pin/wire for amp remote turn-on) that you can snap into your car's harness. E-mail me for details (see my profile).[/quote]
Sent you an email.
Thanks.
whteWRX is offline   Reply With Quote
Old 07-25-2011, 06:09 PM   #5
svxninja
Member#: 279510
02 Wrx
can you do anything like this for a 02?
svxninja is offline   Reply With Quote
Old 07-27-2011, 12:27 AM   #6
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Non-nav factory radios and older years don't have a line-level subwoofer output. A few older radios do have a 5th-channel subwoofer speaker-level (high-level) output. You can tap a pair of the main speaker outputs or the sub out (if you have it) and pipe that into an an aftermarket amp and sub.
I have Subaru radio harnesses that have wires on all of the pins. You can use those to tap the OEM HU's speaker outputs without cutting or splicing into the factory wires. I can also make a harness with the plug for the 5th-channel sub out for OEM radios that have that.
Old 07-27-2011, 12:45 PM   #7
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
SVXdc: I have a similar situation, but with 2 amps and am wondering if it would make sense for me to get that adapter you make (just for sub amp) or just push everything to an LC6i and then my amps from there. I do like the idea of using the HU's sub control.
2point0 is offline   Reply With Quote
Old 07-27-2011, 01:01 PM   #8
darren94
Member#: 138697
11 WRX Limited 5DR
Satin Pearl
So can i just install a amp/sub with the stock navi like a normal install? or is there splicing and custom things that need to be done?
I guess i am asking, to use the factory navi with a aftermarket sub/amp, can i run the power wires, remote line and such (which is easy) like normal and do a plug and play install?
darren94 is offline   Reply With Quote
Old 07-27-2011, 01:06 PM   #9
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
^You need a way to get your audio into the amp. This requires either a line-out converter (speaker wire input --> RCA output to amp) or an amp that takes speaker wire inputs (basically has the line-out converter built in).
Factory navi does not have RCA outputs on the back.
Old 07-27-2011, 02:00 PM   #10
achilles224
Member#: 286465
'08 WRX SSM
'02 WRX WRB
SVXdc made me an RCA jack that worked perfectly on my 08 2.5i w/ Navi. Just did this last week, PM me if you have any questions.
achilles224 is offline   Reply With Quote
Old 07-27-2011, 03:18 PM   #11
darren94
Member#: 138697
11 WRX Limited 5DR
Satin Pearl
So, what is the easiest "best" way to get the audio source to the amp on my 2011 with navi?
Old 07-27-2011, 05:30 PM   #12
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
I don't think you can use the Navi's line-level subwoofer signal as an input to the LC6i (because it appears to only accept speaker-level [high-level] signals as input), so there may not be any benefit to using my adapter with the LC6i. But you should talk to AudioControl to confirm.
Note that the Navi's sub settings are a couple of menu levels deep, so if you're a person who will want to constantly tweak the sub levels for different songs, you may be better off adding the LC6i's optional sub level pod (or switching to an aftermarket HU that lets you adjust the sub level from the front panel).
You could always start with my adapter without the LC6i, and add the processor later if you don't like how it sounds initially.
Once you add the sub RCA cable (see picture I added to my first post), your Navi will have an RCA jack and remote turn-on lead, so it really would be just like adding a sub to an aftermarket HU.
Now if you're looking at amping your main speakers, the Navi does not have line outs for those. You would have to pipe the HU's speaker outputs into your speaker amp (through a LOC, if necessary). I also have harnesses that make that job easier (so you won't have to hack any factory speaker wires).
And if you really want to go gung ho, the Navi also has a line-level center channel speaker output. See the link in my first post for more info.
Old 05-05-2012, 04:34 PM   #13
Sweetsandman
Member#: 239629
2009 WRX
I will definitely be emailing you about getting those cables!
Sweetsandman is offline   Reply With Quote
Old 07-21-2012, 05:22 AM   #14
suny05
Member#: 326797
Originally Posted by SVXdc View Post
Yes!
I didn't know that, luckily I haven't purchased the the OEM sub yet. I was wondering that if that's the case how do I adjust the sub volume? Or can I request the dealer electrician to install it as the way you describe (connect the OEM sub to the 24 pin to the back of the HU)?
Thanks
suny05 is offline   Reply With Quote
Old 08-04-2012, 07:38 PM   #15
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by suny05 View Post
I was wondering ... how do I adjust the sub volume [on the OEM Kicker sub]?
You can't. See discussion here.
A dealer won't do that. In order to drive the OEM Kicker sub from a line-level (low level) signal, you will likely need to modify the Kicker's amp. I'm not how much effort that would require (or if it would be worthwhile). Probably better to just go with an aftermarket sub.
Old 12-18-2012, 10:13 PM   #16
napootuning
Member#: 302158
08 impreza sti
midnight blue
how much will it cost me to get this sub woofer mod from you?
napootuning is offline   Reply With Quote
Old 12-18-2012, 10:31 PM   #17
Mephiska
Member#: 17560
2013 STI 5-door
Satin White Pearl
Since you can't adjust the sub volume with the 08-11 nav I suggest a powered sub with a remote gain control. Unless you want huge bass, the B-8pt I just got provides more than enough low end and it includes a remote level cable and dial.
It would also be quite cost effective at $150
Mephiska is offline   Reply With Quote
Old 12-18-2012, 10:35 PM   #18
mrchyes
Member#: 294069
04 Impreza RS
completely off topic. but i find nothing more annoying that the word "navi" some chick on a toyota comercial says it and it makes me want to punch her in the throat.
mrchyes is offline   Reply With Quote
Old 12-18-2012, 11:05 PM   #19
Mephiska
Member#: 17560
2013 STI 5-door
Satin White Pearl
Doesn't bother me. Whenever I read it I'm reminded it this
Old 12-22-2012, 09:22 AM   #20
mattayt
Member#: 341337
Best source of info I've found so far : ) Thanks!
mattayt is offline   Reply With Quote
Old 04-22-2013, 06:27 AM   #21
ThomasGollob
Member#: 354218
Hi SVXdc, I would love if you could help me out with one of these cables for the sub output. I have been looking around on a lot of forums, trying to find someone local making these, it would be greatly appreciated if you could get back to me.
Cheers.
ThomasGollob is offline   Reply With Quote
Old 04-22-2013, 11:13 AM   #22
evilspoons
Member#: 321311
2012 STi 5-door
World Rally Blue
This looks exactly like a 20th Anniversary Macintosh with a paint job.
evilspoons is offline   Reply With Quote
FS : NYC Pioneer TS-WX75A Subwoofer & Pyramid Bazooka Subwoofer CHEAP!! terfer Tri-State Area Private Classifieds 0 12-29-2010 11:08 PM
FS: New JBL 1000 GTi Subwoofer & BP 1200.1 Amp S54 Private 'For Sale' Classifieds 17 05-03-2004 09:12 PM
FS: JL Audio Subwoofers & Amp! jandro62 Private 'For Sale' Classifieds 1 01-13-2004 09:50 PM
FS: JL 12W1 Subwoofer & Soundstream Amp mines wrx Private 'For Sale' Classifieds 0 01-08-2004 09:21 PM
FS: JL 12W1 Subwoofer & Soundstream Amp mines wrx Bay Area Impreza Club Forum -- BAIC 2 01-06-2004 10:57 PM
Message Board Statistics All times are GMT -4. The time now is 02:42 AM.
