Old 07-28-2002, 01:12 PM   #1
Camperguy
Member#: 21274
2002 Mc_Bains car
I use to have a WRX :(
Default Red-Line water wetter....
Temp use to be right in the middle of the gauge now it sits just above the first line...must be doing something But really I`ve used this stuff in all my vehicles/motorcycles cant hurt,just make sure you follow the directions oz per gallons.
Bill
Camperguy is offline   Reply With Quote
Old 08-23-2002, 10:23 PM   #2
_t_
Member#: 19861
2001 2.5RS
BRP
it sure has an interesting smell tho
_t_ is offline   Reply With Quote
Old 08-23-2002, 11:15 PM   #3
Family Truckster
Member#: 14201
2002 WRX Wagon
Default what about the thermostat?
Doesn't the thermostat still work @ the same temp?
Family Truckster is offline   Reply With Quote
Old 08-24-2002, 12:19 AM   #4
pagel
Member#: 17761
2005 Leg.GT L wagon
Default Coolant temps
Thermostat will still open at 195 (or whatever) but AFTER it opens the Water Wetter will lower the peak temperature the coolant will reach. Anyone feel differently about this?
pagel is offline   Reply With Quote
Old 08-30-2002, 05:39 PM   #5
Sir_Xenon
Member#: 9666
02 WRX
Ver. 7 STi swap'd bugeye
The "wetted" coolant absorbs heat more quickly. The coolant can take heat at a faster rate and send more heat out (at the radiator) than without the stuff - so they say.
The thermostat will work as always but the liquid will be more responsive and more absorbant to and of heat input from the engine.
You guys in hot climates should try Zerex. I wrote a note about it a while back in a thread. It allows the use of 90% water in your system while keeping the engine from corroding. It gives 25% better heat transfer as a result. FYI a lot of race teams use pure water since pure H20 has the best heat transfer capability. The only draw back is that you'll blow your motor if the temps are below freezing.
Mark
Sir_Xenon is offline   Reply With Quote
Old 09-04-2002, 11:01 AM   #6
nhluhr
John Wayne Toilet Paper
Member Sales Rating: (22)
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Just a note for those confused:
"Wetter" has nothing to do with watering down your coolant.
The "Wetting Angle" is the angle at which a bead of liquid meets the surface it's touching. A High wetting angle means the liquid has more surface area in contact with the solid. A low wetting angle means the water has very little surface area in contact with the solid.
For instance, most automotive waxes make the water bead up. This is an example of decreasing the wetting angle. Now, we really want coolant to remain in contact (at a microscopic level) with the solid as much as possible to make more contact, and thus transfer more heat. The Redline Water Wetter increases the wetting angle of the coolant and thus allows an increase in surface area contact (again, at a microscopic level).
In theory, this stuff would allow a faster heat transfer from the engine to the coolant and from the coolant to the radiator, thereby getting rid of heat at a higher rate.
nhluhr is offline   Reply With Quote
Old 09-22-2002, 11:55 PM   #7
DuB ReX
Member#: 18482
Midnight Black Pearl
Talking
this product was just recommended to me late last night from another WRX owner and so i went to pep boys and picked it up for around $7...i was kinda confused on how to use it though..i know it goes in the radiator but where can i find how much i should put in? i haven't checked but i guess i'll look through my manual to see how much of the water wetter i need....do i pour the whole thing in there or what? my car is a MY02 WRX. thanks for the input
btw i was gonna make a new post but i decided to use search first.. good thing or people would definitely have pointed that out.. x_X
DuB ReX is offline   Reply With Quote
Old 09-23-2002, 12:46 AM   #8
pagel
Member#: 17761
2005 Leg.GT L wagon
Default Using Water Wetter.
You might want to use a "gravy baster" to suck out the equivalent to the capacity of the bottle of Water Wetter so you don't overfill. Use the whole bottle. You can either suck/add to the overflow tank or directly into the radiator.
Old 09-23-2002, 02:03 AM   #9
DuB ReX
Member#: 18482
does it matter whether or not i suck it out if it's the overflow bottle? would i just be able to add it all into the overflow bottle without taking any out? and also is it as effective by putting it into the overflow bottle instead of putting it direclty into the radiator? like does the overflow bottle always circulate the liquid in there and the liquid in the radiator constantly??
Old 09-23-2002, 06:09 AM   #10
pagel
Member#: 17761
2005 Leg.GT L wagon
Default Water Wetter.
I just dumped the whole bottle into the overflow tank and it didn't overfill it that much above the "hot" mark. Eventually it circulated and mixed in by itself.
Old 09-23-2002, 04:44 PM   #11
DuB ReX
Member#: 18482
hm..just curious but how often do you need to put in a new bottle of water wetter? i heard it was every 30k miles, but the directions don't say nething about it..
Old 09-23-2002, 06:29 PM   #12
pagel
Member#: 17761
2005 Leg.GT L wagon
Default Frequency Water Wetter
I'm not gonna worry about it since I'll have the coolant flushed and replaced at 50-60K and then I'll throw in another bottle.
Old 11-07-2002, 04:47 AM   #13
Ti-REX
Member#: 21741
LGT Limited Wagon +
WRB Wagon STI V7/8
This stuff is truly amazing.
I used to see oil temps in the high 135 degres Celcius on long fast drives in my previous supercharged Jetta. It used oil to cool the supercharger and could not keep up at speed over 100 mph.
One suggested I try Water Wetter in my coolant. After it was mixed to the coolant system, the oil temp never rised above 100 degres Celcius.
BTW, I used it with a 15% coolant mixture.
Great product.
Ti-REX is offline   Reply With Quote
Old 11-07-2002, 04:49 AM   #14
Ti-REX
Member#: 21741
LGT Limited Wagon +
WRB Wagon STI V7/8
Great product.
Old 11-07-2002, 10:56 AM   #15
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
i just poured in most of a bottle the other day and i didn't really see a big decrease in the temp gauge... it's still sitting just above the lower-mid line...
Old 11-07-2002, 03:47 PM   #16
DetroitWRX
Member Sales Rating: (4)
Member#: 18777
2002 WRX Wagon
Sedona Red Pearl
This stuff works great I just dump the whole bottle in and I have to ewvery car I have owned. It works better with big engined cars that over heat alot (Mustangs). You will not see a diferance in engen temp from the gauge in the car. Cuz the thermostate will still open at same temp. I notices the engine bay is cooler. befor I couldn't even think about touching intake runners at operating temp now I can touch then for a qick second or two. It dosent make as big of a diferance with our small motors but in big V8 cars it awsome.
Rob
DetroitWRX is offline   Reply With Quote
What ratio water/coolant do you run? Water Wetter too? mav1c Motorsports 50 06-03-2009 03:37 PM
Water wetter with just water? mjohn617 Service & Maintenance 8 05-02-2005 08:02 PM
Adding Water Wetter? Khemicalkid Newbies & FAQs 5 07-31-2002 04:03 PM
How many guys running Redlines Water Wetter? Camperguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-28-2002 09:23 PM
RedLine Water Wetter?? donjuan Technical Forum Archive 15 09-29-2000 05:20 PM
