Notices
Old 07-24-2011, 07:07 PM   #1
DRTiraPiedra
Member#: 265912
Default 2011 WRX Hatch elevated engine temperature
Long story short.
1) Sitting in traffic due to construction.
2) AC was on not blasting but enough to keep my wife daughter & me cool.
3) Noticed that the temp started to climb passed where it normally stays. It was a little pass the half way point.
4) Concerned that it would continue to climb I drove on the breakdown lane until reaching a point I could make a U turn & then proceeded to go to the dealer.
5) Iphone dead couldn't take a picture.
6) Once at the dealer car was back to operating temperature.
7) Subaru tech had me drive around could not duplicate issue.
8) Subaru tech inspected the cooling components, ie radiator, hoses, coolant fluid. No issues there.
Conclusion: The Subaru tech could not find any issues, his guess was maybe heatsoaking was the culprit.
My questions are:
1) Has anyone else experienced an issue?
2) I know that the 05 STI came with an intercooler sprayer. Did it actually lower the temp of the engine when pressed?
3) How difficult would it be to install one? I'm currently searching for a kit.
PS Car is 100% stock besides the tints.
DRTiraPiedra is offline   Reply With Quote
Old 07-24-2011, 07:20 PM   #2
2011WRXMT
Member#: 270426
2011 WRX Premium
Satin Pearl White
Just sitting in traffic not moving will make temps go up a bit, thats when the fans should kick on though when your not moving. When stopped the only airflow is from the fans as compared to when your moving. I would say its normal for it to do that, if your worried about it you could try adding some water wetter, royal purple coolant additive etc as they claim to lower coolant temp by up to 20 or so degrees.
2011WRXMT is offline   Reply With Quote
Old 07-24-2011, 07:55 PM   #3
cjeckert
Member#: 235032
2010 WRX
My 2010 will sit a needle width past the half way point in traffic and high heat.
cjeckert is offline   Reply With Quote
Old 07-24-2011, 08:06 PM   #4
everdying55
Member#: 112651
2011 Corn Fed WRX
DGM Hatch
Same for my 2011.
everdying55 is offline   Reply With Quote
Old 07-24-2011, 08:37 PM   #5
gregonfire
Member#: 181047
2015 CWP WRX Limited
2010 WRX 310/345 - Sold
Originally Posted by everdying55
Same for my 2011.
Same for mine as well. Come to think of it, it's always been that way no matter the exterior temp. Hope the problem isn't anything serious!
gregonfire is offline   Reply With Quote
Old 07-24-2011, 08:38 PM   #6
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
how hot was the outside temps? my 08 will hover in the middle of the guage when its above 90 degrees outside. i think your car is fine.
424wrx is offline   Reply With Quote
Old 07-24-2011, 08:49 PM   #7
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
me too.
OP, please be more specific. how MUCH more past halfway did it go? the gauge isn't very sensitive either. it stays in the same position independent of whether i'm at 185F or 202F which is the regular fluctuation i see
also, keep topics like this away from general and in technical as you will get better feedback.
Nimbus09 is offline   Reply With Quote
Old 07-24-2011, 09:36 PM   #8
allroy81
Member#: 62260
2004 sti
2013 forester
Intercooler sprayer sprays warm water thats been sitting in your trunk directly on the intercooler. Not gonna lower the temp of your engine while sitting in traffic.
allroy81 is offline   Reply With Quote
Old 07-24-2011, 09:39 PM   #9
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
Its normal, don't worry until it gets up to the H.
ki4syr is offline   Reply With Quote
Old 07-25-2011, 09:39 AM   #10
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
it not normal..
if for some reason the there was a air bubble in the coolant system this would cause
the over heating issue.
open hood
remove radiator cap
start car
observe the coolant level in reservoir
dip thermometer in (use finger if you do not have one)
add coolant if needed
once the it gets hot to touch re-install radiator cap
allow to warm until coolant fan kicks on ~204 F
note the position of coolant needle on gauge.
go drive around..watch for changes in needle position.
187-189 f normal operation temperatures
Old 07-25-2011, 10:24 AM   #11
DRTiraPiedra
Member#: 265912
Originally Posted by Nimbus09 View Post
me too.
Thanks I wasn't 100% sure I'd get responses in technical considering I didn't have a cel or something that is definitely broken.
To answer your ? It was between half and H closer to half but still up there when I noticed I immediately pulled onto the shoulder by the time I got to the dealer it had gone to normal. As I was driving it did begin to slowly go down it seemed like the cooling system just couldn't keep the ac running and the engine at normal temp. I do acknowledge that this was on a day that it was 104 with a heat index between 103 and 115.
Old 07-25-2011, 10:32 AM   #12
DRTiraPiedra
Member#: 265912
I was considering a cryo system it sprays a mixture of gasses freon. I had a kit on my boosted Civic just don't remember what it was called. I know it had a sprayer in front of the air intake and in front of the radiator. It would spray a mist that would be triggered by either a toggle switch next to my ebrake or when the temperature would exceed a certain numerical limit.
Old 07-25-2011, 10:35 AM   #13
DRTiraPiedra
Member#: 265912
Originally Posted by jaxscuby View Post
it not normal..
open hood
remove radiator cap
start car
Thanks, will do when I get out. I had my wife take the suv and leave the wrx inside the garage. I didn't want to risk her not noticing the temperature going up and messing up the engine.
Old 07-25-2011, 10:36 AM   #14
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
possibly a thermostat that is on its way out. it may not have opened as soon as it should have. that is my best guess, but there could be a bunch of other things that can cause what you have seen. keep an eye on the temp gauge.
Old 07-25-2011, 12:18 PM   #15
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
it not normal..
A little past half way is NORMAL. My WRX has always ran at the dot above the half way mark, either at 20*F or 90*F ambient temperature. Until the needle goes closer to the top of the gauge and into the "H" area, it is normal.
Your looking WAY too deep into this. A dealership is not going to do much for something they can't replicate. Just like my 2010 Forester. It spark knocks like a bitch here in the mountains, even with 89 octane. I took it to the Dealership, which is 1500ft lower in elevation, and they couldn't reproduce symptom. They just said to try different gas stations. I already have, but they still didn't do anything.
FS : SPT cat back exhaust 08+ Sti hatch, 2011 wrx hatch BOOST3DWRX Engine/Power/Exhaust 3 04-07-2011 10:03 AM
FS/FT : 2011 WRX hatch spoiler on a 2011 OBS hatch? sofa-king-groovy Exterior/Styling 2 02-20-2011 06:19 PM
Rear swaybar for 2011 WRX Hatch hisdigness Brakes, Steering & Suspension 4 10-16-2010 04:15 AM
About to Order 2011 WRX Hatch krautklimb Newbies & FAQs 3 10-13-2010 07:49 PM
